Back and Building - Page 2 - JeepForum.com
post #16 of 140 Old 12-15-2013, 07:56 AM
Camfam07
sweet looking rig!
Camfam07 is offline
post #17 of 140 Old 12-15-2013, 11:57 AM
cbenez1
Glad to see you and your XJ up and running again.
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #18 of 140 Old 12-15-2013, 01:05 PM Thread Starter
Vassago
Originally Posted by Camfam07 View Post
sweet looking rig!
thank you!
My XJ will be pulled into the garage tonight or first this in the morning depending on how the day goes. Been working on the getting the garage into a functioning shop all week.
On the agenda:
Install Clearwater cylinder head
Flush EVERYTHING having do with the cooling system and replace hoses and such as needed.
Fix heat, it's winter after all
Rework headlight wiring harness to make room for the stock airbox for the snorkel
Realign snorkel and repair crack from my door
Immaculate cleaning of engine bay to trace leaks and such
Shorten trackbar
Change trans fluid and filter
Clean NSS
Clean throttle body
Diagnose noise from front end
It's a long list for 2 days with the biggest goal being the cylinder head and cooling system above all else. Wish me luck.
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD:
My Photography
Vassago is offline
post #19 of 140 Old 12-17-2013, 07:37 AM
steiny93
How does the snorkel work when its really cold (-10 and below)? Do you have snow dust issues for example plugging up the filter if you are offroad in snow a lot? Or is it a non issue?
Wife thinks my tracked jeep needs a snorkel but i'm worried about it sucking in snow dust and having filter issues (like the rangers and rzr's do if they are tracked without a cab).
steiny93 is offline
post #20 of 140 Old 12-17-2013, 06:51 PM Thread Starter
Vassago
I don't really get those kinds of conditions in NJ to worry about it. Can just turn the top of the snorkel around for slower speed snow dust conditions if you're worried about sucking anything in.
MY BUILD THREAD:
My Photography
Vassago is offline
post #21 of 140 Old 12-17-2013, 06:52 PM Thread Starter
Vassago
Got the cylinder head installed and cooling system flushed, it's going to need another flush it was really gunky. I had coolant in my oil and oil in my coolant.
Pics and details tomorrow.
MY BUILD THREAD:
My Photography
Vassago is offline
post #22 of 140 Old 12-17-2013, 07:49 PM
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
I hope you don mind me answering this Vassago. My jeep has a snorkel, I live in Alaska. 2 weeks ago the temp was ranging from -10 to 10 above. This is my second winter with the snorkel. I've had zero issues and doubt I will.
April 2014 & 2015 COTM
MOBBiN is offline
post #23 of 140 Old 12-18-2013, 01:26 PM Thread Starter
Vassago
Not at all! We're all friends here.
MY BUILD THREAD:
My Photography
Vassago is offline
post #24 of 140 Old 12-18-2013, 01:45 PM Thread Starter
Vassago
Okay time for an update.
This is the first time any vehicle has been in the garage since i've lived in this house for the past 3 year (old roommates have a photography studio in there) needs more work to get perfect but between my jeep, and my new roommate's 240sx drift car build, we'll get it figured out.
Ran into my first and only problem of the head swap. A broken steering pump bolt, still acts like a stud so i just left it like that. I'll tackle it when i upgrade the steering box and pump in the future.
Then i got to witness this mess!
Luckily, the rockers and valves didn't look quite as bad.
Here's a picture of my crack
Torn apart at the halfway point, took 3 1/2 hours to get it to this point taking my time without help.
New head gasket
Clearwater head installed. Yes, i reused my head bolts as they were brand new Mopar bolts i had installed last time i did this and it's okay to reuse them once.
Called it a night on monday at this point, i had taken too long of a break and hit a bunch of traffic doing last minute run around stuff.
And test drive went fine. Check one thing off the list!
One thing i'm still concerned with is i don't have much heat, it's warmish but not hot. I need to flush the heater core again (water is turned off but it's going to be warm this weekend so i'm sure i'll get it flushed then) My no heat issue started after installed a CSF 3row radiator and flowkooler high-flow water pump. Maybe they're too efficient? anyone car to chime in on the subject?
MY BUILD THREAD:
My Photography
Vassago is offline
post #25 of 140 Old 12-19-2013, 05:24 AM
DNFJ
Holy **** I'm surprised the rockers and pushrods were in as nice shape as they were.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #26 of 140 Old 12-19-2013, 08:23 AM Thread Starter
Vassago
I had been changing my oil every week. What was there was insanely thin viscosity though. Driven it to work yesterday and today. 90 miles since the swap and the motor os so quiet now i HAVE to fix the exhaust it's annoying.
Also, my Audi should be sold tonight! That means I get to do a parts ordering spree! Need to figure out the best order to do that in.
MY BUILD THREAD:
My Photography
Vassago is offline
post #27 of 140 Old 12-19-2013, 12:03 PM
VegasGT
1988 MJ Comanche
I was eating a bean burrito when I seen the pic inside the valvecover... almost puked haha.
Good work! Ill be tuned in for this buying spree.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #28 of 140 Old 12-20-2013, 08:49 AM Thread Starter
Vassago
Threw P0432 code on my way home last night
MY BUILD THREAD:
My Photography
Vassago is offline
post #29 of 140 Old 12-26-2013, 10:44 AM Thread Starter
Vassago
Well the Audi is GONE, glad to have that mistake of a purchase behind me!
Orders have been placed for the following:
TNT Customs 1" UBE's
JKS Upper shock mount (my damn landlord threw out the one I had purchased from hotrodhooligan years ago)
Liquid Iron Industries bolt-on slider boxes.
Now I just need axle shafts and a master install kit for the differential, I will be getting those through the shop assembling the axle. I know, I know, I should be doing it myself and I would prefer that, but is the essence of time and not owning a welder (yet) it's simply easier this way and I dont have to worry about having an issue because I screwed it up.
MY BUILD THREAD:
My Photography
Vassago is offline
post #30 of 140 Old 12-28-2013, 09:20 AM Thread Starter
Vassago
Well these showed up quick!
MY BUILD THREAD:
My Photography
Vassago is offline
