biggn235's XJ Sport build - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > biggn235's XJ Sport build
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAMP Research Powersteps - A Morris 4x4 Center Promotion
Unread 05-27-2011, 10:40 PM   #61
rugsucka
I wouldn't put money in my LP D30 - it's not conducive to lifting and is weaker than the HP D30 you likely have. I will be swapping in a HP D30 soon, but will not do it til I'm ready to go a bit higher, and am ready to upsize tires and put in an aussie type locker up front.
Hey - I found one of the snaps of me stuck after a rookie night run down a 'big boy' trail.
I'm stock on crap AT 225's, blown up left front Ujoint firmly planted on my belly after slipping into the ruts.
A couple brothers with some planks and jacks eventually got me out.
I was dumb. I wheeled alone (had company to walk out at least) I didn't know the trail, just it's existence. I also smashed the front window closing the hatch and banging the planks into it.
I think I'll call a bud and slay that trail tomorrow.
rugsucka is offline   Reply With Quote Quick reply to this message
Unread 05-28-2011, 12:30 AM   #62
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
The Dana 30 is more than enough for me right now, and yeah mine is high pinion. At this point in time the XJ is my DD for the foreseeable future and I don't plan on going any bigger than 31-32 inch tires for a long time. I already have a Dana 70 that I got for free so I can build that up over time and eventually find a nice axle for the front as well if I ever want to go crazy and make this XJ a trail beast when it is no longer on daily duty. Lockers aren't absolutely necessary for the moment so I'll have plenty of time to decide exactly which direction I want to take with them as far as selectable or not.
Amp'd 2014 JK - Build Thread
Past - 95YJ 99XJ 98XJ 05WK 94XJ
biggn235 is offline   Reply With Quote Quick reply to this message
Unread 05-28-2011, 09:14 PM   #63
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
I have good news
First- my JeepForum sticker and cards came in, pic kinda sucks but you know what it looks like.
But the real good news-
Thanks to Stephen I now have a temporary set of wheels and tires. Stock Jeep wheels painted flat black with the silver center caps installed, with a set of 31" BFG AT's. The Jeep looks SO MUCH BETTER! The tires are not true 31s and they are a little worn down, but they look and feel way better than the crap tires I had before and they are only going to be on there for a month or two. Thanks Stephen!
Unread 05-28-2011, 09:16 PM   #64
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
I'll try to get good pictures tomorrow, it is too dark outside right now. I'm planning on cleaning it up tomorrow too, at least the inside.
Unread 05-29-2011, 12:53 AM   #65
Isaac5108
Have you done a compression test yet?
Isaac5108
Isaac5108 is offline   Reply With Quote Quick reply to this message
Unread 05-29-2011, 01:11 AM   #66
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
I have not.
Unread 05-29-2011, 07:06 PM   #67
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
Better pictures.
I parked next to a stock XJ this morning at work.
When I got off this evening I gave the Jeep a bath, inside and out.
Also drilled in some self tapping screws to hold the brake hardline in its new location.
I WILL get that new steering stabilizer on this week.
Unread 05-30-2011, 12:44 AM   #68
Isaac5108
Originally Posted by biggn235
I have not.
It's always a good idea to do a compression test. Could have a sticky valve
Isaac5108
Unread 05-30-2011, 12:45 AM   #69
Isaac5108
Better pictures.
Save up your money and get 33s
Isaac5108
Unread 05-30-2011, 06:03 PM   #70
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
I have no motivation or way to do a compression test and I don't think that is the problem anyway.
I don't want 33s... I want 31s.
Unread 05-30-2011, 10:09 PM   #71
Isaac5108
A compression test would point you in the right direction. But hey what do I know?
Isaac5108
Unread 05-30-2011, 10:11 PM   #72
HartinArmz
1997 XJ Cherokee
Your XJ looks ten times better then when you initially bought it. Good stuff!
1997 Jeep Cherokee Sport 4 DR, C8.25, 4.0L, AW4
Build Thread: http://www.jeepforum.com/forum/f177/hartinarmz-1997-build-1170550/
1994 Ford Bronco Eddie Bauer, 5.8L, 2" lift, 33's
ASSIST-PROTECT-DEFEND
HartinArmz is offline   Reply With Quote Quick reply to this message
Unread 05-30-2011, 10:17 PM   #73
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
Thank you sir
It's come a long way in a short time and it doesn't have too much farther to go until it is my perfect year-round DD Jeep
Unread 05-30-2011, 10:59 PM   #74
Durt_Diver
Looks good just needs less backspacing imo
-Jacob-
lockers don't work unless you have Rubicon stickers
Durt_Diver is offline   Reply With Quote Quick reply to this message
Unread 05-31-2011, 04:36 PM   #75
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
Yeah I agree, but these wheels are just temporary until I can get a set of DuraTracs mounted on my Cragars. It won't be too much longer. The tires will be slightly bigger and the Cragars have 4" backspacing.
