'99 Sport Build Thread: Grocery Haulin' With Panache - Page 18 - JeepForum.com
post #256 of 352 Old 08-27-2012, 09:55 AM
GregB_00XJ
Nice clean install, and good call on the hole saw... how often will you use a 5" hole saw anyhow?
Might grab one of these, or the dreaded Specter. Pics of the hood installed?
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #257 of 352 Old 08-27-2012, 03:35 PM Thread Starter
PhilipJ
PhilipJ's Avatar
Moar pics. Sorry about the red crap, I think this camera is starting to give up the ghost.
Here's the little bracket you have to trim down for the evap solenoid. It reuses the same holes and shares them with the heat shield.
PhilipJ is offline
post #258 of 352 Old 08-27-2012, 04:38 PM
GregB_00XJ
Looking good man. Did you paint the hood yourself with a rattle can of colour match? Or did you swap the vents to your hood (more likely).
I love the ORF rear quarter protection, nerf bars and all.
____=__=
l l ,[_____],
()_) ()_)--o-)_)
post #259 of 352 Old 08-27-2012, 05:00 PM Thread Starter
PhilipJ
PhilipJ's Avatar
I just swapped the vents over. The other hood's PO had the lines cut a little too close to the upper edge (along the 'bottom' edge of the vents in the pic) and into the support, so he had to crimp some of the metal back. I got the appropriate measurements from a youtube video and it came out fine.
Yeah the armor is very solid. I stood on one of the rails, shifting my weight up and down and it feels as if it's welded on there. I'll have no qualms about rigging my hammock up to it for camping over the holiday weekend.
PhilipJ is offline
post #260 of 352 Old 08-27-2012, 08:42 PM
GregB_00XJ
Send me that video link! lol
Looks good man.
Greg
____=__=
l l ,[_____],
()_) ()_)--o-)_)
post #261 of 352 Old 08-27-2012, 09:33 PM
lDlH
O_o. Nice thread and good lookin jeep
lDlH is offline
post #262 of 352 Old 08-28-2012, 03:55 AM Thread Starter
PhilipJ
PhilipJ's Avatar
Thanks!
I think it was this video...the guy tends to ramble a bit and he doesn't actually film the cutting or installation but all you really need are the numbers anyway. I basically went 5-1/2" down from the center, then 3" out on either side to mark the upper inner corners.
PhilipJ is offline
post #263 of 352 Old 08-29-2012, 11:14 AM
Bronco1138
Originally Posted by PhilipJ View Post
Thanks!
http://www.youtube.com/watch?v=stjfXphiaSI
thanks for posting the vid, I was looking to do the vents as well!
Current 2000 Green XJ w/ Flowmaster 40 exhaust, magnaflow high flow cat, bbk 62mm throttle body, Rusty's TBS, K&N Intake, Hella Euro H4 Headlights, OME Steering Stabilizer, 3.5" RE super flex kit, RE trac bar, 32" Tires on the way....
SOLD 2001 silver XJ w/4.5" RE Lift, 33", Long Arm, Locked, etc.
Bronco1138 is offline
post #264 of 352 Old 09-01-2012, 05:37 AM Thread Starter
PhilipJ
PhilipJ's Avatar
No problem. I took my hood off so as to avoid cutting into anything underneath (the cowl intake tube is only about 1/8" from touching) and to prevent my windshield from being peppered with hot little pieces of metal. It also made it a bit easier to work on at waist level. It's not very difficult to remove or put back on, but you'll definitely want an extra set of hands (and socket/wrench) as it's a bit unwieldy.
Of course I got them installed right as the temps have dropped from the 90's back down into the 70's, but that's okay. Normal running temp now is right around 205° -- I can tell because the two e-fans that come on at that temp shut off almost immediately after I kill the engine as opposed to the couple of minutes they would run before. Running my A/C now pushes it to exactly 210°. I can probably improve on that just a little bit more once I get the new fan shroud in, I just haven't set aside the time to dig in and do it yet. I'm hoping I don't have to drain the coolant and remove the radiator...I've done it too many times this year already.
PhilipJ is offline
post #265 of 352 Old 09-04-2012, 01:34 AM Thread Starter
PhilipJ
PhilipJ's Avatar
Originally Posted by NW99XJ View Post
Hey Man! When are you gonna get out and give us some serious flex shots!?!?!?
Got out a little this weekend, this was the best I could do. Ran out of stump, but my passenger coil was almost completely off the ACOS anyway. Not bad for a slightly modified 3" kit.
PhilipJ is offline
post #266 of 352 Old 09-04-2012, 01:37 AM
MCObray
That is filthy man.
1994 Dodge Ram 2500. 12V Cummins Turbo Diesel.
MCObray is offline
post #267 of 352 Old 09-05-2012, 01:02 PM
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
Those last two pictures are badass.
14JK -
98XJ
Past - 95YJ 99XJ 98XJ 05WK 94XJ
biggn235 is offline
post #268 of 352 Old 09-05-2012, 02:02 PM
NW99XJ
SECOND FROM THE BOTTOM.....
BLOW THAT ONE UP FOR A POSTER!!!!!
Lookin good man.
5+" of lift, 33's, OTK, Armored, Lighted, Chipped, Winched & Locked up Front.
NW99XJ is offline
post #269 of 352 Old 09-05-2012, 02:21 PM
Weeder1
Whats your front setup consist of?
How do u like the acos, do the threads look strong?
And what bumper is that?
Lol looks good man
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline
post #270 of 352 Old 09-05-2012, 03:19 PM
alexrule123
alexrule123's Avatar
Lol looks good man
I can answer that about the acos. I have jumped my jeep to the point of bending my Dana 30 and they acos were not damaged at all.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
My 98 Sport Build Thread broncofire75 XJ Cherokee Technical Forum 263 11-30-2012 09:44 PM
Jeep450r's 1996 Sport Build Thread Jeep450r XJ Cherokee Technical Forum 20 02-14-2012 03:16 PM
1993 Cherokee Sport Build Thread...kinda Jcool XJ Cherokee Technical Forum 0 03-06-2011 11:09 PM
XJ HAULIN' Pictures !! ATS XJ Cherokee Technical Forum 8 10-10-2004 08:11 PM
