'99 Sport Build Thread: Grocery Haulin' With Panache - Page 3 - JeepForum.com
 1Likes
post #31 of 354 Old 05-23-2011, 06:19 PM
Vassago
i want to rip out my hack-n-tap now and get that shaft!
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD:
My Photography
Vassago is offline
post #32 of 354 Old 05-24-2011, 09:31 PM
VTEK1
Where did u get that sye setup, sorry didnt read anywhere you got it.
Only in a Jeep
MΘΣΝΔ ΚΘΒΦΘΡ
VTEK1 is offline
post #33 of 354 Old 05-24-2011, 10:40 PM Thread Starter
PhilipJ
PhilipJ's Avatar
Ah, I guess I did forget that part. I got it from Tom Wood out of Ogden, Utah. Here's a direct link to all of their case options: http://4xshaft.com/SYE_detail.html
Just call them up and tell them what you need, they know their stuff and put out a great product. There's a lot more options for the 231 than the 242, but I opted to keep it since I do a lot of driving in the passes during the winter where the 4H Part-Time really shines.
PhilipJ is offline
post #34 of 354 Old 07-01-2011, 04:21 PM Thread Starter
PhilipJ
PhilipJ's Avatar
Haven't done a whole lot lately, but more parts are slowly starting to trickle in. Picked up a 3' Firestik antenna, Uniden Pro 538W CB and 18' of Firering coax. I also have some Bushwacker front flat fenders coming sometime today, but need to get some metal trimming stuff before I tackle that. Crown extended brake lines should be here Tuesday.
I did get something installed though. Factory short-arms are really kind of a hindrance with the ACOS, because they don't allow for enough droop to take the weight off the coils so that the rings can be adjusted (unless you have near factory-height coils). They simply 'bottom out' on the axle mounts, requiring you to either use coil compressors or unbolt the arms. Since it's a huge pain in the *** to line up the axle and rebolt those with the coils already in, I opted to rent some compressors from Auto Zone. Took just over an hour and now I can dial in the height to accommodate the 150+ lb bumper/winch combo going on soon.
Yay, shiny new ACOS
Booooo, crappy old stacked spacers (1.75")
Pretty easy to install, just cut level with the internal washer...
...then hit it with some spray paint to keep the rust away, slide it on and bolt it in
PhilipJ is offline
post #35 of 354 Old 07-01-2011, 04:32 PM
MagicNelson
Wow this build is top notch! I'll be following closely
MagicNelson is offline
post #36 of 354 Old 07-01-2011, 05:10 PM
GregB_00XJ
Looking good man!!
This Jeep is turning out pretty sweet Phillip.
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #37 of 354 Old 07-02-2011, 10:08 AM
Brookhart63
When your rear suspension cycles, wouldn't it bend and or hit your exhaust? Maybe I'm missing something
Bought not Built
Jeep Outdoor Club of Cental Iowa
Square Headlight Jeep Club
Brookhart63 is offline
post #38 of 354 Old 07-02-2011, 02:27 PM Thread Starter
PhilipJ
PhilipJ's Avatar
I solved that by having the exhaust turn down just before the rear axle. There was a random factory hole in the chassis just above the outlet which made for a perfect mounting point for the Super 44. At 14 lbs it's a heavy bastard, but I won't have to worry about anything bashing it in on the trails.
I should mention that having it set up like this sets off *a lot* of car alarms.
PhilipJ is offline
post #39 of 354 Old 07-11-2011, 06:05 PM Thread Starter
PhilipJ
PhilipJ's Avatar
Threw in some new Crown brake lines today; about 6" longer than stock. Fronts are 26" and the rear is 21" I believe. No problems, no stripped bleeders or anything else but the upper rear retaining clip was a pain to get off. My first time bleeding brakes and no fiery crashes of death so far, so I'm guessing I did it right.
Also got my Bushwacker flat flares in, but I need to track down a jigsaw before I tackle that. Don't quite trust myself with an angle grinder on body panels.
Just re-used the stock mounting location and Torx
Nice and firm, they stay in place and don't flex into the tires at full lock
The amount of dirt and crap I removed from around the original t-block was unreal
PhilipJ is offline
post #40 of 354 Old 07-12-2011, 06:26 PM
GregB_00XJ
Looking good man... very good. Love the ACOS.
____=__=
l l ,[_____],
()_) ()_)--o-)_)
post #41 of 354 Old 07-13-2011, 08:18 PM
K-R
great ideas on here, subscribed.
i have the 3.5: dirk/ome kit and 31's with a transfer case drop... i get the womwomwomwomwom 24 x 7 :-) i always thought it was just the tire sound, though. keep up the good work!
'bout all I know... minin' coal.
K-R is offline
post #42 of 354 Old 07-13-2011, 09:49 PM Thread Starter
PhilipJ
PhilipJ's Avatar
Thanks, Greg. When are you going to bring your rig down here so we can take some of that showroom-shine off of it on the trails? I'm going to Evans Creek this weekend, so we'll see how much body damage the XJ can avoid (will get some pics and video).
I forgot DPG even carried OME kits when I ordered mine, but all I really missed out on were their included swaybar cables. I didn't need anything super-fancy as I just wanted a simple quality kit to clear 31's so that I could go play this year until I can afford a regear and move up to a taller lift and tires.
Driveline vibe is very chaotic; it's never really the same for any vehicle even if they have the same components. It wasn't nearly as bad as it was in my YJ, so I wasn't as concerned driving around for a few months before getting the SYE kit. Whether you get a resplined mainshaft or hack-n-tap your own, it should be a required upgrade for anyone intending to go offroad unless you really love replacing u-joints.
PhilipJ is offline
post #43 of 354 Old 07-15-2011, 03:38 PM Thread Starter
PhilipJ
PhilipJ's Avatar
Just needs some light tabs and it'll be on its way...rear w/carrier will be right behind it.
PhilipJ is offline
post #44 of 354 Old 07-15-2011, 08:18 PM
GregB_00XJ
Sweet bumper... you can use your winch to pull my Daily Driving Arse out of the mud when we get out for a rip sometime!
____=__=
l l ,[_____],
()_) ()_)--o-)_)
post #45 of 354 Old 07-19-2011, 04:47 PM
jj88jeep
1988 XJ Cherokee
Very sweet build!!! I will have to look into the SYE kit later on, I have the NP 242 also.
jj88jeep is offline
My 98 Sport Build Thread broncofire75 XJ Cherokee Technical Forum 263 11-30-2012 09:44 PM
Jeep450r's 1996 Sport Build Thread Jeep450r XJ Cherokee Technical Forum 20 02-14-2012 03:16 PM
1993 Cherokee Sport Build Thread...kinda Jcool XJ Cherokee Technical Forum 0 03-06-2011 11:09 PM
XJ HAULIN' Pictures !! ATS XJ Cherokee Technical Forum 8 10-10-2004 08:11 PM
