Am I crazy or can I fix this halfway decent? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > Am I crazy or can I fix this halfway decent?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Solution to Radius Arm Bind - Meet Lock-N-LoadFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread Today, 10:17 AM   #1
pbiancardi
I have some rust in two spots, one is the bottom of both doors (rocker panels are clean, doors only) and the passenger front panel.
I was going to pay a body shop $400.00 to repair but bolstered by my POR-15 floor pan repair I am thinking maybe I can do this myself (and I am worried that the body shop might just cover it without treating it and end up coming back).
Can I just wire brush and POR-15 the affected areas and then cover? For the front panel I would hit it with color matched paint (or something close) and for the door I am thinking just tape off a line below the trim and plasti dip everything below it including the rocker panels. Will the plasti dip protect the unrusted areas?
I dont want it to look totally rigged up but if I can save a few bucks and know that the rust is gone for good I would be happy.
imgurl
picture share
pbiancardi is offline   Reply With Quote Quick reply to this message
Unread Today, 10:26 AM   #2
Motorcharge
1991 MJ Comanche
Get rid of the rust and POR-15 then bedline the rockers and door lowers. Your plan for the front is probably the best way to go. Even if it stands out a little who cares if it eliminates the rust.
These new sig limits suck. Thanks a lot Canada.
Motorcharge is offline   Reply With Quote Quick reply to this message
Unread Today, 10:30 AM   #3
pbiancardi
That was my thought, rather have something semi-ugly and fixed than shiny and new with rust waiting to reappear. Bedliner would work better than plasti dip? I have both sitting in my garage anyway...
Unread Today, 11:07 AM   #4
Motorcharge
1991 MJ Comanche
Plastidip peels off and doesn't do much for protection. Bedliner will help keep moisture out and is harder to scratch.
Unread Today, 01:55 PM   #5
DNFJ
DNFJ's Avatar
Put phosphoric acid over top off the cleaned up rust before you paint it, it kills off any remaining rust pockets in the metal.
Wannabe Desert Rat
'00 XJ 6.5" w/ 33s
Built Not Bought #704
DNFJ is offline   Reply With Quote Quick reply to this message
