Air conditioning - JeepForum.com
post #1 of 12 Old 05-15-2012, 07:45 PM Thread Starter
Bigdog7373
Air conditioning
Hey guys this is my first post here. I'm looking into buying an xj, probably a 2000 model or something close. Anyway, i used to own a Z71 tahoe and it had great a/c, then i sold it and bought an audi which has horrible a/c and takes forever for the car to cool off. I want to make sure i'm not going to get into this problem again. It wont make or break me getting the truck though, but i'd like to be prepared. Anyone have any complaints about it or does it work well? I'm in south florida so a/c is a must. Thanks in advance
Bigdog7373 is offline
post #2 of 12 Old 05-15-2012, 08:01 PM
cactus_jack
167,000 miles with original A/C compressor. Cools off fast. Cold as ice
CACTUS_JACK
98 XJ Sport Budget Build
cactus_jack is offline
post #3 of 12 Old 05-15-2012, 08:19 PM
Hudson
It's really a toss up man. All compressors in any car can go bad. (or for that matter the evap, condenser, etc etc.)
My dad is an HVAC Technician, so people always bring their cars to my house to get them charged. I watched him fix 3 Cherokees; One had a slow leak, one had a bad compressor, and one had a hole in the evaporator. Does that mean the A/C is bad? No. If something wasn't wrong with it in the first place, they wouldn't of brought it to him. I'm sure there are plenty that have no problems.
Take Cactus as an example. I personally have a hole in the evap as well. Don't feel like fixing it yet.
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
post #4 of 12 Old 05-15-2012, 10:03 PM
DerMeister
Well, my 2000 has had some AC problems. Hopefully I am near the end of it all. The issue im sure as you know is the cost of AC components, re-charging and in the case with the 97+ XJ, the work involved in the evaporator.
First, my clutch bearing went out on the compressor. Swapped it out with a remain, bam $200. Re-charge, $60.
All leaked out. Found out it was the evaporaor. Bam $120.
It'll take a day or two to fix, and then another re-charge.
I just don't know if it was worth it. The evaporator is prone to leaking on the 97+ models and its a PITA to replace.
DerMeister is offline
post #5 of 12 Old 05-16-2012, 01:15 PM Thread Starter
Bigdog7373
The more i read about these trucks the more it seems like they are prone to a lot of problems. Think i'll just get another tahoe, and i've got enough $ for a bigger lift than before. Thanks for the responses.
post #6 of 12 Old 05-16-2012, 01:42 PM
Millermagic
120k on my 2000. A/C blows cold. Definitely the original compressor and I've never recharged it in the 1.5 years i've owned it
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #7 of 12 Old 05-16-2012, 01:57 PM
cactus_jack
Go read a tahoe forum, I bet they're just as prone, if not more prone, to problems than the Cherokee. Any vehicle with many years of service and high miles is going to have some sort of problem or maintenance issue. If they're taken care of, they'll last forever. I've owned two XJs and have never owned a more reliable vehicle in my life.
CACTUS_JACK
post #8 of 12 Old 05-16-2012, 02:27 PM
Corcor4
1990 XJ Cherokee
this. same on my 2nd, wish i never sold the first and had to get another one. This one doesn't have AC... i like it more, suns out guns out (doors off)
i can assure you, you would love an xj.
when it comes to AC its a toss up in any car. buy one with lower miles and keep track of the maintenance (as you should with any car) and you'll be fine. ive bought my xj's with higher miles 160k+ and love them. not to mention most jeep owners i've met are way more helpful and friend than the other cars/trucks i've owned.
My second try: 1990 Jeep Cherokee Xj 6.5ish" lift with tj componets, 33" duratrac's, oversized roof rack, onboard air, body armor.
-OREGON JEEP OWNERS, NORTH WEST CREEPING JEEPERS
18 years old and lots to learn :D
Corcor4 is offline
post #9 of 12 Old 05-17-2012, 10:05 AM
brycec
2011 JK Wrangler
My evap core needed to be replaced on my 99 XJ after 90k miles. I learned from that experience that the XJ has been notorious for that failure. That being said, now that it's working, it works great. I'm in Houston and when we are pushing 105 outside (with a black on black XJ) the back tends to stay a bit warm regardless of how long the AC is on for.
brycec is offline
post #10 of 12 Old 05-17-2012, 01:13 PM
critmuncy99
U better stick with a tahoe.The 4.0 Engines in these jeeps are crap.I should have keep my VW beetle.
(J-E-E-P) Chew Them Up And Spit Them Out The Other End (J-E-E-P)
critmuncy99 is offline
post #11 of 12 Old 05-17-2012, 09:16 PM
ibjeepin95
Seriously? Someone needs their man card pulled.
ibjeepin95 is offline
post #12 of 12 Old 05-17-2012, 10:18 PM Thread Starter
Bigdog7373
Well i dont know about them being crap lol. But i have heard they are prone to leaks and top end problems. Also it seems like if i were to lift it 4.5" like my intentions were, i would end up getting the same gas mileage as the lifted tahoe anyway. So i might as well get the bigger truck right?
air conditioning???? jwrangler91 XJ Cherokee Technical Forum 8 07-21-2010 11:40 AM
More air conditioning help Beater XJ Cherokee Technical Forum 3 08-06-2007 11:37 AM
Air Conditioning FrumpD63 XJ Cherokee Technical Forum 18 05-09-2007 07:21 AM
Help with Air conditioning scubaman XJ Cherokee Technical Forum 1 06-08-2006 08:01 PM
Air Conditioning?? JPNWXJ XJ Cherokee Technical Forum 0 03-13-2006 12:07 AM
