'99 Sport Build Thread: Grocery Haulin' With Panache - Page 15 - JeepForum.com
post #211 of 352 Old 03-25-2012, 04:32 PM Thread Starter
PhilipJ
PhilipJ's Avatar
Well, I got the Lock-Right installed. It was pretty easy and straight-forward up until I broke a bolt when re-torquing the ring gear back on the carrier. Always use new bolts! Thankfully, I was able to back it out with an extractor and a little bit of heat. It's surprising how few hardware stores carry 3/8" Grade 8 with fine threads. Finally found them at Ace but not quite the right length, so I got the slightly longer ones and trimmed them down on a bench grinder.
It's perfectly quiet on pavement except while making slow, sharp turns. I heard it click a few times in a parking lot but that's it. Can't wait to try it on the trails!
PhilipJ is offline
post #212 of 352 Old 03-26-2012, 09:18 AM
GregB_00XJ
Sweet!!
Lockered up.
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #213 of 352 Old 03-26-2012, 10:14 AM
NW99XJ
Well this report has helped me decide which direction to go when it comes time to lock up.... Now, lets see if I can get a deal like YOU did!
5+" of lift, 33's, OTK, Armored, Lighted, Chipped, Winched & Locked up Front.
NW99XJ is offline
post #214 of 352 Old 03-26-2012, 05:03 PM Thread Starter
PhilipJ
PhilipJ's Avatar
I was a bit rushed so I didn't manage to get any pics, but since I have new Spicer bolts for the ring gear and a Solid diff cover coming soon, I'll do a mini write-up when they arrive. Now that I know all of the socket sizes and torque specs for every bolt involved, a quick tear down and re-install should be a breeze.
PhilipJ is offline
post #215 of 352 Old 03-27-2012, 12:02 AM
XabuJr
XabuJr's Avatar
1992 XJ Cherokee
Should be faster than a YJ rear bumper..
XabuJr is offline
post #216 of 352 Old 03-27-2012, 12:36 AM Thread Starter
PhilipJ
PhilipJ's Avatar
You should probably PB every single bolt on that thing that you plan on touching in the near future. At least the ones you broke were mostly non-essential to needing to withstand any sort of deflection. Welding those tabs right to the cross member would probably be just as strong.
PhilipJ is offline
post #217 of 352 Old 04-21-2012, 06:09 PM Thread Starter
PhilipJ
PhilipJ's Avatar
Been pretty slow lately (unemployment for a while) but I just landed a new job so hopefully I get some more goodies rolling in soon.
Replaced the thermostat the other day because my temps were creeping up to just a hair over 210 and it never gets that high. I think the factory one was still in there as it had the Chrysler logo and the old gasket had somehow bonded to the metal at a molecular level. A new 195-degree Stant Superstat dropped it to right around 205. Also picked up ORO's LED LitePlate which I hope to get installed this weekend.
Did this today since it was so nice out...Spicer 5-760x u-joint replacements. I think the old 297's were factory as well. You know it's bad when you take half the caps off and there's no needle bearings. Strangely, I never noticed any major clunking or anything.
I know the upper boot is torn, I ordered replacements but they're too short.
PhilipJ is offline
post #218 of 352 Old 04-21-2012, 06:51 PM
alexrule123
alexrule123's Avatar
Mine were the same way, lots of rust dust but not so many needle bearings
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #219 of 352 Old 05-04-2012, 02:55 AM
GregB_00XJ
Congrats on the job man! You staying put in T-Town for now, or headed up closer to my neck of the woods as discussed when I was down there? Jeep is sounding like it should be running pretty schweet right now!!
I think mine needs U Joints too, mine look old and sketchy.
____=__=
l l ,[_____],
()_) ()_)--o-)_)
post #220 of 352 Old 05-04-2012, 03:39 AM
robd2003
I take it you went to a larger ujoint on the axle shafts?
Jeeps:
99' XJ<->5.5" Lift; 35's; SYE; Winch; much more goodies too
02' WJ<->Rebuilt from wreck, still stock
robd2003 is offline
post #221 of 352 Old 05-04-2012, 07:07 AM Thread Starter
PhilipJ
PhilipJ's Avatar
Thanks. I'm working just down the road at Weyerhaeuser. The type of work is nearly identical to what I did with steel, except with lumber and some occasional rebar or meshing. Tons of overtime opportunity, which I haven't had in forever. I'll probably be staying put for a little while until I figure out where exactly I want to relocate to. Definitely somewhere north and/or east of Seattle though, and hopefully with the chance of relocating within the company.
Jeep is running great, but my temp still creeps up just over 210 and drops back down once in a while even though its new nominal range after the t-stat replacement keeps it at 200-205. I'm guessing it's the water pump which is the factory unit, so it's up next for replacement soon. Pep Boys has a nice Bosch unit for $38.
They're actually about the same size, but the 760's are cold-forged instead of hot-forged like the 297's, so they are definitely stronger over the life of the joint. The only drawback is that they aren't greasable, but I don't play around in the soupy mud or water too much anyway. If they can hold up half as long as the stock ones did (until I get chromoly shafts) I'll be happy.
PhilipJ is offline
post #222 of 352 Old 05-04-2012, 08:54 AM
GregB_00XJ
Sounds like a good place to land man. Congrats again.
I hear that the greasable U Joints are not as strong as the non ones are?
____=__=
l l ,[_____],
()_) ()_)--o-)_)
post #223 of 352 Old 05-04-2012, 01:02 PM
robd2003
Ahh okay, i just got a 99 xj on 35's in trade and 200$ so im looking at the small things to actually help hold up to 35's. it came with a HP30/C8.25 combo
Jeeps:
robd2003 is offline
post #224 of 352 Old 05-28-2012, 06:25 PM Thread Starter
PhilipJ
PhilipJ's Avatar
PhilipJ is offline
post #225 of 352 Old 05-28-2012, 06:43 PM
GregB_00XJ
^ that blows goats.
____=__=
l l ,[_____],
()_) ()_)--o-)_)
My 98 Sport Build Thread broncofire75 XJ Cherokee Technical Forum 263 11-30-2012 09:44 PM
Jeep450r's 1996 Sport Build Thread Jeep450r XJ Cherokee Technical Forum 20 02-14-2012 03:16 PM
1993 Cherokee Sport Build Thread...kinda Jcool XJ Cherokee Technical Forum 0 03-06-2011 11:09 PM
XJ HAULIN' Pictures !! ATS XJ Cherokee Technical Forum 8 10-10-2004 08:11 PM
