Boxosaurus build... - Page 90 - JeepForum.com
post #1336 of 1688 Old 08-18-2013, 06:56 AM
tyvanwie
How big of spacers are you talking? It effects more than just the control arms.
tyvanwie is offline
post #1337 of 1688 Old 08-18-2013, 09:17 AM Thread Starter
MattBillyTayloe
Ones that will give me an inch. orielleys has them. My track bar is new and good up to 4.5"
MattBillyTayloe is offline
post #1338 of 1688 Old 08-18-2013, 09:19 AM Thread Starter
MattBillyTayloe
Originally Posted by JeepCollector91
Unless you or someone else installed an inline fuel filter on your XJ, you just changed the fuel filter when you changed your fuel pump as it is built in to the sending unit. As for the misfire, are you getting any codes? Could be any number of things. TPS, Temp Sensor, O2 sensors, Bad/Dirty Injector, Bad Coil, (can't remember if you have the distributorless ignition on that '99), exhaust leak before oxygen sensor causing it to get a bad reading and throwing off the mix.
Not sure if an oxygen sensor is sensitive to welding but that may be something to look into being that you just had the exhaust welded???
I have a distributor, I'm going to check on some things today, see of I can't get it running right
post #1339 of 1688 Old 08-18-2013, 09:33 AM
tyvanwie
Eh. Are you just doing it to level it?
tyvanwie is offline
post #1340 of 1688 Old 08-18-2013, 09:52 AM Thread Starter
MattBillyTayloe
Yeah for the most part, when I re did the rear it ended up higher than my front, and I know for a fact those spacers will give me enough to level it, you can kind of see. The rear is at 4.5 pretty much
post #1341 of 1688 Old 08-18-2013, 09:59 AM
tyvanwie
Put trail spares and tools and I bet it'll be level. Do you have a full size spare?
I wouldn't worry about it being level. You may end up with more issues than you'd like. You have the same front end as me, and I wouldn't add a spacer on top of 3.5"(?) springs. That's adjustable arm range. Not to mention longer swaybar links and shocks.
tyvanwie is offline
post #1342 of 1688 Old 08-18-2013, 10:05 AM Thread Starter
MattBillyTayloe
Shocks will be fine and I have away at drop brackets, not sure yet, I have a spare, just don't have a rim for it
post #1343 of 1688 Old 08-18-2013, 10:09 AM
tyvanwie
Honestly, I'd go ahead and get adjustable arms first. It'l be a great upgrade. Then if you do add a spacer you'll be okay.
tyvanwie is offline
post #1344 of 1688 Old 08-18-2013, 10:17 AM Thread Starter
MattBillyTayloe
**** that, I'm not doing anything with my arms until I get las. My shorties will do fine. It's basically a lot of money for little gain
post #1345 of 1688 Old 08-18-2013, 10:51 AM
tyvanwie
And long arms won't do anything unless you get longer shocks
tyvanwie is offline
post #1346 of 1688 Old 08-18-2013, 10:51 AM
AmmitOsiris
AmmitOsiris's Avatar
Lolololol
AmmitOsiris is offline
post #1347 of 1688 Old 08-18-2013, 10:58 AM Thread Starter
MattBillyTayloe
Well duh
post #1348 of 1688 Old 08-18-2013, 05:30 PM Thread Starter
MattBillyTayloe
Checked my compression and they all read good.
Might run sea foam through it, not sure how that goes but eh.
post #1349 of 1688 Old 08-18-2013, 05:45 PM
AmmitOsiris
Sea foam.. Call me and I can walk you through it
post #1350 of 1688 Old 08-18-2013, 06:18 PM Thread Starter
MattBillyTayloe
Pour it into the intake slowly, while running,
Let it sit 5 Minutes, start it and hope it
Runs lolz
Closed Thread
thisthreadsucks
