Adding a lift to existing lift?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > Adding a lift to existing lift??
ZONE 4.25" combo lift for TJ available at Rockridge4wJeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinRIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 08-31-2014, 10:39 PM   #1
lzugl
I have a 90 Cherokee with a 4.5' rough country lift sitting on 33 toyo mts. I was wondering how i should go about getting my lift up to about a 6' with out buying a new lift and also a ballpark on how much it would run if possible.
lzugl is offline   Reply With Quote Quick reply to this message
Unread 09-01-2014, 08:11 AM   #2
Motorcharge
1992 XJ Cherokee
Why do you need 6" of lift? It will depend on what you've got now, but you're looking at pretty much a complete overhaul of the suspension and steering to get to 6".
|Project Motörcharge|
Motorcharge is offline   Reply With Quote Quick reply to this message
Unread 09-02-2014, 03:54 PM   #3
sAe23
1995 XJ Cherokee
You could add a shackle relocation bracket. With extended shackles it would net you up to about two inches.
Then you just add a 2" coil spacer up front...
...and then add longer brake lines and cables, longer control arms, adjust your track bar (it IS adjustable, right?), new leaf shims, maybe need a drop pitman arm. etc etc etc.
If your 33" tire fit under the 4.5" lift now, I'd just say leave it, or trim the fenders if there is some clearance issues.
sAe23 is offline   Reply With Quote Quick reply to this message
Unread 09-02-2014, 08:02 PM   #4
chris87xj
Jeepaholic
chris87xj's Avatar
1987 XJ Cherokee
The difference between 4.5 and 6" is where things get expensive.
You'll also want longarms at that height.
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
COTY 2009
Originally Posted by cruiser54 View Post
Better to hoard Jeep technical info than old newspapers and the neighbor's mail, I guess.......
Vote here NOW in the September Cherokee Of The Month contest!!!
chris87xj is online now   Reply With Quote Quick reply to this message
Unread 09-03-2014, 10:15 AM   #5
DunmerBoy
eXJpedition
DunmerBoy's Avatar
just get some bushwacker or similar fender flares for extra clearnece
We are a group of individuals that worship a box shaped unibody that's been out of production for over 13 years. There's no shame to be had here. :D
- Build Thread -
DunmerBoy is offline   Reply With Quote Quick reply to this message
