Amplifier grounding - JeepForum.com
post #1 of 6 Old 04-30-2012, 01:47 PM Thread Starter
nickxrock
Amplifier grounding
I'm new to the forums, and I'm sure this has been asked before. Where do you guys usually ground your Amps when installing them in the xj?
nickxrock is offline
post #2 of 6 Old 04-30-2012, 02:17 PM
PNWClimb
1997 XJ Cherokee
A popular placement is under the rear seat, and using one of the seatbelt bolts works great for grounding.
KE7RVG
Climb rocks and routes
PNWClimb is offline
post #3 of 6 Old 04-30-2012, 02:19 PM
Oregon187
Welcome to the forum.
As close to the amp as possible. You can use an existing screw/bolt or put in a new one but your ground wire should be as short as possible. I put my amp under the back seat (not the best location for heat control but mine isn't very powerful anyway) and I used one of the holes in the seat support and just added a bolt through it. Don't forget to remove the paint or you won't have a connection.
2001 XJ build thread --
Oregon187 is offline
post #4 of 6 Old 04-30-2012, 02:21 PM
Oregon187
http://www.jeepforum.com/forum/f11/x...thread-680594/
There is lots of Audio information on this thread.
post #5 of 6 Old 04-30-2012, 07:50 PM
NJXJ91
My amps mounted on my sub. So I used the spare tire mount
NJXJ91 is offline
post #6 of 6 Old 04-30-2012, 08:12 PM
Durt_Diver
mine is grounded underneath the screw for the jack stand holder. just screwed right on
-Jacob-
lockers don't work unless you have Rubicon stickers
Durt_Diver is offline
