Any tow bars on XJ's?/ - JeepForum.com
post #1 of 13 Old 03-15-2012, 08:19 PM Thread Starter
VietVet67
I thinking about an XJ to tow behind my RV--anyone tow theirs on all fours with a tow bar--if so anything i should know?? it's a 2000 if that makes a difference??Thanks in advance--Glenn
VietVet67 is offline
post #2 of 13 Old 03-15-2012, 11:02 PM
Planetcat
2010 WK
I tow the XJ all over the place with my Dodge Ram 2500. Tow hooks are bolted directly to the front rock bumper face and it tows great. Towing it with a big truck is easy, but I tow it sometimes with my grand cherokee and the lack of "trailer" brakes makes the jeep sway all over and braking is nerve racking. Even with the truck, I can't make radical lane changes or turns. The best thing to do is to get a brake actuator for the XJ brakes, so you can stop it when you're towing it. I'd give it a try first with your RV to see how it tows, but the right way to do it is with the actuator. Read the owner's manual about the correct settings of the transfer case and the transmission, too. Other than that, they are a breeze to tow with the right rig. Here's the only picture I have that shows the front tow hook connections:
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
post #3 of 13 Old 03-16-2012, 07:16 AM
IDIdiesel
I flat towed mine behind a RV without trailer brakes and just planned out m stops. Pulled real nice. The owners manual has instructions for transmission settings.
2015 Ford F350 crew cab, gasser
2001 Cherokee sport "AGENT ORANGE"
1991 Ford 7.3L IDI- FOR SALE
IDIdiesel is offline
post #4 of 13 Old 03-16-2012, 07:39 AM
Azzy
You got it all wrong... that's a rig to push an RV, right?
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #5 of 13 Old 03-16-2012, 07:44 AM
fedx95
1993 XJ Cherokee
lol
fedx95 is offline
post #6 of 13 Old 03-16-2012, 10:08 AM Thread Starter
VietVet67
Is the origional bumper on a 2000 XJ stout enough to work--will only be towing once and a while to ELK camp--Yes i did try pushing an RV once--folded up the tow bar very nicely-and it wasn't a folding one either?-Thanks guys --Glenn
post #7 of 13 Old 03-16-2012, 10:29 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Check out RV equipment websites/dealers, you need a special Cherokee frame attachment adapter for the tow-bar. The stock bumper is just sheet metal and will pull right off.
CJ7-Tim is offline
post #8 of 13 Old 03-16-2012, 11:34 AM
BlueBadger
I built a row bar to match my home built bumper sorry no pics. I pull it with a 1500 2wd dodge with a 360. Pulls great been every where with it like this. But with the light truck have to plan stops and no sudden lane changes!!!! With that big RV you shouldn't even notice it.
BlueBadger is offline
post #9 of 13 Old 03-16-2012, 07:36 PM Thread Starter
VietVet67
I'll be wanting a bumper like Planetcat has then --any excuse to custom it i guess--Thanks for the replies so far-BTW
post #10 of 13 Old 03-16-2012, 08:53 PM
IDIdiesel
exactly I used it to get a bit better than 8mpg. I had it loaded up with a bung of shooting equipment for the national matches last summer
post #11 of 13 Old 03-17-2012, 10:40 AM
Planetcat
2010 WK
It's an Olympic rock bumper. I have the one with the hitch, so I can swap my portable winch between truck and jeep. I think without the hitch receiver, they run a little over $200 at Quadratec, but there are others that will do the job. I did the same thing with my old YJ. Grade 8 hardware all the way around, some 1/2" hitch pins to quickly disconnect the tow bar, and you're good to go.
post #12 of 13 Old 03-18-2012, 10:27 PM
joe108
Dont forget to use some type of braking device for the towed veh., Jeeps are very heavy and the towing veh. has a very hard time stopping the additional weight in an emergency situation, been there. Luckily I was able to stop..that and in most states it's required, not to mention if things go bad while towing and you end up in court.
joe108 is offline
post #13 of 13 Old 03-19-2012, 03:31 AM
PNWClimb
1997 XJ Cherokee
Mine came with the Jeep, mounts with bolts into the rail and flag nuts. One of the first things to come off, after that goofy license plate frame... I've still got it around
KE7RVG
Climb rocks and routes
PNWClimb is offline
XJ's with liberty light bars! Spokes XJ/MJ Cherokee Non-Technical Forum 2 01-12-2010 11:49 AM
Bastard pack, sway bars, track bars. Slightly confused. andr3w XJ Cherokee Technical Forum 4 11-10-2009 03:13 PM
New to XJ's.. How about this one izanuff XJ Cherokee Technical Forum 5 04-02-2008 01:00 AM
XJ's Everywhere! norsky XJ Cherokee Technical Forum 9 03-05-2008 07:37 PM
3 XJ's for $500 scorpionkill XJ Cherokee Technical Forum 4 11-19-2004 02:22 PM
