Buying Advice Needed - JeepForum.com
post #1 of 16 Old 07-05-2013, 01:27 PM Thread Starter
helmetface
Alright guys, I've been scoping out XJ's for a while now as a new DD(something I can beat on-love that straight6 and that will handle well in the wintertime) Would have loved to find a 5spd, but alas they are so few and far between..
That being said, I've narrowed it down to two locals:
2000 XJ with 83k, auto - Good Condition, asking $4300
No modifications
1992 XJ with 200k, auto - Decent Condition(needs one rocker replaced), asking $2800
4" Lift, Tuff Country sx6000 shocks, 4 Leaf Springs suspension & 1 inch shackles
Here's the catch though, I'd like to do a modest lift, something in the area of 3-4.5" which the older XJ already has. The 2000 XJ is a bit more than I am willing to spend right now, and I don't think I can talk him down to my budget at this time. So, I know that already narrows down this "one of two" to a "one of one" situation..What I'm more concerned about is making sure the lift was done "properly"?
I'm great with cars/mechanics, however I have 0 experience with lift kits. I am not concerned with the work involved, just wanting to be sure I don't increase the wear on my suspension/tires and obviously I don't want the "death rattle"
That being said, what do I need to inquire about with this lift kit to understand what I am getting in to completely?
Do all lifts require and SYE kit?(remember it's 4")
What else can I inspect to ensure the Jeep's geometry has not been compromised? I'm used to race car alignments on cars barely 4" from the ground let alone something lifted that much more haha
Thanks in Advance, very much so looking forward to joining this community and starting yet another money pit in my life
helmetface is offline
post #2 of 16 Old 07-05-2013, 05:56 PM Thread Starter
helmetface
Hey guys the 2000 is down to 3k and I'm wanting to jump on it.
I asked the buyer about leekage and what not and his words were "it's got a little rear main seepage like all jeeps do"
Can anyone verify/comment on this??
Thanks!
post #3 of 16 Old 07-05-2013, 06:15 PM
Motorcharge
Rear main seal is a pretty common issue. Fairly easy to fix since you don't need to remove the trans.
If it's clean I'd pick it up. I still see 00-01 XJs with under 100k on em at big dealerships for $8-10k around here and they don't sit on the lot long at all. We had a 2001 at my dealership a couple months back with like 65k on it. It was fairly clean but not showroom quality. It sat on our lot less than 6 hours before someone shelled out $13k for it.
I'd stick with stock if you're using it as a DD. Not all XJs will require an SYE. Over 3" a lot will, some won't, just depends on the Jeep. 97+ tend to need them more than older XJs do.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #4 of 16 Old 07-05-2013, 07:07 PM Thread Starter
helmetface
Hey motor thanks for the feedback!
I'm really super-excited to add the 4.0 to my engine forte'
Anyhow, 3k for thishdefinitely seems like a great buy. I going Sunday to really tear into it.
Two more questions for you or anyone:
This 2000 has a homemade intake. He did it very clean, however I curious do aftermarket intakes without some sort of tuning cause these 4.0's to run lean? Or other issues?
Lastly, can anyone recommend a cheap lift kit? I'd like to stat between 3-4.5" and this is more for looks than it is off road duty. I'm just looking for clearance and a beefier look.
post #5 of 16 Old 07-05-2013, 07:32 PM
Motorcharge
Shouldnt be any issue with the intake. 4.0s arent picky about much but spark plugs.
Cheap and lift rarely mix. Search, there are thousands of threads out there on it already. For looks and a DD Id stay 3" or under, cheaper and you have to upgrade less stuff outside kits.
|SOLD|
| June 2015 COTM |
post #6 of 16 Old 07-05-2013, 07:37 PM
austin6137
1990 XJ Cherokee
I personally would go for the older one, but that's just cause of the 0331 head that the 2000 most likely has. But I do like the newer interior
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #7 of 16 Old 07-05-2013, 07:58 PM
Motorcharge
All 00-01 XJs have them, not a big deal. Just watch your temps and dont run overheated. Passing a good deal on a 00-01 over it is outright stupid and due to ignorance based on forum hype. Even if it cracks its a pretty easy and cheap fix. Also sort of a blessing because you can pickup mint ones with bad heads cheap and have a good DD out of it or flip it for not much work or cash.
|SOLD|
| June 2015 COTM |
post #8 of 16 Old 07-05-2013, 09:08 PM
JeepAbout
If its a "cold air" intake I would suggest going to a junkyard and getting the old air box. I made the mistake of having one in my XJ for 8 years! I have read on countless forums about people saying its garbage. I've since replaced my intake with the stock box and I've noticed the Jeep idles and runs smoother. Low end torque is more evident and it isn't so loud. Cold air intakes and throttle body spacers are garbage. Just garbage.
JeepAbout is offline
post #9 of 16 Old 07-05-2013, 09:45 PM Thread Starter
helmetface
Thanks to everyone.
I'm lookkmg at the Rough country kits..those seem pretty complete.
From my understanding, I could install the 4.5" kit and if I don't have vibes I could be okay without an SYE?
post #10 of 16 Old 07-05-2013, 09:47 PM
austin6137
1990 XJ Cherokee
Buy the rough country kit, dont believe the negative hype on the forum there great for the money
post #11 of 16 Old 07-05-2013, 09:58 PM
Motorcharge
Depends on the intake. Yeah, cone filters in the engine bay are pointless and you're sucking in hot air from the engine bay. The same setup run from the cowl is totally different and beneficial.
|SOLD|
| June 2015 COTM |
post #12 of 16 Old 07-06-2013, 10:20 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I would go with the 2000 since it is stock you can build it how you want. Also Tuff Country is a bottom feeder lift kit they ride rough and don't perform well offroad ( MY 99 Had a Tuff country lift the PO installed) I have since replaced it with Rubicon Express Springs and Teraflex Adjustable upper and lower control arms with Bilstein shocks it rides and performs much better
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #13 of 16 Old 07-07-2013, 02:39 PM
96xjKing
I would go with the rough country, I've got a rough country 3" on my 96 xj with 31's and absolutely love it despite the front tires rubbing the LCA's in sharp turns
96xjKing is offline
post #14 of 16 Old 07-07-2013, 02:43 PM
Tom95YJ
Tom95YJ's Avatar
Adjust the steering stops or get wheels with better back spacing. My 33's don't rub on my RE lift
Sent from AutoGuide.com App
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #15 of 16 Old 07-07-2013, 02:50 PM
96xjKing
I appreciate the advice, I'm already planning on adjusting the steering stops I just haven't had time lately to get around to it
96xjKing is offline
