Better, And Redder Build Thread. - Page 114 - JeepForum.com
post #1696 of 2292 Old 01-15-2014, 07:32 PM
egodfrey
egodfrey's Avatar
Get a locker you bum!
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #1697 of 2292 Old 01-15-2014, 09:11 PM
Teej
Originally Posted by Spokes View Post
Jeep is good to go now. Im still getting a clunking noise on bumps and when i go D to R to R to D. It sounds like the upper control arms are loose. I tighten the hell outta them today and it still does it the lower are tight. As are all the nuts on the arms. (ill double check them again) im wondering if the RC arms are worn out again It isnt the steering cause that is all new and tight, the trackbar is also nice and tight and no slop frame or axle end.
Not that I know anything, but couldn't the D to R and R to D clunk be motor mounts?
Instagram:
CoTM March 2014
CoTM May 2015
Teej is offline
post #1698 of 2292 Old 01-16-2014, 06:20 AM
DNFJ
Tranny mounts/bushings.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #1699 of 2292 Old 01-16-2014, 09:58 AM
No4x4Yet
Changed out my leaky axle seal today and rotated tires. Did em both since I was in there. Simple job just a lil time consuming cause ya gotta pull the whole axle apart lol Gonna order some of those outer axle seals. couldnt believe all the crap that was in the tubes.
You guys like my garage?
Dont drop any small nuts or bolts.
No4x4Yet is offline
post #1700 of 2292 Old 01-16-2014, 12:16 PM Thread Starter
Spokes
Erik in time lol and its not a motor mount its something with the axle cause u can feel the jeep shift and when u hit bumps
Red 00 XJ lifted
Build -->
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline
post #1701 of 2292 Old 01-16-2014, 12:38 PM
egodfrey
egodfrey's Avatar
Start with bushing and check if all the bolts are tight, id start with the trac bar and move to control arms.
egodfrey is offline
post #1702 of 2292 Old 01-16-2014, 03:42 PM
DNFJ
this
Previous:
DNFJ is offline
post #1703 of 2292 Old 01-16-2014, 07:19 PM
IDIdiesel
when you figure out that clunk let me know I get the same thing. Can feel it if im in R and tap the brakes on and off
2015 Ford F350 crew cab, gasser
2001 Cherokee sport "AGENT ORANGE"
1991 Ford 7.3L IDI- FOR SALE
IDIdiesel is offline
post #1704 of 2292 Old 01-16-2014, 10:32 PM Thread Starter
Spokes
Been there done that everything is tight. Think the arms are just worn out. I've replaced em 3 times
Originally Posted by DNFJ View Post
this
Will do
Red 00 XJ lifted
Build -->
Spokes is offline
post #1705 of 2292 Old 01-16-2014, 10:45 PM
Camfam07
I had same clunk, I ended up fixing it by tightening calipers, replaced the upper ca bushings with polys, tightened steering box and track bar + outer frame rail bolts on the mount, and noticed my sway bar mounts on the axle and under frame rail were loose, all these things done at once fixed it but I think it was the upper bushings that actually fixed it though. Just a few things I did too get mine fixed, same exact issue though, coming from d to r and r to d... I have a rotted out motor mount and no clunking currently, if his pop was like mine your can feel it on your feet, right above/near the upper ca frame bushing, after we did a thorough check and tighten every bolt it was gone! Just not sure which one actually fixed it. Also I know my dad's clunk was fringe the motor mount bolts that are notorious for coming loose, the ones the hold the mounts to the engine it's self, hope that made sense. Let me know of any of these helped. Thanks good luck
Camfam07 is offline
post #1706 of 2292 Old 01-16-2014, 10:48 PM
Camfam07
Also another one is shock mounts if your have front bpe's I have the jks and they came loose and would pop, that actually happens to me every few months it seems. Good luck!
Camfam07 is offline
post #1707 of 2292 Old 01-16-2014, 11:45 PM Thread Starter
Spokes
Will check over everything again but so far have checked all that. Thanks
Red 00 XJ lifted
Build -->
Spokes is offline
post #1708 of 2292 Old 01-17-2014, 06:26 AM
DNFJ
Grease all your bushings
et
Previous:
DNFJ is offline
post #1709 of 2292 Old 01-17-2014, 11:53 AM Thread Starter
Spokes
et
Always do every oil change. It's a very neglected jeep as I'm sure u can tell lol
Girlfriend got a call today from jcr checking in on how we liked the sliders. Thought it was nice and got some advice of how to prep them lil better too
Red 00 XJ lifted
Build -->
Spokes is offline
post #1710 of 2292 Old 01-19-2014, 02:20 PM Thread Starter
Spokes
Lower axle end bushings are worn out. So tired of Rc. Starting a new job this week so hopefully can get some new lift parts
Red 00 XJ lifted
Build -->
Spokes is offline
#3 Build thread 92 XJ Miller_TimeII XJ/MJ Cherokee Non-Technical Forum 7 02-06-2012 08:55 PM
My build thread. My attempt on a SAFE build on a budget. xyimmyx XJ Cherokee Technical Forum 46 06-09-2011 02:50 PM
CEN-CAL-XJS New Build Thread. CEN-CAL-XJS XJ Cherokee Technical Forum 8 01-17-2009 05:59 PM
My XJ build thread... oh and HI AFhockey31 XJ Cherokee Technical Forum 36 11-26-2008 07:00 AM
an 88 build thread camjeep3 XJ/MJ Cherokee Non-Technical Forum 2 06-08-2008 09:00 PM
