Bit the dust -
Go Back > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Bit the dust
UCF Aluminum Trail Doors for Jeep JKUCF Jeep TJ Aluminum Trail DoorsUCF Full Roll-Cage for Jeep Wrangler TJ & LJ
Unread 11-03-2015, 04:31 PM   #1
Bit the dust
my 2000 xj sport is finally done. It overheated a few times in the past few months and after replacing thermostat and e-fan it was fine until it overheated again and now the motor sounds like a bunch of nuts and bolts spinning in a dryer. I'm sure it can be repaired but its 15 years old and has 207,000 miles......i decided to put it to rest. I bought a patriot which is nice but not as capable as the Cherokee but it suits my needs. I will be salvaging the Cherokee, I didnt put any aftermarket products on it except tires so not much to part out. Good bye cherokee
BALDSLUG is offline   Reply With Quote Quick reply to this message
Unread 11-03-2015, 04:35 PM   #2
1997 XJ Cherokee
Tell the forum about it so we can by parts off of it!
"This is why duct tape is only rated for <25mph fastening applications." -chris87xj
shooptube is offline   Reply With Quote Quick reply to this message
Unread 11-06-2015, 10:21 AM   #3
Put it up here. If the body's good someone will buy it and build it a new motor. Or tear it apart for pieces. One or the other.
Lifted, Locked, Stiffened
bluejunior is offline   Reply With Quote Quick reply to this message
Unread 11-06-2015, 07:51 PM   #4
Motorcharge's Avatar
1991 MJ Comanche
Excellent use of your third post in 5 years.
Motorcharge is offline   Reply With Quote Quick reply to this message
In order to be able to post messages on the forums, you must first register.
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. is not in any way associated with Jeep or the Chrysler Corp.
