ARB Old Man Emu Lift kits vs Others - Page 2 - JeepForum.com
post #16 of 21 Old 09-25-2012, 11:25 AM
MountainMan864
ill be ordering the dpgoffroad 3.5in HD OME lift minus the JKS parts. Ill be replacing those with Currie parts. Ill be running 1.5in wheels spacers with moabs and 265s mud tires.
MountainMan864 is offline
post #17 of 21 Old 09-25-2012, 03:45 PM
MCObray
. You sir, know what you're doing.
1994 Dodge Ram 2500. 12V Cummins Turbo Diesel.
MCObray is offline
post #18 of 21 Old 02-20-2013, 07:25 PM
5jeepsIn12years
hey guys, i know this thread is a bit old but can anyone tell me what the MPG drop is going from stock to 1.5? trying to keep lean but an off road/better ride is tempting
5jeepsIn12years is offline
post #19 of 21 Old 02-20-2013, 11:31 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Your milage will drop some buy not much mainly do to larger tires and more drag. You would probably lose 1-2mpg
Sent from iPhoneusing JeepForum
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #20 of 21 Old 02-21-2013, 12:20 PM
DerMeister
I ended up doing a 2" lift with OME rear springs and bilstein shocks. I spent under $600 all said and done, and I'm very happy with the set-up. The Bilstein shocks are a little stiffer than I'd like, but it's not a big deal.
Now on to the OME rear springs. I bought and verified that had the OME medium duty springs. I got a solid 4" of lift off of them, and they have settled to around 3.25" of lift in the rear after driving around with cement blocks in the back for 8 months. I took them out because I was afraid to drive around with 50lb pieces of cement in the back any longer during winter in case of an accident.
I was pretty upset by the original 4" at first, but I've realized that over time the springs will settle even more, so these springs should last a LONG time before I get any sagging. A little bit of weight makes it even with the front.
DerMeister is offline
post #21 of 21 Old 01-01-2014, 01:35 PM
barflyfisherman
Hd ome
I outfitted my 1999 XJ with HD OME Front and Rear springs with Bilstein Shocks. I added the OME add-a-leaf to the rear spring pack.
I had a Rugged Ridge 4" lift in my old rig. I needed a kidney belt and control felt really lose (body sway) on the highway. This time I was going to do it right.
I am running a Nate's rear tire carrier bumper, with (2) 5 gallon gerry cans, (1) 5 gallon water jug, a roof rack with hi-lift jack, shovels, pick/axe & the cargo area full of gear. Up front I have a modified Nate's recessed winch bumper, 10,000 lb winch and a dual battery set-up. Smittybuilt cutout flares with 31's on 16" wheels. 4 wheel disc brakes. Up front WJ spindles w/Ford rotors. In the rear are Crown Vic disc brakes on an 1989 Dana 44 with an E-locker. Running 4.11 gearing ratios.
Needless to say, there is a lot of weight.
The Heavy Duty OME front and rear springs (w/add a leaf) gave me about 3.5" of lift. I installed adjustable shackles in the rear to gain 1". When the gas tank, gerry cans & water jug are filled, I drop in the rear about 1/2".
My mileage dropped about 2 mph after the lift. Changing the gearing ratio to 4.11 and swapping to the correct speedo gear (a 5 minute $20 EBay fix) brought my mileage up 2 mpg. And, I didn't lose momentum going up hills on the highway any longer!
The ride is perfect when loaded. A little hard when I'm empty, but I mainly use my rig for hunting on rough ranch roads.
REMEMBER - you get what you pay for!
Hillary Clinton - Wasn't a swirling house supposed to fall on her by now?
I don't kill innocent animals.... only the guilty looking ones!
barflyfisherman is offline
LIFT KITS that will fit 37's jeepsteralley XJ Cherokee Technical Forum 33 09-12-2009 09:12 AM
OME Lift Kits CrawlnFool XJ Cherokee Technical Forum 4 05-16-2009 12:41 PM
lift kits where to buy neil4.0 MJ Comanche Technical Forum 11 06-11-2008 02:04 PM
Lift Kits Vs Individual Lift Parts LeeBee XJ Cherokee Technical Forum 6 10-22-2007 12:21 PM
Lift kits Bblock XJ Cherokee Technical Forum 8 08-10-2002 01:01 AM
