Backspacing Question - JeepForum.com
post #1 of 12 Old 12-03-2013, 07:29 AM Thread Starter
LiveforXJ
I know stock backspacing on a 1989 Jeep Cherokee is 5.25, I am in the market for some wheels with 3' backspacing. I want to get 15X12.50 rims, but I don't know if these will stick out to far? Any ideas?
LiveforXJ is offline
post #2 of 12 Old 12-03-2013, 11:45 AM
kevinofhardy
This can be figured out with a bit of math. The difference between 5.25 and 3 is 2.25. So it will automatically stick that much farther out. If you have stock rims they are probably 7 or 8 inches wide. Lets split the difference and do 7.5. Going to 12.5 inches the difference is 5 inches. Split that in half since the other half of that will be going under the fender. This leaves you with an additional 2.5 inches wider than stock. Add those up and you are 4.75 inches wider than stock at the outside edge of the wheel. Technically I do not guarantee these numbers, but that is what I would expect to see.
kevinofhardy is offline
post #3 of 12 Old 12-04-2013, 06:12 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
12.5" is pretty wide for an XJ rim. You might get better performance from a narrower size.
***Chris***
chris87xj is offline
post #4 of 12 Old 12-04-2013, 06:22 PM Thread Starter
LiveforXJ
I mean I had 12.50s on my old xj, but I just wanted to know if the 12.50 along with the 3' backspacing would just look dumb.
post #5 of 12 Old 12-04-2013, 06:50 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
12.5" rims on an XJ is probably more unusual than backspacing in the 3-4" range.
***Chris***
post #6 of 12 Old 12-04-2013, 07:15 PM
kevinofhardy
The question that I have is what size tire do you want to be running? That would be a pretty important factor in wheel width.
post #7 of 12 Old 12-04-2013, 07:21 PM Thread Starter
LiveforXJ
I want to run 33s. I had 12.50X15 rims with 33s but I wanted to backspace my rims so they would stick out further.
post #8 of 12 Old 12-04-2013, 07:22 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
XJ's aren't really conducive to tires much wider than 12".
***Chris***
post #9 of 12 Old 12-12-2013, 07:49 AM
AmbuGrl
AmbuGrl's Avatar
I ran 33 12.5 15 on my 98 XJ (DD) without any issues. Our wheels had 4in bs.
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #10 of 12 Old 12-12-2013, 01:17 PM
Maxxrus08
1992 XJ Cherokee
I have 33x12.50x15 KM2 on mine with a 3.75 bs. Rubbing on the passenger LCA when i go to full lock out. Going to add a 1/2" spacer. I like the wider stance look though.
1992 Jeep Cherokee Lerado 4x4
4.0L HO Auto Trans
RE 4.5" Superflex lift
33x12.25x15 BFG KM2
Maxxrus08 is offline
post #11 of 12 Old 12-14-2013, 01:01 AM
holysirsalad
Stock XJ rims are all 5.75" BS. I don't think you can really get a 12.5" wide tire on a 12" wide rim... 10" at the max
holysirsalad is offline
post #12 of 12 Old 12-14-2013, 07:59 AM
Xride
Stretched yo!
You can get the tire on, but why, a 12.5" mud/AT tire is made for like a 9" wide wheel. It'll look silly.
99 XJ, black, 4x4, NP231, 8.25 rear. Fully locked.
5.5" long arm lift, 35x12.5x15 Kumo KL71MT
Xride is offline
