Blue Waffle Build Thread - Page 3 - JeepForum.com
post #31 of 382 Old 11-22-2013, 11:06 AM
VegasGT
1988 MJ Comanche
What do you really gain? Some say 30% strength is gained because of the reverse rotation of an HP, I call BS on that. The only other gain is the pinion is a slight bit higher, but again, who cares? Look at your 8.25 pinion. It eats a lot more rocks than your 30 pinion will see. At least mine does...
My buddy just got done building his TJ on 35's, stretch the rear, swapped in an 8.25, but left the LP30 because we couldn't find a real reason worth fixing the track bar bracket on an HP30 housing he had to swap in. Needless to say, he geared the LP30 4.88 and locked it.
X2 I woulda still bought my Aussie if I had an LP30, I dont see a big benefit to swap for an HP30 just to lock it. Realisticly if your gonna grenade anything in either 30 its gonna be those damn spider gears.
Plus its not like buying a locker is gonna set you back any, same thing no matter HP or LP, right?
Also, holy hell the 8.25 pinion takes a beating lol.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #32 of 382 Old 11-22-2013, 11:07 AM
Luke95
I'd do a hp swap. But that is after I grenaded to lp. I really only see it as a 15 percent increase. I have one factory and it has not popped but I haven't pushed it to hard.
I'm saying Aussie lock the front the. Call it a day.
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #33 of 382 Old 11-22-2013, 11:15 AM
VegasGT
1988 MJ Comanche
On this topic, you get much snow up there DNFJ? If so you wont wanna run an auto locker up front if thats your DD. Ive heard they are real sketch in snow on road, havent got any snow to test that firsthand yet. Its not my primary DD though so I was willing to take the tradeoff, selectable locker is a little too pricey for me.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #34 of 382 Old 11-22-2013, 12:15 PM Thread Starter
DNFJ
Depends on how the winter is, last year was pretty mild except for a storm or two that dumped 8" in like an hour. Because of Lake Erie being relatively close and the appalachians to our east, they tend to slow down storms and end up pounding us sometimes.
Given that the last two winters have been relatively mild, I wouldn't be surprised if this one sucked.
Personally I don't really care for autolockers in general, I like the thought of being able to control exactly how my wheels are going to react in a given situation.
Also absolutely staying with the 8.25 for the forseeable future. They're awesome.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #35 of 382 Old 11-22-2013, 01:56 PM
ibjeepin95
wut
ibjeepin95 is offline
post #36 of 382 Old 11-22-2013, 02:08 PM
VegasGT
1988 MJ Comanche
wut
15% assuming proper planetary alignment and sufficient blinker fluid levels. Its just science dont question it.
Edit: we as the bull**** brigade are here to clutter your declutter thread I think.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #37 of 382 Old 11-22-2013, 02:10 PM
Luke95
Originally Posted by ibjeepin95
wut
Strength over lp.
Luke95 is offline
post #38 of 382 Old 11-22-2013, 02:35 PM Thread Starter
DNFJ
It was more so I could keep track of what I've actually done without having to re-read everything.
So, mod ideas that aren't lockers?
Previous:
DNFJ is offline
post #39 of 382 Old 11-22-2013, 02:37 PM
VegasGT
1988 MJ Comanche
Could finally do the hack and tap so you can lose the TC drop.
- '88 MJ Pioneer -
Build In Progress
Daily/TowPig
VegasGT is offline
post #40 of 382 Old 11-22-2013, 02:41 PM Thread Starter
DNFJ
Part of me wants to swap a 242 in
Previous:
DNFJ is offline
post #41 of 382 Old 11-22-2013, 02:50 PM
Luke95
Why?
I had one in the 88 never used full time ever.
Luke95 is offline
post #42 of 382 Old 11-22-2013, 03:19 PM
ibjeepin95
Strength over lp.
Explain your reasoning. I want numbers.
post #43 of 382 Old 11-22-2013, 03:20 PM
ibjeepin95
It was more so I could keep track of what I've actually done without having to re-read everything. So, mod ideas that aren't lockers?
Gears. Skids.
post #44 of 382 Old 11-22-2013, 03:21 PM
ibjeepin95
For a DD, I can understand that reasoning. Though I'm not sure if the full time option likes lockers....
post #45 of 382 Old 11-22-2013, 03:37 PM
Luke95
No even with a LSD it blows.
My old Xj was LSD and it was jerky on the road in full time
http://www.jeepforum.com/forum/f9/hp...p-d30-1061276/ and good thread hp vs lp
Luke95 is offline
jeep , overbuilt , overland , rebuild , restore
