Cactus Jack's Build Thread - JeepForum.com
post #1 of 22 Old 09-28-2010, 09:10 PM Thread Starter
cactus_jack
OK folks so here's the scoop:
00 XJ Sport. Partial DD, Partial trail rig
I work for Napa so parts will come fairly cheap
Plans are: Budget boost of at least 4", 31's or maybe 32's. Eventually will have roof rack, armor, etc, etc,
Will be starting my lift soon. I have everything on hand for it now
96 Grand Cherokee coils-----NEW from work $60
2" Coil Spacers from eBay------------------$41
S-10 Leafs for bastard pack---------------FREE
All four RC Shocks-------------------------$136
I'll be starting my lift on my next day off of work so I will post pictures then.
Any suggestions or ideas would be cool. Look forward to sharing my build with you all
CACTUS_JACK
98 XJ Sport Budget Build
cactus_jack is offline
post #2 of 22 Old 09-28-2010, 09:16 PM
BamaXJ
1989 XJ Cherokee
So basically you've got the NAPA hookup for all your brothers on the forum. Haha, just kidding man. I'm looking forward to seeing some pictures of this bad boy.
1989 Jeep Cherokee:
Lift, tires, suspension, accessories, and other crap.
BamaXJ is offline
post #3 of 22 Old 09-29-2010, 06:16 AM Thread Starter
cactus_jack
lol, you got it man. I'll get some pictures up on my next day off of work
CACTUS_JACK
post #4 of 22 Old 10-19-2010, 07:23 PM Thread Starter
cactus_jack
OK, so I finished the front end today and was a bit disappointed with the outcome and the fact that I netted about 2 3/4 inches of lift instead of the 4 inches I had hoped for. I'll be starting on the rear as soon as I get a chance, been real busy with work and planning my wedding! Below are some pics, enjoy!
(Above) Stock height, just about to pull it in the garage
(Above) Sitting at roughly 30 3/4 inches in the front before starting
(Above) Went ahead and did a brake job while I had the wheels off...the little red jack was a bit of a pain in the *** to work with but it got the job done
(Above) That's how she stands today. I've since backed it back into the garage so I can get started on the bastard packs for the rear. I'll keep everyone updated
CACTUS_JACK
post #5 of 22 Old 10-19-2010, 07:35 PM Thread Starter
cactus_jack
oh, and I have a question.....do I REALLY need the front sway bar? It's not much of a daily driver and I cant see a front sway bar making that big of a difference. I have new sway bay links but havent put them on yet (broke the old ones) So the sway bar is just sort of dangling there for now
CACTUS_JACK
post #6 of 22 Old 10-19-2010, 09:34 PM
motorsports3
1997 XJ Cherokee
You dont need it, but it could be quite dangerous driving without it, esp at highway speeds.
Some people here say it is horrible, and some say it isnt that bad.
motorsports3 is offline
post #7 of 22 Old 10-20-2010, 02:23 AM
connor0770
looks good for a budget boost!!! how do those RC shocks ride?
97 TJ Dana 30 w/ARB Solid Cover, Currie 4" lift, Ford 8.8 w/ Riddler Cover, Currie Steering, Trail Gear Front Bumper, LOD Rear Tire Carrier, Smittybuilt XRC8, 35" KM2's, 5100 Bilsteins, Teraflex Oil Pan Skid, Poison Spider Sliders, Rock Lights etc.
connor0770 is offline
post #8 of 22 Old 10-20-2010, 05:35 AM Thread Starter
cactus_jack
I guess there's only one way to find out....drive it, lol
so far not too bad. I thought it would ride really rough but they're doing pretty good
CACTUS_JACK
post #9 of 22 Old 10-25-2010, 02:04 PM Thread Starter
cactus_jack
Got the garage all ready to start the rear today. Had to build a work bench to put my new tool box on and stuff. Also picked up a cheapo grinder from Harbor Freight yesterday so I could start building my bastard pack. Will starting on the bastard pack tonight and will probably have it all done friday. I work throughout the day so evenings are the only time I have to turn wrenches...bummer.
Ill keep everyone posted
CACTUS_JACK
post #10 of 22 Old 11-11-2010, 02:18 PM Thread Starter
cactus_jack
Joined the death wobble club today......sooo...instead of installing my bastard packs this weekend like I had planned, I will be diagnosing the source of the DW.
It was extremely violent too....so I'm sure something had to have broken or cracked because it happened 3 times on a 20 mile trip going 60mph.
Sucks because I was about to go spend my money on new wheels and tires but it seems now I'll have to ensure my Jeep is safe instead of off-road capable, lol
CACTUS_JACK
post #11 of 22 Old 11-21-2010, 03:31 PM Thread Starter
cactus_jack
worked a bit on the rear bastard packs today after letting the nuts and bolts soak in some pb blaster. almost got the driver's side done but ran into some issues. The upper bolts that hold the shock on both snapped off inside the hole....soo...ive already broken 2 easy outs. Looks like I might have to drill and re-tap them.
Painted each leaf from the S10 with rustoleum and got them ready to stack. Had to grind the spring clips off with a cut off wheel. Should have the whole thing finished by the end of this week
CACTUS_JACK
post #12 of 22 Old 11-22-2010, 02:52 PM
yellow_xj
I have tried the drill and tap and they stripped out. I ended up removing the nuts from the cross member they are tack welded in like 4 spots I used a hammer drill set on hammer and punched them right out dropped bolts through which was a PITA but there solid and I know my shocks arent going pull off the body again. Also when you measure to see how much lift you gained try measuring from the center of the hub to the bottom of the fender flair front stock is 17.5 and rear is 17 inches.
01,4.0 W/Upgraded Injectors & Bored Throttle Body,AW4,NP231,D30 W/RC CA Drop,C8.25 W/Aussie Locker & Junkyard Disc Conversion,6" lift on 33X12.5X15.
Yellow Jeep Club member # 16
Jeeps dont die they get rebuilt bigger and stronger, like the 6 million dollar man!
yellow_xj is offline
post #13 of 22 Old 11-23-2010, 02:21 PM Thread Starter
cactus_jack
yea, i seen that in someone else's build thread after I took the measurements and did the front end lol. At least I'll have a good measurement for the rear when Im finished
CACTUS_JACK
post #14 of 22 Old 11-28-2010, 01:56 AM
tizzdizz
tizzdizz's Avatar
2003 WJ
I've driven with it disconnected between trails and didn't like it. I mean, why take a chance? You can modify your stock end links to be quick disconnects for $5 worth of parts at the hardware store. This is what I did.
I'd also be worried that if there were ever an accident and the insurance company saw that my front swaybar had been removed, I might have no coverage or a lawsuit on my hands.
Did you figure out your death wobble yet? Might start by checking out your control arm bushings and ball joints. Good luck!
, 4" Zone, 265/75/16 Duratracs, Addco rear swaybar
r: Stock with 31s and a trim. Sold
: 2" on 31s with armor and dents. Sold
74 Nova - 2" drop and disc conv. Sold.
tizzdizz is offline
post #15 of 22 Old 11-28-2010, 06:37 AM Thread Starter
cactus_jack
yea, i drove with it disconnected for a couple of days....did not like it at all. So I went ahead and bought new links and put them on. I work at NAPA so they were too expensive. Ive got a good idea in my head for some poor-boy discos so hopefully I will get them on soon.
havent i figured out the DW yet. Im working on my bastard packs right now so I have the rear end on jack stand right now. Im goin to look at the front end soon as im done
CACTUS_JACK
My 98 build thread......... come on in! CHAMPTEK XJ Cherokee Technical Forum 20 01-24-2012 01:45 PM
My build thread. My attempt on a SAFE build on a budget. xyimmyx XJ Cherokee Technical Forum 46 06-09-2011 02:50 PM
01 XJ Build Thread NotDirtyEnough XJ/MJ Cherokee Non-Technical Forum 18 05-22-2010 03:16 PM
My build Thread.. miniderblank XJ Cherokee Technical Forum 24 02-28-2010 10:30 PM
My little build thread Big4banger XJ Cherokee Technical Forum 5 09-16-2009 08:38 PM
