Any boater's?! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Any boater's?!
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 10-13-2013, 01:12 PM   #1
HawksWin
Any boater's?!
Hey guys I tow a 17 foot Sylvan with my 2000 xj Sport with a 4.0 auto and a 8.25 rear end. After going to the lake and back I started my jeep and it sounded like it was missing. After giving it a little throttle, it ran fine. Just want to make sure I'm not hurting my xj!
HawksWin is offline   Reply With Quote Quick reply to this message
Unread 10-13-2013, 02:14 PM   #2
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
I pull a 16' Smokercraft with no issues yet.
4.0 auto; 8.25; stock gears; 31" tires; brakes on the trailer axle.
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
COTY 2009
chris87xj is online now   Reply With Quote Quick reply to this message
Unread 10-14-2013, 03:43 PM   #3
jeepkid03
Winning
jeepkid03's Avatar
The running rough is a common problem called "heat soak" on 2000 and 2001 Cherokees. It most commonly occurs on a hot start of the engine. Just make sure you tow in "3" and NOT in "D". A transmission cooler isn't a bad idea either. Make sure your cooling system is in good condition, and you should be fine.
-Josh
My 0331 Head Swap How-To Thread:
http://www.jeepforum.com/forum/f11/0...hread-1371398/
Build Thread:
http://www.jeepforum.com/forum/f22/m...build-1119997/
jeepkid03 is offline   Reply With Quote Quick reply to this message
Unread 10-14-2013, 05:50 PM   #4
HawksWin
Thanks! I started in D and noticed how bad it was towing. Threw it in 3 and was way better. So the "heat soak" isn't bad? Thanks for the help!
Unread 10-14-2013, 06:59 PM   #5
Muddy97Cherokee
1997 XJ Cherokee
Check O2 sensors and crank shaft sensor.
[SIZE="4"][U][B]1997 XJ Sport[/B][/U][/SIZE]
[SIZE="3"]6.5" with 31's[/SIZE]
[SIZE="3"]Built to CRAWL[/SIZE]
[URL="http://www.jeepforum.com/forum/f177/muddy97cherokees-build-thread-1318554/index5.html"][SIZE="5"][COLOR="Blue"][B]BUILD THREAD[/B][/COLOR][/SIZE][/URL]
[SIZE="3"][B]IG: zack_hstadt[/B][/SIZE]
[SIZE="4"]-ZACK[/SIZE]
Muddy97Cherokee is offline   Reply With Quote Quick reply to this message
