Bought a pair of wheel spacers, having buyers remorse need some imput - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Bought a pair of wheel spacers, having buyers remorse need some imput
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 01-22-2015, 07:57 PM   #1
bigjoe347
I put a pair of wheel spacers on the jeep and I think I went overkill on it and regret buying them in concern of the lugs. I went full bore with 2" for the wide stance which feels great on road but fear for breaking lugs off road.
Would like some input on the wheel spacers and would like some info on people who have had them and had issues or not, Leave me a comment on your opinion, all responses are appreciated.
- Bought 2" wheels spacers
- Fear for lugs breaking off roading
bigjoe347 is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 08:27 PM   #2
Tkahne88
what kind of spacers did you buy?
Ive got 2" spacers as well but mine are hubcentric and wheel centric. I am not worried much though because my wheel offset isn't much more than the average jeep with 15" wide tires. now if you have wide stance rims and spacers then I would begin to worry, or if the spacers aren't fit to the hub and rim.
97 TJ with some BIG wheels n stuff
Tkahne88 is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 08:42 PM   #3
Teej
Do you even Luke95?
Teej's Avatar
As long as you have proper thread engagement, you're not going to break them. They're just as strong, if not stronger than the stock hubs.
Teej's '01 XJ Build Thread
Instagram: @tj_chciuk
CoTM March 2014
Teej is offline   Reply With Quote Quick reply to this message
Unread 01-23-2015, 09:02 AM   #4
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Just make sure you torque them proper and check from time to time. Locktite is your friens and keep an eye on your unit bearings - they'll go before your lugs break in half.
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is online now   Reply With Quote Quick reply to this message
Unread 01-23-2015, 11:39 AM   #5
Teej
Do you even Luke95?
Teej's Avatar
I wouldn't loctite spacers because that can give inaccurate torque readings. As long as they're torqued around 90 ft-lbs, they'll be fine.
CoTM March 2014
Unread 01-23-2015, 11:50 AM   #6
JeepN4KC
JeepN4KC's Avatar
I see what you're saying - but I've had spacers on my WK for 30K+ miles. Torqued just under spec, locktite, check 'em about every tire rotation. Zero problems from any of them. DDing, wheelin, towing..........none of my lugs have snapped off.
~Mike~
My Build Thread WK
~RED WK CLUB #7~
Unread 01-23-2015, 12:05 PM   #7
Teej
Do you even Luke95?
Teej's Avatar
Same here but I go a bit over torque and with no loctite.
CoTM March 2014
Unread 01-23-2015, 11:15 PM   #8
bigjoe347
Thanks to all of you on reassuring my purchase. A lot of people are against them, I love the aggressive look, I love the feel of the jeep and have to do some mod on the bumper before next off road trip
