Best way to protect suspension components from rust and grime - JeepForum.com
post #1 of 7 Old 03-21-2011, 09:26 PM Thread Starter
thatswatshesaid
1992 XJ Cherokee
Ok so today I just realised the absolute best way to protect your suspension components and other parts of the underbody from rust and grime. Barrel Lube! Just order some or buy some from a gun dealer. Lots of it mind you. I'm going to try doing this every two weeks to see how it holds up and how easy it will be to wash mud and grime off. I know this stuff works amazing as we use it on giant solid steel components at my work and they never rust. The lube will still be on the parts six months later when we do maintenance. Don't use it in high friction areas or on threads mind you. But it does an amazing job if you're willing to put in the work. Just pour some on a thick wad of paper towels and wipe on the components you wish. (Keep away from skin and face unless you wanna look like you're going through puberty again lol.)
thatswatshesaid is offline
post #2 of 7 Old 03-21-2011, 10:55 PM
dcorn
I hear paint does a pretty good job, usually Rustoleum flat black
Or just keep it in the garage to keep rust away.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #3 of 7 Old 03-21-2011, 11:14 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
just move to the desert
1990JEEPXJ is offline
post #4 of 7 Old 03-22-2011, 12:47 AM
robsjeepxj
I do the black paint thing as well, not flat though.
robsjeepxj is offline
post #5 of 7 Old 03-22-2011, 03:15 AM
ReconMill
Flat-4 Turbo
ReconMill's Avatar
2005
The best protectant from rust is grime. Specifically, leaky fluids and grease.
Kyle - I mod stuff®
2005 Subaru Legacy GT
ReconMill is offline
post #6 of 7 Old 03-22-2011, 06:38 PM
jeeptorino68
1992 XJ Cherokee
engine oil leak
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline
post #7 of 7 Old 03-23-2011, 04:48 AM
dcorn
I'd recommend not worrying about a little rust and grime on the bottom of the Jeep. If you hit rocks, it's gonna happen. If you don't wheel it hard, just paint everything.
If you wanna oil half your engine bay and front suspension, I recommend overfilling the front diff so all the excess fluid comes spewing out the breather when you drive. God, what a mess...
dcorn is offline
rust prevention , suspension
Need Help Identifying Suspension Components UNHCLL XJ Cherokee Technical Forum 5 11-13-2010 06:30 PM
Questions About Suspension Components BeepBeepGoJeep XJ Cherokee Technical Forum 12 03-15-2010 09:23 PM
Painting suspension components, what to use? compcrasher86 XJ Cherokee Technical Forum 3 08-23-2009 06:10 PM
DPG Suspension components.... btfury XJ Cherokee Technical Forum 2 08-08-2007 09:49 PM
Suspension Components Ryan949 XJ Cherokee Technical Forum 3 08-07-2007 03:21 PM
