BPE shock extentions - JeepForum.com
post #1 of 9 Old 07-29-2011, 01:53 PM Thread Starter
BlakeDGKleavitt
1997 XJ Cherokee
What are these. Any body use these if ya put up pics
BlakeDGKleavitt is offline
post #2 of 9 Old 07-29-2011, 06:01 PM
lilnapsak
1997 XJ Cherokee
they do extend the shocks a little.. the main purpose of them is right in the name "bar pin ELIMINATOR". its a mount that lets you get rid of the stock style bar pins that hold the shock up that cause a lot of problems for people
lilnapsak is offline
post #3 of 9 Old 07-29-2011, 06:08 PM Thread Starter
BlakeDGKleavitt
1997 XJ Cherokee
Okay thanks lol I didn't even know what BPE stood for. So they're good?
post #4 of 9 Old 07-29-2011, 08:51 PM
GregB_00XJ
Yes...
lower front
Upper rear
Teraflex brand... work great. Used new upper rear bolts and welded in the BPE to the body. Never break a bolt again. The bar pins are a bit of a pain, and can make a bit of noise. They add about 1/2-3/4 of an inch of length. Detours makes longer ones in various sizes, but you are better off getting the correct length shocks.
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #5 of 9 Old 07-29-2011, 09:28 PM
lilnapsak
1997 XJ Cherokee
they arent really needed but they make changing shocks a hell of alot easier and reduce noise. i have them in the rear of my jeep, my front never gave me an issue.
post #6 of 9 Old 08-01-2011, 11:07 AM
XJH-007
XJH-007's Avatar
I've used them in the past to fine tune my suspension, shocks that needed a little less compression and/or a little more length.
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #7 of 9 Old 08-01-2011, 09:03 PM
cdawall
1994 XJ Cherokee
using the stock rear sway bar mounts as a BPE on the rear works great and is a slight extension. i never really saw a need to do the front plenty of bar pin shocks available for the front.
edit: here are mine
Wheeler '05 Ranger Edge SAS'd, 5.38's, D60/D60u, 38.5s
Family SUV '94 XJ 3.55's, D30/35, 315/75R16's
cdawall is offline
post #8 of 9 Old 08-01-2011, 11:38 PM
MCObray
Anyone using these on 2-3" of lift?
1994 Dodge Ram 2500. 12V Cummins Turbo Diesel.
MCObray is offline
post #9 of 9 Old 08-02-2011, 10:43 AM Thread Starter
BlakeDGKleavitt
1997 XJ Cherokee
I'm getting a 3" lift and it says it comes with BPEs so that s why I asked
