New lift kit or fix the existing one? - JeepForum.com
post #1 of 2 Old 04-30-2012, 03:18 PM Thread Starter
CJSport
I bought a 2001 XJ it has a lift but needs
1. track bar
2. pitman arm joint
3. sway bar liks
4. busghings
5. steering damper
I do not know what size lift i have I think its a 4 inch lift maybe a 3 my question is I'm looking at an 800 dollars in parts to keep the existing lift or should I spend another 3 and get a skyjacker 4" kit for 1125.000?
Do most lift kits come with all of the parts Ive listed above or will I still need to buy anything listed in 1 through 5?
CJSport is offline
post #2 of 2 Old 04-30-2012, 03:24 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Where in the hell are you getting your prices at ?
I pieced together a 3.5" RE lift with full leafs for $685 including Bilstein 5100 shocks !
All of the parts you listed should run you 3-400 at most
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
Adding a Budget Boost to an Existing Suspension Lift jeepin_in_a_94 XJ Cherokee Technical Forum 6 02-22-2012 04:49 PM
Can i get projectors for my existing h4 hid kit? jackdup XJ Cherokee Technical Forum 0 02-17-2010 09:06 PM
Adding Coil spacer to existing RE 3.5" sf.... tdogg55555 XJ Cherokee Technical Forum 8 02-01-2009 02:13 PM
Extra lift on my existing one? Skatertony528 XJ Cherokee Technical Forum 11 11-16-2008 11:58 AM
Options for adding 2" to my existing OME kit? 330LICIOUS XJ Cherokee Technical Forum 1 10-31-2006 03:36 AM
