Boxosaurus build... - Page 55 - JeepForum.com
post #811 of 1688 Old 03-02-2013, 12:50 PM
ibjeepin95
Originally Posted by Luke95 View Post
The shocks I have don't have the part that goes threw the top they have a standard bushing so I made some emiminators I have 7 or so inches down travel left 3 up.
Not in the rear. Mine are out right now for an up coming axle swap
Sent from under my broken Heep
So they are in the front? And it's the upper? Upper fronts do not have bar pins....
ibjeepin95 is offline
post #812 of 1688 Old 03-02-2013, 12:51 PM
Luke95
Yes that's correct
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #813 of 1688 Old 03-02-2013, 12:52 PM
ibjeepin95
Yes that's correct
Um, upper fronts don't use bar pins....
post #814 of 1688 Old 03-02-2013, 12:58 PM
straightsixjeep
What shock specs are you guys running with apx. 3in of lift?
straightsixjeep is offline
post #815 of 1688 Old 03-02-2013, 01:02 PM Thread Starter
MattBillyTayloe
Now he feels stupid, and I'm confused, because I haven't researched enough on shocks and suspension enough to know alot. But hey jack, can't I buy shock relocation brackets?
MattBillyTayloe is offline
post #816 of 1688 Old 03-02-2013, 01:04 PM Thread Starter
MattBillyTayloe
No one knows. Whatever came with the kit po installed
post #817 of 1688 Old 03-02-2013, 01:05 PM
straightsixjeep
Im trying to figure out how much bump stopping I need. I flexed on an rti ramp but my suspension was at full flex before the tires were rubbing. Im thinking its the shocks bottoming out. They are 2012 jk rubi shocks which should have enough travel.
post #818 of 1688 Old 03-02-2013, 01:05 PM
ibjeepin95
You can buy BPE's, which will move the mount some. But, the best thing to do is to just make your own mounts.
post #819 of 1688 Old 03-02-2013, 01:07 PM Thread Starter
MattBillyTayloe
More research I suppose
post #820 of 1688 Old 03-02-2013, 01:07 PM
Luke95
I know but dont know what to call em. They allow me to run shocks that would not work other wise, the kind with 2 bushings.
10 inch travel for me
Luke95 is offline
post #821 of 1688 Old 03-02-2013, 01:10 PM
ibjeepin95
Post a pic. I have no idea what you're talking about.
post #822 of 1688 Old 03-02-2013, 01:11 PM Thread Starter
MattBillyTayloe
Noob question of the day :
How do you know how much travel?
post #823 of 1688 Old 03-02-2013, 01:12 PM
straightsixjeep
My fronts have 10in of travel as well. Have you extended your bump stops?
post #824 of 1688 Old 03-02-2013, 01:17 PM
ibjeepin95
Take your shock out, fully extend it, measure how much shaft is showing. No homo.
post #825 of 1688 Old 03-02-2013, 01:18 PM
straightsixjeep
With shock fully extended, measure from eyelet to eyelet, then compress the shock and do the same thing.
Closed Thread
thisthreadsucks
