Are all gears created equal - Page 2 - JeepForum.com
post #16 of 18 Old 04-01-2012, 10:13 AM
xGArfx
If you have an visions of going to 33s then do yourself a big favor now, get 4.88s your mpg and trans life will thank you!! I've driven many setups- 4.56 w/33s and 35s, 4.88s w/33s and 35s, 4.10s w/33s.....
best setup by far is still 4.88s and 33s, I don't look forward to the day I decide to jump to 35s i will miss the good power and mpg I've been getting
If colorado has the hills and mountains I think it does you surely won't regret the 4.88s. I live in NJ and we have some hills on the highway but it does amazing, the times I've taken it out to NY and PA I really got to appreciate the lower gears, not to mention 4 low is VERY low and does amazing in the rocks/trails. Not trying to bash you or anything just giving you some things to think about, I went through this expensive dilemma a year ago and glad I choose to gear it deep at the time. You may think 31s are the biggest tire you will run but trust me, it most likely wont be lol!!!!
xGArfx is offline
post #17 of 18 Old 04-01-2012, 10:32 AM Thread Starter
Steev89
I thought I had heard somewhere that 4.56 was the lowest you could go on the 8.25 rear axle that I have.
If that's wrong then maybe I should just jump up to 4.88 lol
1999 Jeep XJ : 5" lift, TnT y-link radius arms and belly pan, Rugged Ridge sye, TnT body StiffinerZ. Socket forever stuck inside unibody
Steev89 is offline
post #18 of 18 Old 04-01-2012, 10:58 AM
xGArfx
this is where I ordered my gears and installs from, i have a hp 30 up front and a 29 spline 8.25 rear. Came with yukon 4.88s for the 8.25 and usa standard (yukons side brand) 4.88s for the 30. Also came with TOYO bearings/seals ect and you also need to get the new dana 30 carrier. I liked ordering all the stuff from one place but you might be able to find it cheaper buying things individually, just made it easier for me.
http://www.rwkhaussupply.com/magento...-and-rear.html
xGArfx is offline
4.11 , gears
All gears created equal??? 99Greenmachine XJ Cherokee Technical Forum 6 07-25-2009 09:16 AM
R all XJ downpipes created equal? LeeBee XJ Cherokee Technical Forum 6 11-03-2007 06:35 PM
all tow hook brackets created equal? bluestocker00 XJ Cherokee Technical Forum 7 07-26-2007 02:40 PM
And on the 8th day, God created TNT. HeavyMetal XJ Cherokee Technical Forum 47 05-15-2007 03:52 PM
Are all (stock) crossmembers created equal? TheNerd XJ Cherokee Technical Forum 2 11-27-2006 09:23 AM
