Anyone paint your engine parts? - JeepForum.com
post #1 of 31 Old 08-16-2014, 01:43 PM Thread Starter
svshaw82
1989 XJ Cherokee
Just wondering if anyone paints their engine parts on a rebuild? Attached a few photos of mine so far to share.
Does anyone else have some to share?
svshaw82 is offline
post #2 of 31 Old 08-16-2014, 03:41 PM
ninjakid
1987 YJ Wrangler
I'm no mod but this thread might be better off in the non technical section.
Its a 258 going into a yj but yes I did paint mine.
Its not like I really had a choice though since dry ice blasting my block removed most of the paint and I would never forgive myself for not taking the time to paint it and make it look nice.
Incompetence in motion
96 XJ 4dr, 4.0, AW4, NP231,
87 Wrangler, 4.2, TF999, NP231
ninjakid is offline
post #3 of 31 Old 08-16-2014, 04:03 PM
Ferryman
That looks nice! Just be carefull not to paint the bosses of the frostplugs, they might fit too tight and lose their function.
Tony.
Ferryman is offline
post #4 of 31 Old 08-16-2014, 04:22 PM Thread Starter
svshaw82
1989 XJ Cherokee
What do you mean the bosses of the frost plugs? A little paint there gonna hurt them?
svshaw82 is offline
post #5 of 31 Old 08-16-2014, 08:14 PM Thread Starter
svshaw82
1989 XJ Cherokee
Almost done with the intake...
svshaw82 is offline
post #6 of 31 Old 08-16-2014, 10:04 PM
ninjakid
1987 YJ Wrangler
I like that combination of red and black.
What paint you using?
ninjakid is offline
post #7 of 31 Old 08-16-2014, 10:32 PM Thread Starter
svshaw82
1989 XJ Cherokee
I've been sticking to the red and black because those are my jeeps colors
Been using the high temp engine paints from Oreilys. So I hope they stick after it's running again. They will have plenty of time to cure.
svshaw82 is offline
post #8 of 31 Old 08-17-2014, 02:43 AM
Ferryman
Sorry, forget it. I didn't realise you're based in CA.
Frostplugs are disigned to pop out when you neglect your antifreeze in low temp areas and paint can hold them tight.
Again forget it, you are doing a great job!
Tony.
Ferryman is offline
post #9 of 31 Old 08-17-2014, 11:44 AM Thread Starter
svshaw82
1989 XJ Cherokee
Originally Posted by Ferryman
Sorry, forget it. I didn't realise you're based in CA. Frostplugs are disigned to pop out when you neglect your antifreeze in low temp areas and paint can hold them tight. Again forget it, you are doing a great job! Tony.
Lol! Scared me for a second! I was gonna be like
"Man! I've already got them all in, now I gotta bang them out and replace them all?"
Thanks for the comments
svshaw82 is offline
post #10 of 31 Old 08-17-2014, 12:10 PM Thread Starter
svshaw82
1989 XJ Cherokee
Reassembled!
svshaw82 is offline
post #11 of 31 Old 08-17-2014, 02:58 PM Thread Starter
svshaw82
1989 XJ Cherokee
All fittings back on and injectors seated. Complete clean of throttle body, and I even took a dremel to debur the casting flash inside.
svshaw82 is offline
post #12 of 31 Old 08-17-2014, 03:01 PM Thread Starter
svshaw82
1989 XJ Cherokee
Anyone know where I can get another fitting and vacuum tube for my MAP sensor? The old one was brittle and snapped when I removed the engine.
svshaw82 is offline
post #13 of 31 Old 08-17-2014, 05:19 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I got mine at the dealer, it was the only place I could find them.
xjfever is offline
post #14 of 31 Old 08-17-2014, 06:57 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Ferrari look:
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #15 of 31 Old 08-20-2014, 05:59 AM
DNFJ
Yup.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
