Boxosaurus build... - Page 56 - JeepForum.com
post #826 of 1688 Old 03-02-2013, 12:19 PM Thread Starter
MattBillyTayloe
Originally Posted by ibjeepin95
Take your shock out, fully extend it, measure how much shaft is showing. No homo.
:tehehe:
MattBillyTayloe is offline
post #827 of 1688 Old 03-02-2013, 12:20 PM
ibjeepin95
Originally Posted by straightsixjeep View Post
With shock fully extended, measure from eyelet to eyelet, then compress the shock and do the same thing.
This works too. These are the numbers you should use to set up mounts.
ibjeepin95 is offline
post #828 of 1688 Old 03-02-2013, 12:22 PM Thread Starter
MattBillyTayloe
Are we talking te mounts in te axle
post #829 of 1688 Old 03-02-2013, 12:28 PM
ibjeepin95
Let me rephrase that. Measure your mounts on your Jeep at full droop and full bump. Then look at fully extended and fully collapsed measurements when looking for shocks.
post #830 of 1688 Old 03-02-2013, 12:31 PM
tyvanwie
Im trying to figure out how much bump stopping I need. I flexed on an rti ramp but my suspension was at full flex before the tires were rubbing. Im thinking its the shocks bottoming out. They are 2012 jk rubi shocks which should have enough travel.
Yeah you don't want your shocks bottoming out...you bumpstop until the shocks almost collapse.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #831 of 1688 Old 03-02-2013, 12:37 PM
straightsixjeep
Im trying to think what all was holding me back, It has to be the shocks bottoming out. Im at 3.5in of lift with 31x10.5c15's. I trimmed the fenders and the front inner fender seam. I drove up the rti ramp until one rear wheel came off the ground, or until I was at full flex. The tire that was stuffed up front had more room to go so If I were to add extended bump stops up front It would be to keep the shock from bottoming out, further decreasing my flex.
My shock specs are:
The rear are about 23.25" extended, 15" collapsed.
The front are about 22.75" extended, 14.75" collapsed.
I most likely have to pull a coil and jack up the axle to see how much bump stopping I need.
straightsixjeep is offline
post #832 of 1688 Old 03-02-2013, 04:50 PM
Luke95
I haven't bottom end em out and have yet to but am soon
Sent from under my broken Heep
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #833 of 1688 Old 03-02-2013, 08:41 PM Thread Starter
MattBillyTayloe
I has mono
post #834 of 1688 Old 03-03-2013, 12:33 AM
straightsixjeep
sorry bro
post #835 of 1688 Old 03-03-2013, 07:08 AM
Luke95
I has mono
Explains why you felt like **** for so ****in long
Luke95 is offline
post #836 of 1688 Old 03-03-2013, 01:25 PM Thread Starter
MattBillyTayloe
sorry bro
This. Thanks guys lol,
Also, looking into new shocks and bushings for xj, and need to do something about ****ty stock steering
post #837 of 1688 Old 03-03-2013, 01:33 PM
Luke95
Rancho 7000 are good. 9000 amazing and bilstien amazing.
Steering is eh...how much you wanna spend?
Luke95 is offline
post #838 of 1688 Old 03-03-2013, 01:36 PM Thread Starter
MattBillyTayloe
I don't wanna break the bank on shocks. Bilsteins are cool, just spensive,
No clue
post #839 of 1688 Old 03-03-2013, 01:45 PM
Luke95
No clue
1 ton under the knuckle is $275 from serious offroad
You could do the Monroe $100 mod.
$120 rc shocks
Ranchos
Bilstien $380
Luke95 is offline
post #840 of 1688 Old 03-03-2013, 02:17 PM Thread Starter
MattBillyTayloe
$120 rc shocks
Ranchos
Bilstien $380
Yer so smart
Closed Thread
thisthreadsucks
