Battery or Starter - JeepForum.com
post #1 of 4 Old 01-20-2011, 02:15 PM Thread Starter
werff
1995 XJ Cherokee
Battery or Starter
Hey all. I have 1995 Cherokee 4.0. Havent had it too long so now all the quirky things are starting to happen. the latest is when trying to start it, there a few times when all you hear is a click. Try it again and it fires right off. Seems to be happening on a more regular basis. Been working a lot so I havent had any time to troubleshoot so I thought I would be lazy and ask my Jeep forum buddies....any ideas?
werff
werff is offline
post #2 of 4 Old 01-20-2011, 02:48 PM
T4STE
could be a lot of things to consider.
does your reverse lights work? if not it could be your neutral safety switch needs cleaning
could be your starter
could be your battery
check your fuses
could be the fuse for the fuel pump
do you hear your fuel pump priming when you put the key in the on position?
these things to check over. im sure people will chime in for more things to check
16 WK2 75th Anniversary-Lucille the Albino Rhino
96 XJ Sport-Rosemary the Perrywinkle People Eater
T4STE is offline
post #3 of 4 Old 01-20-2011, 03:14 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
NSS is my guess. Mine does the exact same thing. turn the key and get a click then nothing, then turn it try again and it will fire right up.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #4 of 4 Old 01-23-2011, 06:29 PM Thread Starter
werff
1995 XJ Cherokee
so...here's the deal. When I turn the key there is a loud click coming from the starter there and it is not turning over at all now. . Can the NSS cause this or has the starter gone out? I am going to replace the starter this week. if that isn't it...I will get the transmission flushed and at the same time have that stinkin' NSS serviced. I'll let you know what works. thanks for all the help.
werff
werff is offline
4.0 battery on, starter replaced no start orangekid XJ Cherokee Technical Forum 15 12-22-2009 06:05 PM
4.0 clicks when starting, new battery, new starter, new NSS HELP ME PLEASE x513x XJ Cherokee Technical Forum 5 02-08-2009 03:21 PM
not the alternator, battery, maybe starter swebilius75 XJ Cherokee Technical Forum 6 03-18-2006 07:36 AM
Battery and or Starter problems jeepcher4x4 XJ Cherokee Technical Forum 4 09-26-2005 08:53 PM
starter, battery, other? flarnlgso XJ Cherokee Technical Forum 11 06-01-2005 03:34 PM
