Can't keep speed up in the mountains - JeepForum.com
post #1 of 14 Old 04-10-2011, 12:35 PM Thread Starter
nicksdsm
I took a drive out to the mountains last week. Some of the mountains are steep but the majority aren't to bad. After about 20 minutes of driving up and down the mountains my XJ started to feel like it was struggling to speed up or keep a constant speed (like the brakes were engaged). In the beginning I was traveling at approx 60 mph and at the end it wouldn't go over 25-30 mph. At one point I had to stop because I though something was wrong. After about a 10 minute rest, I continued on. At first it was fine but it quickly started doing it again. After my trip I didn't drive my jeep for a few days. Yesterday I drove on a flat highway for about 3 hours. Towards the end of my trip my XJ started to have a problem keeping a constant speed. No matter how hard I pressed the gas it kept wanting to slow down. The engine temp was normal at 200-210. I'm thinking the tranny is getting overheated. After I stop my jeep I don't smell anything out of the ordinary. I spoke to a friend who is a mechanic. He said the problem is probably the cats going bad. Any Ideas???
nicksdsm is offline
post #2 of 14 Old 04-10-2011, 03:37 PM
scavok
1993 XJ Cherokee
Are your RPMs going high when you are trying to keep speed?
If its a manual trans - when I cruise in the mountains I keep it in 4th gear, 5th is useless uphill for too long.
ScavoK
scavok is offline
post #3 of 14 Old 04-10-2011, 04:49 PM
srmitchell
Sorry, I'm on my phone, but what's your setup? Lifted? Tire size/gears? And which tranny?
If it's the aw4, check the fluid.
Also, check all vacuum lines, and clean your throttle body. Don't rule out dirty, or bad sensors.
Mine cruises up huge hills in 3rd gear all day long.
I work on Mopars
srmitchell is offline
post #4 of 14 Old 04-10-2011, 05:53 PM
scavok
1993 XJ Cherokee
one more thing to check is your air filter. High altitude and a bad filter will drop performance too.
ScavoK
scavok is offline
post #5 of 14 Old 04-10-2011, 06:39 PM
Texsun
if your tranny is auto is sounds like its getting over heated... but idk
Texsun is offline
post #6 of 14 Old 04-11-2011, 04:00 AM Thread Starter
nicksdsm
It's a auto tranny. I'm lifted 3-4 inches, 30 inch tires. stock 3.55 gears (I think).
The RPM's won't go up. It's not reving out.
nicksdsm is offline
post #7 of 14 Old 04-11-2011, 04:18 PM
scavok
1993 XJ Cherokee
If it isnt revving up or sticking i doubt its the tranny, i'd bet on air or fuel flow. How are your filters? Is it ever hard to start up?
ScavoK
scavok is offline
post #8 of 14 Old 04-12-2011, 05:51 AM Thread Starter
nicksdsm
I have a newer k&n 9 inch cone filter. It's not dirty and it's never hard to start. It's always turns over on the first try.
nicksdsm is offline
post #9 of 14 Old 04-12-2011, 08:24 AM
jeeptorino68
1992 XJ Cherokee
hows the fuel filter?
how about the condition of the throttle body> is it filthy?
also is the kickdown cable properly adjusted?
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline
post #10 of 14 Old 04-12-2011, 08:32 AM
XJH-007
XJH-007's Avatar
X2 what Kyle said....If it's not kicking down into lower gears something is going on with the tranny...now there may also be something else such as a clogged cat that is causing the loss of power.
Miles? Original Cat?
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #11 of 14 Old 04-12-2011, 08:33 AM Thread Starter
nicksdsm
The Trans does shift, the engine just wont rev.
I'm not sure about the fuel filter, It's probably dirty. I have a new, clean 63mm TB. What is a kickdown cable?
nicksdsm is offline
post #12 of 14 Old 04-12-2011, 08:40 AM
XJH-007
XJH-007's Avatar
Uhhhhhhhhh the trans shifts but the engine speed doesn't change??
***02 WJ Overland
XJH-007 is offline
post #13 of 14 Old 04-12-2011, 09:25 AM Thread Starter
nicksdsm
The trans shifts down the RPM's raise but no matter how far I push the gas down the engine won't speed up.
nicksdsm is offline
post #14 of 14 Old 04-12-2011, 09:50 AM
lowicz96
1995 XJ Cherokee
Sounds like either air cant get in, exhaust cant get out or fuel isnt getting in. I would try the cat 1st, when they collapse you lose a bunch of power
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
swap 4 speed with a 5 speed.dont know if they make one the87XJkid XJ Cherokee Technical Forum 8 08-11-2009 06:56 AM
4 speed or 3 speed trans? RamboPants XJ Cherokee Technical Forum 1 03-25-2007 01:49 PM
Blown radiator hose while in mountains!! SoloHiker XJ Cherokee Technical Forum 9 10-15-2006 10:33 AM
3-speed vs 4-speed Auto TJ_PILOT XJ Cherokee Technical Forum 4 11-17-2003 10:34 PM
5 speed nosinjcted XJ Cherokee Technical Forum 1 01-26-2003 02:18 PM
