Aftermarket drive shaft question - JeepForum.com
post #1 of 9 Old 06-18-2013, 03:38 PM Thread Starter
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
I just installed a SYE. I think I am going to end up just using a stock XJ front drive shaft in the rear for now if I can and then upgrade when I have the cash
So, my question is. . . If I only upgrade one of my drive shafts, which one should it be? Front or rear and why? In a perfect world where I wasn't always broke or one that had aftermarket drive shafts for less $400 damn dollers I would just upgrade both. Unfortunately I do not live in that perfect world.
koolaid5 is offline
post #2 of 9 Old 06-18-2013, 05:17 PM
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
I'm running a stock front DS in the rear until it breaks then ill upgrade. When I did my LAs I had to get an extended front DS. I haven't had any issues running an aftermarket front DS and stock front DS in the rear.
April 2014 & 2015 COTM
MOBBiN is offline
post #3 of 9 Old 06-18-2013, 05:35 PM
sluff28
1975 CJ5
if I didn't already have the ds that's what I would have done a JY front shaft in the rear until money was avail then upgrade the rear first.
sluff28 is offline
post #4 of 9 Old 06-18-2013, 06:21 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Crap, I wonder if I will need a longer front drive shaft. I just installed T&T long arms up front and haven't checked to see if the stock driveshaft will work yet.
koolaid5 is offline
post #5 of 9 Old 06-18-2013, 06:22 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
What aftermarket drive shaft did you pick up? And how much was it?
koolaid5 is offline
post #6 of 9 Old 06-19-2013, 05:59 AM
DNFJ
I would upgrade the rear shaft first. It's less protected, and will see more duty/use than a front DS will. Unless you drive around in 4wd all day.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #7 of 9 Old 06-19-2013, 06:01 AM
bob6987
my front tom woods drive shaft was only 220 shipped.
1991 YJ, 4.0, 6" lift, 40" tires, full cage, dana44/ford 9, detroit locker, 5.38 gear
2012 JKU
bob6987 is offline
post #8 of 9 Old 06-19-2013, 06:34 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
How did you find that deal?
koolaid5 is offline
post #9 of 9 Old 06-19-2013, 10:24 AM
MOBBiN
MOBBiN's Avatar
They are less protected but they are easier to change and stock front DS's are inexpensive. I've bought 3 and never paid more than 25$ each. If money is an issue upgrade when you break one.
MOBBiN is offline
