??? about dynamat and heat.... - JeepForum.com
post #1 of 9 Old 09-02-2013, 02:50 PM Thread Starter
Cowboy_Elvis
So, I want to pull the carpet out of my 98 xj and think line it. I heard from my bud that his jeeps floor stayed really hot due to the less insulation. If I put down dynamat, would that work and think line over it?
Cowboy_Elvis is offline
post #2 of 9 Old 09-02-2013, 03:30 PM
LimeLJ
LimeLJ's Avatar
I would actually recommend getting some DEI heat shield and putting it underneath above the hot spots.
2004 Jeep Wrangler Unlimited
1997 Jeep Comanche - 4.7L Stroker, Lifted, "Restored", and soon to be supercharged.
LimeLJ is offline
post #3 of 9 Old 09-02-2013, 07:19 PM
XJmike0122
I'm not sure why but I have a feeling that would be a bad idea.
XJmike0122 is offline
post #4 of 9 Old 09-02-2013, 09:43 PM
mschi772
1997 XJ Cherokee
This isn't about the heat really, but the fact that you mention Dynamat by name means that you probably don't know that there are products just as good that aren't a rip-off and that you're probably planning to erroneously line 100% of the surface in the dampening material. Have a look at SoundDeadenerShowdown.com before you waste time and money.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #5 of 9 Old 09-03-2013, 05:20 AM
XJmike0122
™Glad you know about "think line" WTF is think line?????
post #6 of 9 Old 09-03-2013, 08:05 AM Thread Starter
Cowboy_Elvis
Hahah rhino line, damn auto correct, but I just wasn't always sure if dynamat was the best, I guess I can look into heat shields as well
post #7 of 9 Old 09-03-2013, 08:11 PM
raypla
Link is in my sig, the damp works pretty good, plan on doing doors and hatch and this and that. In the summer when wearing shorts my legcan touch the tran tunnel without getting seared, at operating temp, road noise was reduced significantly. Once you get start quieting one spot the place you don't have covered sounds like a megaphone. You're warned. Make sure you spray some self etching primer on any shining damplifier before coating with bedliner, if you want it to adhere.
99 XJ 4.0 D30 29sp 8.25, IRO TB & HD Tie Rod, Kellys WIP main 5 wires 1AWG
, Banks header, Stainless Magnaflow catback, cat, 2" OME lift, JC1B Leafs, OME sports, JKS discos, 30X9.5X15 BFG AT's, Fastman 62mmTB, Cibie E-codes with 55/60 Osram bulbs, Putco harness=JUNK!!, Alpine 7563 Deck, PWX 10" Cubby, JBL GTI 180.2 400wX1 rms, 6.5 Infinity Perfects , front PWX 6.5, Infinity ref amp 111wX4 rms, Optima Yellow, 100 sqft of
raypla is offline
post #8 of 9 Old 09-03-2013, 08:18 PM
jeepster383
Make sure to pull the full exahust heat shield from a grand cherokee and install it on you're cherokee. I rhino lined my xj and after a day of wheelin the floor got so hot around the muffler It melted my rhino line to the back seat floor mat. Also when it got hot it would put off a nasty smell. After the full heat shield no problems. Although my tranny tunnel does give off annoying heat and there is more road noise. But I like it.
jeepster383 is offline
post #9 of 9 Old 09-04-2013, 06:55 PM
raypla
The Damplifier I used is safe to +400*. Good ***** but not cheap. I've had not a problem but that might not be the case with other kinds of damp. Steer clear of some less expensive, asphalt based, products.
Do it right and do it once!!
raypla is offline
