Cactus Jack's NEW build thread! - Page 8 - JeepForum.com
post #106 of 130 Old 02-12-2013, 06:52 PM Thread Starter
cactus_jack
Originally Posted by thenewguy79 View Post
Not beyond pinch weld though?
Cut and fold. Showed how I did it earlier in this build
Sent from my MB865 using JeepForum
CACTUS_JACK
98 XJ Sport Budget Build
cactus_jack is offline
post #107 of 130 Old 02-12-2013, 07:34 PM
thenewguy79
Cool thanks
thenewguy79 is offline
post #108 of 130 Old 02-12-2013, 07:38 PM
thenewguy79
Cool thanks
Found it. Thanks again for the help
post #109 of 130 Old 04-08-2013, 06:08 PM Thread Starter
cactus_jack
Well it's been a while since I've had time to give the Jeep some love. Between work, college and a lack of a warm work area, I just haven't been able to do much.
Today was a sunny 75 degrees and I decided to tackle my steering gear box. It had some noticeable slop and was getting quite annoying. I opted to go with the Durango upgrade.
I got the Durango box from NAPA for about $130 with my employee discount. Went ahead and got new pressure and return lines as well.
Here they are side-by-side. Not much difference except the Durango box has a slightly noticeable beef to it.
Also had Mark over at Detours Offroad Hardware fabricate this beefy spacer out of 3/16 plate. I was surprised to see the factory aluminum spacer came out in one piece.
Overall, a MUCH better drive with the new box. Steering is much tighter and has much better response at highway speeds. I'd highly recommend it to anyone looking to upgrade.
In other news, I'm doing some slight customizing to my eBay bumper as well as adding some lights. Should have it done next Monday.
CACTUS_JACK
post #110 of 130 Old 04-08-2013, 08:29 PM
VegasGT
1988 MJ Comanche
Durango upgrade is my plan too when my box lets go. Sure was a nice day in good ol Kentucky today, huh?
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #111 of 130 Old 04-08-2013, 08:32 PM Thread Starter
cactus_jack
Yessir. Hope spring is here to stay
CACTUS_JACK
post #112 of 130 Old 04-12-2013, 05:34 AM Thread Starter
cactus_jack
Decided to go ahead and fix my exhaust manifold this weekend instead of finishing welding the bumper. I'm getting some ticking or light knocking sounds and I want to see if they go away with a new manifold. I'll go ahead and do motor mounts while I'm in there too.
What do you guys think? It sounds like a light rod knock. Goes away with a slight rev. Flexplate bolts are tight.
CACTUS_JACK
post #113 of 130 Old 04-20-2013, 10:23 AM Thread Starter
cactus_jack
Took care of the dreaded exhaust manifold. Didn't take care of my ticking noise but at least I don't smell like exhaust fumes every time I drive it
It had a pretty significant crack at the bottom
Wasn't too bad of a job. Took me about 2 1/2 hours. Hardest part was the bottom intake bolts. I'll be getting that bumper finished up Monday hopefully as long as the weather cooperates.
CACTUS_JACK
post #114 of 130 Old 04-20-2013, 10:49 AM
XJ99XJ
1995 XJ Cherokee
Did your "new" manifold come with the mounting bolts? Good work when I did my 99 I ended up reusing old ones. But then I sold it.
--1999 Cherokee Sport 2" Lift 30" rubber
---1995 Cherokee Sport 4.5" 32" rubber
XJ99XJ is offline
post #115 of 130 Old 04-20-2013, 11:56 AM Thread Starter
cactus_jack
It came with the two bottom bolts for the donut but I had to buy the manifold bolt kit separately.
CACTUS_JACK
post #116 of 130 Old 04-20-2013, 12:33 PM
XJ99XJ
1995 XJ Cherokee
Somthing Imma have too keep in mind, cheers
XJ99XJ is offline
post #117 of 130 Old 04-22-2013, 06:11 PM Thread Starter
cactus_jack
Finally finished fixing my eBay bumper today. I didn't like how it ran straight across the front so I made some relief cuts, bent and welded it on both sides. Also added some unibody tie-in mounts and cut off the smaller tubing pieces and just left the bull bar.
CACTUS_JACK
post #118 of 130 Old 04-22-2013, 07:05 PM
VegasGT
1988 MJ Comanche
Much better!! Looks real good, nice handywork.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #119 of 130 Old 04-23-2013, 09:49 AM Thread Starter
cactus_jack
Thanks man, I'll be adding some lights to it soon so it should look pretty nice when it's finished
CACTUS_JACK
post #120 of 130 Old 04-27-2013, 12:10 AM
tofuzeppelin
tofuzeppelin's Avatar
Good call on cleaning that bumper up. Also really diggin the full black look, Not usually done well but yours looks good man
01 TJ with some stuff
77 SJ Cruzer
Lifes to short for bad coffee and bald tires
tofuzeppelin is offline
My Build Thread - 99 XJ XJK XJ/MJ Cherokee Non-Technical Forum 58 04-22-2013 02:30 PM
Cactus Jack's Build Thread cactus_jack XJ/MJ Cherokee Non-Technical Forum 21 05-06-2012 06:57 AM
My build thread. My attempt on a SAFE build on a budget. xyimmyx XJ Cherokee Technical Forum 46 06-09-2011 02:50 PM
Yet another 99 XJ build thread Prosonic XJ Cherokee Technical Forum 172 11-23-2010 04:58 PM
My build Thread.. miniderblank XJ Cherokee Technical Forum 24 02-28-2010 10:30 PM
