brendan127's Wrecked '98 Jeep Cherokee is Back - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > brendan127's Wrecked '98 Jeep Cherokee is Back
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 03-03-2013, 07:59 AM   #16
thenewguy79
Sounds like most of your problems could be fixed by a quick trip to a junkyard. And I think you might need a new thermostat.
thenewguy79 is offline   Reply With Quote Quick reply to this message
Unread 03-03-2013, 08:23 AM   #17
brendan127
Found out it has a new thermostat last night.
brendan127 is offline   Reply With Quote Quick reply to this message
Unread 03-03-2013, 08:51 AM   #18
cbenez1
Check the plug going into the thermostat housing on the front of the engine. May be broken or loose from the accident or the repair. Could also be the temp sensor. After a hit up front you might be chasing a few issues like that as you start to drive it again. It's worth it rather than a car payment though. Nice to see another XJ saved from the yard.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline   Reply With Quote Quick reply to this message
Unread 03-03-2013, 09:05 AM   #19
brendan127
My friend thinks maybe its the sensor we're not sure, I'll have to mess with it.
Unread 03-04-2013, 09:31 AM   #20
brendan127
Found out that it was the coolant temperature sensor for the sending unit. Replaced it and everything is back to normal. Now I just have to deal with all that noise the belt is making.
Unread 03-04-2013, 05:56 PM   #21
brendan127
Here's some pics.
