-   XJ/MJ Cherokee Non-Technical Forum (http://www.jeepforum.com/forum/f177/)
-   -   Amplifier grounding (http://www.jeepforum.com/forum/f177/amplifier-grounding-1363167/)
nickxrock 04-30-2012 01:47 PM
Amplifier grounding
I'm new to the forums, and I'm sure this has been asked before. Where do you guys usually ground your Amps when installing them in the xj?
PNWClimb 04-30-2012 02:17 PM
A popular placement is under the rear seat, and using one of the seatbelt bolts works great for grounding.
Oregon187 04-30-2012 02:19 PM
Welcome to the forum.
As close to the amp as possible. You can use an existing screw/bolt or put in a new one but your ground wire should be as short as possible. I put my amp under the back seat (not the best location for heat control but mine isn't very powerful anyway) and I used one of the holes in the seat support and just added a bolt through it. Don't forget to remove the paint or you won't have a connection.
Oregon187 04-30-2012 02:21 PM
http://www.jeepforum.com/forum/f11/x...thread-680594/
There is lots of Audio information on this thread.
NJXJ91 04-30-2012 07:50 PM
My amps mounted on my sub. So I used the spare tire mount
Durt_Diver 04-30-2012 08:12 PM
mine is grounded underneath the screw for the jack stand holder. just screwed right on :laugh:
The time now is 07:06 PM.
