Back and Building - Page 7 - JeepForum.com
post #91 of 140 Old 02-16-2014, 11:41 AM Thread Starter
Vassago
going to check out a possible donor motor tomorrow morning as my oil pressure is hardly within spec running 5w-40 rotella. It's out of 98 with 80k original on it. was a winter jeep for a guy and the unibody rusted out. he's asking 550 for it.
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD:
My Photography
Vassago is offline
post #92 of 140 Old 02-16-2014, 03:33 PM
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
And all that is wrong with yours is what? Low or high oil pressure? Mine was EXTREMELY low unless I kept the rpm's up to 1500, so I drove with 2 feet for a bit until I could fix it. A new oil pump and pickup did the trick. Not a bad job at all and you can take care of the rear main seal, oil pan gasket, and any other little oil leaks while you're at it.
koolaid5 is offline
post #93 of 140 Old 02-16-2014, 05:00 PM Thread Starter
Vassago
It's toast, only a matter of time, i want the peace of mind for long trips. 0331 head gremlin got me twice, my #2 and #4 cylinder walls are blackened and shiny too. i tolerated the low pressure after the first head swap. Also i have lots of lifter noise that i didn't have before. But now after my 45 minute work commute, the needle is dipping under the first line unless i tap the gas. I'm sure i could nurse mine and make it last a while, but i highly doubt it'll last through the summer temps with the trips i have planned. I race enduro mountain bikes so i have 6 hour trips to central VT and 1 to northern NH and 1 to southern NH, and I prefer to drive to GA to visit my dad so i can bring toys.
Besides, with my motor out, it might inspire me to build a stroker with it, i knwo no one with have any objection to that.
MY BUILD THREAD:
My Photography
Vassago is offline
post #94 of 140 Old 02-16-2014, 07:06 PM Thread Starter
Vassago
been trying to figure out a nice quiet exhaust since currently mine is broken and clogged cats and dumps before the axle with a FM44. I'm replacing header back.
then i came across this, it's on a 4 linked rig, but his shocks are mounted ho mine will be and his pinion is higher than the TJ44 i'll be running so i think I'll be okay. He's also running the stock tank skid as i do.
http://www.pirate4x4.com/forum/jeep-...l#post13270604
Edit: On second thought, i believe the JKS shock mount i'll be using is lower than that probably causing an issue. maybe i could go over it
MY BUILD THREAD:
My Photography
Vassago is offline
post #95 of 140 Old 02-21-2014, 08:07 AM Thread Starter
Vassago
the jeep has been dropped off the rear axle installed (really need to purchase a welder this season as that the only reason i'm not doing the install) i should have it back later tonight.
MY BUILD THREAD:
My Photography
Vassago is offline
post #96 of 140 Old 02-22-2014, 11:15 PM Thread Starter
Vassago
It's it, soooo smooth riding. Gotta button up a few things still.
Did some measuring, somehow I got more lift. I thought I might get 1/2" which I was okay with plans to add rear bumper and plating, but I got over an inch higher. I'm netting 6 1/4" over stock in the rear and it's really raked.
My old set up consisted on RE 3.5" full packs and 1" shackle, I sat just a hair over 4.5" after it settled. I swapped out the shackle for a slider box at stock height, and 1" UBE's with the same leaf pack.
Mike at Globex said that my leaf packs were pretty rusted together with the pin to the old turdy5 and that he had to reuse the shim because it wouldn't come off.
I'm thinking about removing that shim and the short leaf it's stuck too, I'm worried that will ride too soft though. It's that or new leaf packs or cut off the UBE's and either attempt to evenly shorten them, or replace them. Thoughts?
MY BUILD THREAD:
My Photography
Vassago is offline
post #97 of 140 Old 02-23-2014, 12:31 PM Thread Starter
Vassago
snapped a couple phone photos at work
trying to determine which leaf to remove from the pack, also it has JK shocks in it as i need new upper bushing for my Bilsteins, and i need parking brake cables because the TJ ones didn't fit. Aside from the extra lift (i shouldve just done regular UBE's in hindsight) i'm very satisfied with how this rides with the slider boxes, unbelievably smooth. in about 2 weeks i should be at a point where i can get it back out on the trail for testing.
MY BUILD THREAD:
My Photography
Vassago is offline
post #98 of 140 Old 02-23-2014, 03:45 PM
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Looks good! How do you have your rear shocks mounted? Are they just mounted to the stock upper mount?
Originally Posted by Vassago View Post
i need new upper bushing for my Bilsteins.
New bushings for the bilsteins? Eh, I think you should just sell them to me instead
Aside from the extra lift (i shouldve just done regular UBE's in hindsight) i'm very satisfied with how this rides with the slider boxes, unbelievably smooth..
Looks good. I kind of wish I would have gone with the slider boxes. I had to remove my HD Offroad relocation brackets, because my new 6.5" rusty's leaf packs gave me too much lift.
Where are you planning on taking the XJ out to test it out? Making a Rausch trip? I'm hoping to get up there sometime this summer finally.
koolaid5 is offline
post #99 of 140 Old 02-23-2014, 04:03 PM Thread Starter
Vassago
They're mounted to the JKS crossover mount.
I actually have a set of 5100 stock mounting in the box for 6" lifts PM me if you want them I just hadn't shipped them back to return them yet.
Ill probably take it to the local pine barrens trails, couple of fun little hill climbs that I want to see how the locker and gears are since I used to run them all the time before it sat. Actually this is going to be a totally different rig than it used to be the last time shes been out. Gears, steering, disc brakes, axles, rear suspension set up and shocks. I'm down for a rausch trip for sure, I'd like to go a few times this year if possible, easier for me to go during the week with my work schedule.
MY BUILD THREAD:
My Photography
Vassago is offline
post #100 of 140 Old 02-23-2014, 04:20 PM
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Sweet... Sending PM in 2 min.
I have the JKS crossover mount as well, because after my 9" install my shocks were too long. That's why I asked about yours, because it looked like they were at an angle like mind.
I'm in the same boat that you are with the new axles, lockers, gears, and suspension (longarms, new coils, and new leaf packs),
koolaid5 is offline
post #101 of 140 Old 02-23-2014, 04:34 PM Thread Starter
Vassago
Oh man I always wanted to do 9" front and rear narrowed a little bit.
MY BUILD THREAD:
My Photography
Vassago is offline
post #102 of 140 Old 02-23-2014, 04:37 PM
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
I wish I had a 9" front. Just a Ford 9" rear and Wagoneer D44 up front. 63" - 65" WMS, I forget which without looking it up. So, I'm a bit wide.
koolaid5 is offline
post #103 of 140 Old 02-23-2014, 05:35 PM Thread Starter
Vassago
Personally I like the JK width and run with JK stock backspaced wheels on the narrow body XJ keeps
MY BUILD THREAD:
My Photography
Vassago is offline
post #104 of 140 Old 02-23-2014, 06:33 PM
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Personally I wouldn't mind having a sweet *** 4 door JK with a small lift and 35's for a DD, but I can't afford that ****.
koolaid5 is offline
post #105 of 140 Old 02-23-2014, 06:47 PM Thread Starter
Vassago
I'm still a JK hater, my girl has a Sahara 4 door, its nice but just took big for a wheeler for me. A little to no lift 2 door on 37s might sway me maybe. If I ever left an xj I'd go LJ or Toyota
MY BUILD THREAD:
My Photography
Vassago is offline
