Betty build thread XJ 2001 - JeepForum.com
post #1 of 22 Old 03-15-2013, 08:15 PM Thread Starter
FleXJeep37
So I guess im going to start my build thread. I been wanting to start one of these for a while now. So here it goes. Hope you guys like it.
The day I brought her home!
Painted Wheels Black
Steering Upgrade and New Steering Damper
Made My Own Discos
New Skyjacker 0-3inch Hydros - Drive Safe Yallz
3 Inch RC lift
Removed Corners and Cut Bumper - Also Cut and Fold Fenders
Drop Shackles 1-2 inches and 1.5 spacer. She now sits at 4.5 since the rear sags a bit and i set it at 2 inches on the shackles. Cant wait to get my 4.5 leafpack
Had to remove bumper and cut holes to make sure i soaked the nut and bolts through the inside so i wouldnt ruin the welded nut and be SOL!!
With My Buddies Shaggin Waggon
FleXJeep37 is offline
post #2 of 22 Old 03-15-2013, 08:23 PM
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
Looks good so far
April 2014 & 2015 COTM
MOBBiN is offline
post #3 of 22 Old 03-15-2013, 10:22 PM Thread Starter
FleXJeep37
Diff fluids and drum brake overhaul!
I recently cleaned and painted my Chrysler 8.25. I think it had a leak so I scraped the old gasket and now she looks all pretty. I had a leak from the wheel cylinder in the passenger side drum. No wonder I was loosing fluid and couldn't figure out where it was leaking from. When I removed the drum it looked like mud! New left side brake line. The old one broke when I was removing it from the wheel cylinder. Makes me feel safer knowing I have new shoes drums hardware and cylinders back there.
Now that I look at these pics I can tell I need to cut my u bolts down a bit so i dont mess anything up when I flex.
Working in the snow while I did this was not fun but it had to be done since the gargage was occupied.
post #4 of 22 Old 03-15-2013, 11:03 PM
Saul32
1988 FSJ Wagoneer
Betty is coming along. I remember the day you picked her up. Remember you were too ******* impatient to wait for me to come with and headed out to the ****ing dealers.. and ended up at the wrong one but when I saw you drive her up I was really impressed. I helped with the rear lift and pulled her *** outta a mud pit the size of a meteor crater a few months back. Its been fun so far. Can't wait to see whats next
Ps. Both our trucks need new TIRES n WHEELS... Agnes looks super lame with those 31's and Bettys 31's are bald!!!
Nothing important...
Saul32 is offline
post #5 of 22 Old 03-15-2013, 11:26 PM Thread Starter
FleXJeep37
33s for sure
Haha yeah. If it wasnt for you I wouldnt have betty! That day made me nervous winching out tied to my rear axel! Gotta get my hitch back on! Too funny when you winched out that Yukon tard with no spare and he blew out his tire! That day was fun! Cant wait to hit up BK tomorrow! Check out the craftsman I found behind the dumpster at work! Just needs a little TLC!!
post #6 of 22 Old 03-15-2013, 11:32 PM
Saul32
1988 FSJ Wagoneer
wtf?
That is a sweet Crafstman tool cart!!you lucky fcuk!!!!
Saul32 is offline
post #7 of 22 Old 03-15-2013, 11:37 PM Thread Starter
FleXJeep37
Wfm
They ball hard!! They got like 600 lbs of metal sitting there waiting to get scrapped! Metro Racks and all this other junk. I kinna wanted to take it but I couldnt fit anything else with the baby seat and tool cart already! We should go late at night and just take it all!
post #8 of 22 Old 03-15-2013, 11:45 PM Thread Starter
FleXJeep37
As she sits now!
She is so Purdy!!!
post #9 of 22 Old 03-16-2013, 12:53 AM
Saul32
1988 FSJ Wagoneer
**** late night. lets pick that **** up in the pickup tomorrow after youre done
Saul32 is offline
post #10 of 22 Old 03-16-2013, 05:16 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Nice looking XJ!
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #11 of 22 Old 03-16-2013, 04:06 PM Thread Starter
FleXJeep37
Originally Posted by phfister View Post
Nice looking XJ!
Thanks! She still has a long way to go!
post #12 of 22 Old 03-17-2013, 08:33 AM Thread Starter
FleXJeep37
Injector Swap
So I picked up some newer, cleaner injectors from the Pick and Pull a few months back and finally found some time to throw them on. Took about an hour with the help of the forum of course on how to do it. I noticed the difference right away! Better throttle response. Hopefully my misfires and CEL go away for good. The funny thing about the misfires is that it was really random. Sometimes it was one cylinder and sometimes three. When I pulled the old ones out they were full of grease and grime!
Im still gonna be on the hunt for Dodge Neon Injectors from the JY and swap those into my XJ when I get a chance and I'll post my results and try to post pictures as well. I'll probably do my valve cover gasket and paint it red in the process while I have the throttle body and cables out of the way.
post #13 of 22 Old 03-27-2013, 06:49 PM Thread Starter
FleXJeep37
Emissions Test
Took my Jeep to get the emissions testing and passed. I thought it was odd because I keep getting Misfire codes for random cylinder 1 to 3 at a time. I clear it with the DRBII whenever it does that. Spark Plugs??
Anyways I took my grandfathers 97 GC and it failed P0300 P0301 P0302.
They noted catalytic converter failed and 02 sensors. I looked up the codes and they are all Misfire codes. Are they wrong or am I just stoopid!?
post #14 of 22 Old 04-02-2013, 07:09 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Does it only do it when the engine is warm? If so, it's the notorious heat soak issue.
Previous:
DNFJ is offline
post #15 of 22 Old 04-04-2013, 11:53 AM Thread Starter
FleXJeep37
Ah Ha! That must be it. I did notice that the CEL will only come on after a day of running errands. Turning the car on and off must be the case. I remember now reading other threads about the heat soak but completely forgot about it after I fixed the CKP and ruled out all other issues.
Im going to wrap all my injectors and maybe the manifold to reduce temps.
Just another reason to spend time on her. There are so many mods for under hood temps. Where do I start?
Hood Spacer?
E Fan?
Wrap Injectors?
Wrap Manifold?
Hood Vents?
