AAL or shackle - JeepForum.com
post #1 of 15 Old 06-25-2008, 10:49 PM Thread Starter
Undecided
AAL or shackle
im wanting to do a simple lift on my xj. looking for 2-3 and im not sure if i want to do 3" aal, or just go the cheap route and do a 2" shackle and spacer. what would some of you recomend cause im putting a set of 235/75/15's on it.
Undecided is offline
post #2 of 15 Old 06-26-2008, 12:40 AM
XJKipp
1995 XJ Cherokee
I'd recommend the aal, it may sag over time, but the combination of a shackle and a spacer will place a lot of stress on the spring pack...just my 2 cents
1995 XJ Country
3.5" Full Traction w/ HD leafs
31x10.50 BFG M/T KM2...see specs
Georgia Institute of Technology
Ramblin' Wreck from Georgia Tech
XJKipp is offline
post #3 of 15 Old 06-26-2008, 05:47 AM
XJ_Austria
1994 XJ Cherokee
in any case go with a long aal.
XJ_Austria is offline
post #4 of 15 Old 06-26-2008, 08:29 AM
MBJR9
I agree. The short AAL's tend to give a harsher ride from what I've heard.
The XJ
1996 XJ Sport, 4.0L HO I6, AX15 5 Speed, NP231, Dana 30/35, Flareless
The Daily Driver
2004 Ram 1500, 5.7L Hemi V8, 545RFE 5 Speed Auto, NP241, Chrysler 8.0/Chrysler 9.25, 10mpg
MBJR9 is offline
post #5 of 15 Old 06-26-2008, 09:59 AM
XJ_Austria
1994 XJ Cherokee
Also the short AAL stress the upper leaf to much at the eye area and they tend to break there when flexing.
post #6 of 15 Old 06-26-2008, 08:35 PM
JeepRide
JeepRide's Avatar
Thumbs up
Long aal with 30x9.50x15 tires
98 xj 4.0L 231 / aw4 /8.25/3.55
31x10.50 a/t 3 inch bastard lift
JeepRide is offline
post #7 of 15 Old 06-26-2008, 08:42 PM
camjeep3
1988 MJ Comanche
shackles. aal sag. or do a custom bastard pack
2011 Chevy Silverado ext cab z71
1988 JEEP Comanche 4x4 shortbed:
4.0L w/ 5spd
6inch RE lift w/ Spring over-8.8 aussie locker and 4.56s
High School Jeepers #15
camjeep3 is offline
post #8 of 15 Old 06-28-2008, 11:36 PM Thread Starter
Undecided
i was reading about the bastard pack and am thinking of doing that with a new set of springs. now if i only do about 2-3" would i need to get longer brake lines, and an drop pitman arm. cause i want to do it as cheap as possible.
post #9 of 15 Old 06-29-2008, 02:37 PM
XJ_Austria
1994 XJ Cherokee
full leaf packs are always best but most expensive. If you wheel it off road, go with longer brake lines. Drop pitman arm you do not need for 2-3" lift, just forget it.
post #10 of 15 Old 06-30-2008, 12:10 AM Thread Starter
Undecided
i wont be doing a lot of wheeling mostly just driving it, just want to do a small lift for the clearance for the slightly bigger tires. thats why i only want to do a 2-3" lift.
post #11 of 15 Old 06-30-2008, 12:14 AM
justinwalden
a bastard pack for 2" = AAL?
Tennessee, Tennessee, There ain't no place I'd rather be!
justinwalden is offline
post #12 of 15 Old 06-30-2008, 12:41 AM
jcc522
dont do anything to it. i run those tires with no rub at all
jcc522 is offline
post #13 of 15 Old 07-01-2008, 09:41 PM
CheyenneK5
X2
For Every One Person with a Spark of Intelligence, There are 100's with Ignition Trouble
The Comments made by this Person are in NO way meant to Offend anyone, they are the opinions of a single person and if they piss you off then sorry about your luck
CheyenneK5 is offline
post #14 of 15 Old 07-01-2008, 10:07 PM
RockRodHooligan
RockRodHooligan's Avatar
I say shackle, it's something that you can still benefit from even if you decide to go with full spring pack later. I went with a ProComp full spring pack, got them from 4 Wheel Parts about a year ago for $90 for both.
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #15 of 15 Old 07-02-2008, 01:00 PM
FooK
FooK's Avatar
Eh, I strongly advise a leaf pack.
1. Your springs are already worn and sagged.
2. AAL's, Shackles, Blocks will all expedite the complete sagging out of your leafs
3. A lift shackle will kill your shackle angle and ruin your ride quality
4. Blocks will increase the occurence of spring wrap and could cause yoke/driveline damage, as well as sag out the leafs
5. AAL's can put stress near the eye of the spring and cause negative arch in the main leaf and potentially break the main leaf.
Here is a wise suggestion.
Get a 3"-3.5" leaf pack. RE's are like $175 each + $70 or more shipping. I do Tuff Country's 3" pack for $159.99 and if you're interested in them I will ship them for free ($319.98 total)
1. PM me and I'll give you a checkout coupon code for the free shipping.
2. Tuff Country's are a decent spring, fairly soft riding, and have a lifetime warranty. I installed a set yesterday actually.
3. UPGRADEABILITY! When you're ready for 4" of lift, you can add a shackle relocation kit. Brianho13 on NAXJA makes a kit for this. http://www.naxja.org/forum/showthread.php?t=956630
4. UPGRADEABILITY! When you're ready to go any higher, a 1-1.5" lift shackle will get you to 5.5-6" and you'll have adjustability in your relocation kit to keep your shackle angle.
This would be a really good way to go about it. Obviously an extra $320 for leafpacks isn't in everyones budget, but in 6 months - 1 year when your add-a-leaf or block has mutilated your factory leaf packs, you'll be wishing you bit the bullet. I know I did.
Jason Roy - Marketing Director at WP
Driver #1724 Team WP Jeepspeed
Co-Driver #36 ERS Rally Team
FooK is offline
AAL or Shackle?? NHCOP XJ Cherokee Technical Forum 5 02-23-2008 05:49 PM
Tnt shackle ?? gradysjeep XJ Cherokee Technical Forum 4 02-06-2008 02:41 PM
shackle?? XbajaJeepX XJ Cherokee Technical Forum 1 03-11-2007 05:27 PM
shackle bolt stuck to shackle bushing. where to make cut in bolt? tron XJ Cherokee Technical Forum 6 12-12-2005 04:57 PM
shackle help johnisawesome XJ Cherokee Technical Forum 3 03-25-2005 01:23 AM
