Boxosaurus build... - Page 53 - JeepForum.com
post #781 of 1688 Old 02-22-2013, 04:34 PM Thread Starter
MattBillyTayloe
Originally Posted by straightsixjeep
Your shock will be at full extension before the axle drops enough to clear the leaf spring pack. You can try to do it without. Report back your findings.
Being a smart ***? I will probably do it all your way, gunna empty a can of on blaster on it when I get home
MattBillyTayloe is offline
post #782 of 1688 Old 02-22-2013, 04:36 PM
straightsixjeep
Seriously, if you have some crazy long extension shocks you may not have to lol. Yes pb blaster is your friend. Watch those brake lines when your lowering the axle. You only need a few inches of clearance to get a pair of vise grips on the bottom of the center pin but when it comes time to remove the leaf springs you may need more room. Lower the axle a little more but dont let it yank on the rubber brake line. Double check where you put your jack stands, safety first. For real.
straightsixjeep is offline
post #783 of 1688 Old 02-22-2013, 04:37 PM Thread Starter
MattBillyTayloe
Seriously, if you have some crazy long extension shocks you may not have to lol. Yes pb blaster is your friend. Watch those break lines when your lowering the axle. You only need a few inches of clearance to get a pair of vise grips on the bottom of the center pin but when it comes time to remove the leaf springs you may need more room. Lower the axle a little more but dont let it yank on the rubber brake line. Double check where you put your jack stands, safety first. For real.
Where is the center pin? Is it the same considering I hve blocks? O'Neill check it all out when I get down there
post #784 of 1688 Old 02-22-2013, 04:40 PM
straightsixjeep
Block or not, you should have a center pin. Once you pull the wheel look at the metal plate where the u-bolt nuts are. In between the 4 bolts is the center pin. You will see a hole in the metal plate and the nut screwed onto the center pin bolt. The bolt goes in from the bottom and the nut is ontop. Just like that nut pops through the hole in the metal plate, the bottom of the center pin sit in axle perch hole. You will see it once you get in there.
post #785 of 1688 Old 02-22-2013, 04:43 PM Thread Starter
MattBillyTayloe
Thanks man, wanna on me your number inches I run into any sudden troubles? Haha
post #786 of 1688 Old 02-22-2013, 04:46 PM
straightsixjeep
Just message me on here I dont want you blowing up my phone hahaha. Either way, it would be faster to write on here than text. Im more descriptive on here to.
post #787 of 1688 Old 02-22-2013, 05:10 PM Thread Starter
MattBillyTayloe
Alright man
post #788 of 1688 Old 02-22-2013, 11:15 PM
8pitcher
8pitcher's Avatar
Plus he never answers texts haha
8pitcher is offline
post #789 of 1688 Old 02-23-2013, 03:09 AM
straightsixjeep
Just found out why I havnt gotten any texts in a week, inbox was full and the phone didnt tell me
post #790 of 1688 Old 02-23-2013, 08:32 AM
8pitcher
8pitcher's Avatar
Odd. I can't receive texts unless I'm talking on the phone.
8pitcher is offline
post #791 of 1688 Old 03-01-2013, 05:28 PM
Luke95
Hey how's the Kralwer going?
Sent from under my broken Heep
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #792 of 1688 Old 03-01-2013, 09:01 PM Thread Starter
MattBillyTayloe
Rattly
post #793 of 1688 Old 03-02-2013, 12:28 AM
KG8893
Rattly
Dem Cherokees are rattle buckets.
Sent from somewhere in Nevada
I'm not saying we should kill stupid people... Just get rid of all the warning labels...
If you find my comments to "infer" something, they don't. Go to hell.
Built Not Bought #666
KG8893 is offline
post #794 of 1688 Old 03-02-2013, 12:57 AM
straightsixjeep
Spray some penetrating oil on the ol night krawker.
post #795 of 1688 Old 03-02-2013, 07:38 AM Thread Starter
MattBillyTayloe
I need a bucket, to douce everything
Closed Thread
thisthreadsucks
