APPLJCK - 1997 Jeep Comanche Work Log - Page 4 - JeepForum.com
post #46 of 92 Old 11-04-2013, 05:45 PM Thread Starter
LimeLJ
LimeLJ's Avatar
Careful now. You're still dealing with a Jeep here..........
The same model Jeep that was frequently used for racing and had its own Street Comanche model.
I am going to consider replacing all of the leaf spring bushings and possibly adding a rear track bar. It is definitely some tail wag. If I get that under control then there is no reason to go back to the ground.
2004 Jeep Wrangler Unlimited
1997 Jeep Comanche - 4.7L Stroker, Lifted, "Restored", and soon to be supercharged.
LimeLJ is offline
post #47 of 92 Old 11-04-2013, 06:02 PM
VicOfAges
I've never been into racing, but dude. That was a race.
VicOfAges is offline
post #48 of 92 Old 11-04-2013, 09:35 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Video Link: http://www.youtube.com/watch?v=PXnwYG0R3rc
That rig was awesome - I just pictured a chopped MJ w/ lopro's and spinners on your previous post..........but something like in that vid would be kickarse.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #49 of 92 Old 11-05-2013, 01:48 PM Thread Starter
LimeLJ
LimeLJ's Avatar
I would still have reasonable tires. I entirely went with the new JK Moab rims because I like how they look with the truck. The mud tires just happened to be on there.
LimeLJ is offline
post #50 of 92 Old 12-08-2013, 02:00 AM Thread Starter
LimeLJ
LimeLJ's Avatar
This is what my "TO DO" list looks like right now. This is what I have written done, but is certainly not a complete list.
  • Install rest of exhaust(3")
  • Weld up rear bumper
  • Missing Transfer Case Nut 3/8"
  • Paint oil pan scratches.
  • 1,000 mile rear differential oil change(Uh, 1,800 miles I mean.)
  • Seam Sealer by VIN tag in engine bay
  • Drain and refill transfer case - Rattling on coasting - Break down current case and swap output shaft to newer case.
  • Finish installing Novak shifter
  • Rebuild front drive shaft
  • Differential Breathers
  • Horns
  • Rotate Fuel Pump Assembly
  • Grind Rear Flare Retainer Studs Off
  • Flares
  • Refresh Tail Lights
  • Install New Battery Wiring
  • Headliner
  • Cover Rear Backer Board
  • Test Install Burgundy Interior for dual tone look
  • Recover Seats
  • AC Charge
  • Parking Brake Adjustment
Hella Vision Plus H4 ECE conversion housings, Centric Premium Rotors, Centric Posi-Quiet Pads, and WJ Front Lower Control Arms
This looks familiar. The axle is off to the side and back from finally being regeared to 4.56 along with new hubs installed.
RE9905 braces for the RE9900 drop brackets. The manual specifies they do not work on the Comanche, but the general frame area is the same. Looks like an extra hole needs to be drilled for the forward crossmember bolt and possibly some of the lower control arm mount extra bracing trimmed.
Rear view mirror with auto-dimming, compass, map lights, and temperature.
Sound Deadener! I put this on the ceiling, INSIDE the B pillars, inside the doors, and along the back wall. Made a huge difference in overall rumble.
Replacement weatherstripping for the A pillars. Not quite factory style, but they would work well.
LimeLJ is offline
post #51 of 92 Old 12-15-2013, 11:19 PM Thread Starter
LimeLJ
LimeLJ's Avatar
New wheel hubs installed when I had it regeared. The brake dust shields were left off due to be rusty.
Centric Premium Rotors and Posi-Quiet Pads - What was on there were nearly new, but hard braking induced a very hard pull to the left that I could not solve.
WJ Lower Control Arms - Returned 100% of the steering radius with these. They are installed in the correct orientation.
LimeLJ is offline
post #52 of 92 Old 12-16-2013, 05:39 AM
DNFJ
Damn this thing is amazing. Keep up the good work.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #53 of 92 Old 12-29-2013, 01:08 AM Thread Starter
LimeLJ
LimeLJ's Avatar
This will look better with some piping like the stock seats.
LimeLJ is offline
post #54 of 92 Old 01-02-2014, 06:48 PM Thread Starter
LimeLJ
LimeLJ's Avatar
Hella Vision Plus H4 Headlights - A huge improvement over stock even without a wiring harness upgrade.
Fixed Vacuum Ball - HVAC vents finally work and cruise control works.
Marine Style Battery Terminals - This is part of Kelly's WIP 4 gauge wire upgrade. This solved the hard starting issue as my power harness was thoroughly destroyed by corrosion along with battered terminals.
Trimmed the cover at the PDC to fit the new cables.
150 AMP fuse for the alternator. I can run a 136 AMP alternator safely now.
The flexible 4 gauge welding wire was wrapped in wire loom for heat and abrasion resistance. The alternator field generator wires were removed from the original harness and incorporated into the new harness.
LimeLJ is offline
post #55 of 92 Old 01-02-2014, 06:53 PM
Spokes
i never should have sold my MJ
Red 00 XJ lifted
Build -->
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline
post #56 of 92 Old 01-02-2014, 07:18 PM
JeepN4KC
JeepN4KC's Avatar
Back in July I swapped in Centric Premiums on the WK - good stuff.
I put Akebono pads with 'em and the set-up is top notch IMO.
~Mike~
WK
XJ
JeepN4KC is offline
post #57 of 92 Old 02-03-2014, 08:35 PM Thread Starter
LimeLJ
LimeLJ's Avatar
AEM F/IC Installation - That bulge is a perfect spot to wire in without extending the AEM F/IC harness and have it mounted inside.
Mounted to the driver kick plate.
F/IC's USB B port is extended and mounted to the center console for easy access and tuning.
I ended up getting the Napier Flares.
LimeLJ is offline
post #58 of 92 Old 02-03-2014, 08:56 PM
VegasGT
1988 MJ Comanche
Nice choice on the Napiers, I would buy those if I chose to ever run flares again.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #59 of 92 Old 02-05-2014, 09:05 PM Thread Starter
LimeLJ
LimeLJ's Avatar
Pioneer Head Unit - Does all the fancy stuff, but only puts out 17 watts RMS per speaker...
...So I have to wire in this 8 AWG wire for a four channel amplifier to push 45 watts RMS to speakers and a subwoofer.
The stock clutch master cylinder mount is perfect for running wires.
LimeLJ is offline
post #60 of 92 Old 02-05-2014, 09:06 PM Thread Starter
LimeLJ
LimeLJ's Avatar
Yep, southern states are nice and lenient on vehicle rules. The splash up on the Cherokee is worse than my Wrangler so I really want the flares.
LimeLJ is offline
