Brian's '01 XJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Brian's '01 XJ
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaSave 17.76% for the 4th of july with ruffstuff specialties
Unread 12-07-2014, 07:40 PM   #1
4playSC
Brian's '01 XJ
Picked this up a few days ago.
I paid scrap price for it ($350.00).
The exhaust was missing and it needed a map sensor. Also needs tires.
LOL, and stand in line if you are wanting to offer me my money back
btw, is this a BB?
13 Chevy Tahoe, 4work
00 Chevy 2500, 4hauling
93 Tack-Kick, 4play
01 XJ, 4futureplay
4playSC is offline   Reply With Quote Quick reply to this message
Unread 12-07-2014, 08:05 PM   #2
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Welcome to the forum Brian. I don't think you can go wrong at that price.
The coil spacer in your picture does indeed fall into the category of budget boost. What's lifting the rear to match?
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
COTY 2009
Win a free premium membership HERE.
chris87xj is online now   Reply With Quote Quick reply to this message
Unread 12-07-2014, 08:14 PM   #3
VegasGT
Rustler of Jimmies
VegasGT's Avatar
Looks like 2" pucks up front and very large shackles out back.
Looks like a solid rig though, anything that runs and drives for $350 is a deal haha.
- '99 XJ Sport -
Lifted, Locked, Stiffened
July '13 and '14 COTM
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 12-07-2014, 08:15 PM   #4
4playSC
I haven't looked close at the rear. The leafs seem almost flat but I really haven't paid enough attention. There are other issues that are more pressing I have been trying to focus on. Dang work interfering with playing with my new ride.
93 Tack-Kick, 4play
01 XJ, 4futureplay
Unread 12-14-2014, 04:09 PM   #5
4playSC
Correct. That is 2" pucks and longer shackles.
Well, I bought an exhaust system off an XJ someone was parting out. Mine had no cat or muffler. Now to install it ...
Also got a CB put in. good times.
93 Tack-Kick, 4play
01 XJ, 4futureplay
Unread 12-17-2014, 06:09 PM   #6
4playSC
this thing has some very dark tinted windows.
my wife thinks a decal like this is appropriate:
93 Tack-Kick, 4play
01 XJ, 4futureplay
Unread 12-19-2014, 06:30 AM   #7
4playSC
Got an exhaust system installed A friend gave me a set of 33s (only about 25% tread, but free).
Now to figure out why it won't run smooth. One of the O2 sensors has spliced and extended wiring with various mixed up wire colors on the plug - not the same as the on the harness, not sure it is wired properly. I found a diagram so maybe that should help there.
Also picked up a "new" throttle body and some sensors at a pull your part lot.
Wish me luck.
93 Tack-Kick, 4play
01 XJ, 4futureplay
Unread 12-19-2014, 04:28 PM   #8
4playSC
Got the "new" throttle body and sensors installed. Also installed new spark plugs. Runs a lot better.
Still has a slight miss while at idle. A lot more noticeable while driving. Tried rewiring the mixed up/spliced wires to the front downstream O2 sensor; I think it's still wrong. Only had a small amount of time to work on it after work today before I had to give up. Maybe tomorrow will bring better luck.
I did score a free set of lift arms for the rear gate. The current ones are replacements. They hold things up but are too short.
93 Tack-Kick, 4play
01 XJ, 4futureplay
Unread 12-20-2014, 12:41 PM   #9
WhammyXJ
Nice XJ.
======o00o.
/__||_l__l,\___\,___
l_--\__\__l_---[]llllll[]
_(o))_____(o))--o-))
WhammyXJ is offline   Reply With Quote Quick reply to this message
Unread 03-03-2015, 03:38 PM   #10
4playSC
Got rid of the 235 racing slicks and put on some old 31s I had.
Also, I ordered a Spartan locker for the front.
93 Tack-Kick, 4play
01 XJ, 4futureplay
Unread 03-03-2015, 04:27 PM   #11
rstantoniii
Looking good, any plans to lift it more or replace the rear leaf springs?
rstantoniii is offline   Reply With Quote Quick reply to this message
Unread 03-03-2015, 04:53 PM   #12
4playSC
Maybe later on the lift or springs. I have a front locker ordered. Next is a winch bumper, then a rear bumper. After that, I'm thinking wheels that will let me run 33s. I tried 33s with the wheels I have but they rub the leafs. Need to push thing out a bit. The 33s also confirmed that the D/S shock is definitely shot. That side sagged such that the 33 barely cleared, the P/S sat much better. So, yeah, throw some shocks on the list somewhere in there. $$$$$$$ is the only thing slowing me down.
Oh, also, the timing belt broke yesterday on my Tackick. So that needs $$ too.
93 Tack-Kick, 4play
01 XJ, 4futureplay
Unread 03-03-2015, 04:54 PM   #13
rstantoniii
Shocks have nothing to do with anything sagging. If the D/S is lower it's probably a worn out spring.
Unread 03-03-2015, 05:35 PM   #14
4playSC
Maybe sag is the partially a bad description. The D/S did seem to sit lower compared to the P/S when the 33s were on. With any size tire, I have noticed that when I hit a bump I hear a "thump" that reminds me of noises previously heard in cars with struts and no leafs, when the struts were bad.
With the 33s, when I turned right, body roll (I don't have a front sway bar) would cause the D/S to scrub at the back side of the wheel opening. The tire would also scrub on bad bumps in the road.
Not trying to say leafs aren't bad, but from prior experience I'm sure the shocks are bad. LOL, with my luck, probably both.
93 Tack-Kick, 4play
01 XJ, 4futureplay
Unread 03-03-2015, 07:48 PM   #15
FairlanePhil
That's 50x nicer that the ****pile I just spent $1400 on. I'm $400 in and it's still not road worthy
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline   Reply With Quote Quick reply to this message
