biggn235's XJ Sport build II - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > biggn235's XJ Sport build II
Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri2007-2016 Jeep JKU 4" X-series suspension lift **dea
Unread 05-30-2012, 02:02 AM   #46
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
I took that picture before I got the track bar bracket on, but that is how it sits. It is pretty level, but the rear is just a little higher than the front so I'm going to go down a notch on my shackles to help level it out even more. Since the front springs are used they are nice and broke in, so when the rear springs break in too it should be just about perfect.
By far the easiest lift install I have ever done on a Jeep, things actually went really well. The track bar bolt lined up perfectly!
Amp'd 2014 JK - Build Thread
Past - 95YJ 99XJ 98XJ 05WK 94XJ
biggn235 is offline   Reply With Quote Quick reply to this message
Unread 05-30-2012, 02:03 AM   #47
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
Oh and I need to get an alignment, bad
Unread 05-30-2012, 02:07 AM   #48
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
AND my new JeepForum sticker came in the mail, it has been a pretty good day all around.
Unread 05-31-2012, 04:33 PM   #49
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
Got the new LCAs in, cut the old bolts out and have new grade 8s in place. Started working on the transfer case drop and broke one of the bolts so now I'll have to drill it out I guess, I don't know what else to do.
Unread 06-01-2012, 09:25 PM   #50
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
Finished drilling the old bolt out and re-tapped it. To get the other stud out we had to weld a piece of steel to it and hit it with a hammer. Got the 1" spacer on and took the Jeep to get pizza. Needs an alignment really bad but it drives!
Only thing left to do is get the rear brake line on and knock the broken upper shock bolts out to drop in my new ones.
Unread 06-02-2012, 08:55 AM   #51
my1979impala
build threads move so much faster when your jeep actually runs. lol
jeepforum.com/forum/f176/2000-tj-build-2269009
my1979impala is offline   Reply With Quote Quick reply to this message
Unread 06-05-2012, 12:08 PM   #52
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
Till you break a brake line haha
Finally got everything finished up, still need to get an alignment though.
Unread 06-05-2012, 12:09 PM   #53
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
Getting that stupid stud out.
Smacked the **** out of it with a hammer.
Unread 06-05-2012, 07:07 PM   #54
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
Got it aligned today
Drives MUCH better
Unread 06-05-2012, 07:08 PM   #55
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
And put the freshly painted front skid on, along with some 31" BFG KOs on Jeep steelies painted black
Result of a lot of work over the past week-
Unread 06-05-2012, 07:09 PM   #56
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
A little driveway stretches, ready to wheel!
Unread 06-06-2012, 07:22 PM   #57
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
Sold my stock wheels and tires today, they were on craigslist for less than a day. Took that money and put it towards a new set of Soft 8s, they should be here by Monday.
Also added school stickers!
Unread 06-08-2012, 05:22 PM   #58
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
Cragars came in today, getting them mounted tomorrow so I can give my roommate his wheels back.
And I'm rocking a JF sticker again
Unread 06-09-2012, 11:24 PM   #59
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
I usually like the clean look of XJs, but I figure if I end up not liking them I can just take them off.
Unread 06-09-2012, 11:25 PM   #60
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
I didn't notice how obvious my reflection was till I posted them.
