Blue Waffle Build Thread - Page 2 - JeepForum.com
post #16 of 382 Old 11-19-2013, 05:33 PM
Luke95
Shhhhhh.
Needs more wheeling pics.
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #17 of 382 Old 11-19-2013, 06:09 PM Thread Starter
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Originally Posted by Luke95 View Post
Shhhhhh.
I know, hopefully this local club works out.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #18 of 382 Old 11-22-2013, 05:48 AM Thread Starter
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
So now what do I buy?
Previous:
DNFJ is offline
post #19 of 382 Old 11-22-2013, 08:31 AM
Luke95
Lockers.
Luke95 is offline
post #20 of 382 Old 11-22-2013, 08:39 AM Thread Starter
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Lockers.
Yes because I obviously need to put lockers in my LP30.
Besides the fact that it is basically winter now.
Previous:
DNFJ is offline
post #21 of 382 Old 11-22-2013, 08:49 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
I have been thinking the same thing w/ my LP30.
Lock and gear it?
Swap it w/ a locked and geared HP30?
Thing is - I certainly wouldn't be first locked and geared LP30, so I almost lean towards going that route.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #22 of 382 Old 11-22-2013, 08:53 AM Thread Starter
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Lock and gear it?
I was more or less getting at the fact that it is now winter around here, meaning mods that can be done in a weekend at worst. Though swapping everything shouldn't take more than that, not a fiber in my being wants to lay on 20* gravel for 4 hours to swap in a HP30.
Previous:
DNFJ is offline
post #23 of 382 Old 11-22-2013, 09:17 AM
ibjeepin95
I think this thread needs a picture of an actual "blue waffle"...
ibjeepin95 is offline
post #24 of 382 Old 11-22-2013, 09:18 AM
ibjeepin95
Lock and gear it?
I honestly don't see the benefits of swapping an HP30 in.
post #25 of 382 Old 11-22-2013, 09:23 AM
Luke95
I do if you blow the lp but that is it.
**** it run it till you pop it then swap an hp or go bigger.
Luke95 is offline
post #26 of 382 Old 11-22-2013, 09:29 AM
JeepN4KC
JeepN4KC's Avatar
The weather has turned here too. I hear ya on wrenchin in the cold. Only advantage is you can't feel your knuckles when you bloody them.
Well, other than the leetle bit of clearance gained on the shaft, and I guess a better driveline angle...............in the end it would be a lot of work "just because" as it stands right now.
Oh BTW..........here ya go:
~Mike~
WK
XJ
JeepN4KC is offline
post #27 of 382 Old 11-22-2013, 09:46 AM Thread Starter
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Yes because I have unlimited funds and time if something happens to my front axle.
A valid point.
Why so?
I think not.
Previous:
DNFJ is offline
post #28 of 382 Old 11-22-2013, 11:23 AM
ibjeepin95
Why so?
What do you really gain? Some say 30% strength is gained because of the reverse rotation of an HP, I call BS on that. The only other gain is the pinion is a slight bit higher, but again, who cares? Look at your 8.25 pinion. It eats a lot more rocks than your 30 pinion will see. At least mine does...
My buddy just got done building his TJ on 35's, stretch the rear, swapped in an 8.25, but left the LP30 because we couldn't find a real reason worth fixing the track bar bracket on an HP30 housing he had to swap in. Needless to say, he geared the LP30 4.88 and locked it.
post #29 of 382 Old 11-22-2013, 11:24 AM
ibjeepin95
Wrong "blue waffles"
post #30 of 382 Old 11-22-2013, 11:47 AM
JeepN4KC
JeepN4KC's Avatar
Meh.............my pic is easier on the eyes............
~Mike~
WK
XJ
JeepN4KC is offline
jeep , overbuilt , overland , rebuild , restore
