'99 Sport Build Thread: Grocery Haulin' With Panache - Page 12 - JeepForum.com
post #166 of 352 Old 02-02-2012, 07:02 PM Thread Starter
PhilipJ
PhilipJ's Avatar
Originally Posted by GregB_00XJ View Post
Looking good Phillip.
I will be in T Town again soon for a visit with Mom. Would be great to meet up this time! Will give you a heads up and maybe we can make it work?
LOVE the fans.
Definitely.
I'm not real busy on the weekends other than being in Seattle for a couple of hours on Saturday afternoons for my flag football league. I'm usually back in town by 4-ish.
The fans have been great. On average they keep the temp a few degrees cooler than the stock setup; right around 205 or so. Also picked up a new B&M stacked plate trans cooler; I roughed up the Hayden one in the process of the fan install. I didn't really like how it mounted anyway, this one I can bolt straight to the header without having to zip-tie through the radiator (making future radiator work a lot easier.)
Originally Posted by alexrule123 View Post
I used the OME AAL in my OME pack and it netted 1" and it has stayed that way for over 6 months.
Good to know. I just torqued everything down and took it for a spin...it feels a lot more firm and stable in the back now. I really like how it rides. I can only imagine it'll be even better with 130 lbs of bumper giving it a little pre-load.
PhilipJ is offline
post #167 of 352 Old 02-08-2012, 10:24 AM
GtiKyle
I'm tagging along for a snow wheeling trip Saturday morning if your interested, up near Lonesome Lake. Hit me up if your interested in going.
1998 Cherokee, 6.5" LA, D30/C8.25 4.56 locked F/R, 35" MTR's, other goodies ...
Build thread :
GtiKyle is offline
post #168 of 352 Old 02-08-2012, 04:49 PM Thread Starter
PhilipJ
PhilipJ's Avatar
I'd love to, but Saturday I have flag football and then afterwards the bumper is going on. Got it prepped and painted last Saturday (but no pics of the progress.)
And a random driveway shot to see how much I still need to bring up the front end. I couldn't get any consistent measurements to go off of, so I figured around 1"-1.25" via eyeballs.
PhilipJ is offline
post #169 of 352 Old 02-14-2012, 10:41 AM Thread Starter
PhilipJ
PhilipJ's Avatar
Finally got the rear bumper (AJ's Tanker w/tire carrier) on this weekend. Ran into a bit of a problem while removing the gas tank skid bolts. The very last one on the driver's side (closest to the front) snapped off leaving most of it still exposed above the nut strip. This wouldn't have been a problem on the passenger side, but the fuel hoses run over the top on the driver's side and there's a little bridge of metal welded over the channel. The damn bolt was too tall and couldn't slide under it, so after trying a million different things, we finally dremeled the welds, pried up the plates a little and zipped off the top of the bolt with my angle grinder.
Everything else went pretty easy, except I can't reuse my stock gas tank skid. Its mounting 'rails' are too wide and interfere with the bumper's strengthened 'L'-shaped guide rails, (as you can see in the pictures of my previous post) so unless I trim the hell out of the skid's rails (too much effort) it's not going back on. I've been thinking about getting an aftermarket one anyway, so win/win. Stock skid for sale!
Just a few teasers until I get everything cleaned up a bit...
Timken tapered roller bearings for the hinge
And a sweet billet cap to cover everything up
1000 lb. adjustable latch handle
T-handle doing its job holding the open carrier in place. The hole also makes a great antenna mount location if you don't want to use it as a stop.
Rear quarter protection (I need a dry day to clean up the fender and hit it with some matched paint)
And thanks to AJ for the awesome bumper! I'm proud to have his stuff protecting every side of my XJ.
PhilipJ is offline
post #170 of 352 Old 02-14-2012, 11:04 AM
GregB_00XJ
Looking great man, love that rear bumper. That tank skid would make a sweet match for my awesome front skid!!
How muchy?
Next time I am headed that way I will give you a shout again. Might be in the next month now as my dad is in the hospital which postpones my trip this weekend.
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #171 of 352 Old 02-14-2012, 07:14 PM Thread Starter
PhilipJ
PhilipJ's Avatar
$25? No dents or anything and no stray bolts with nuts stuck on them this time but I'm out of black spray paint. You'll probably need a set of bolts and nut strips too...I destroyed mine taking them out. Damn factory Loctite.
PhilipJ is offline
post #172 of 352 Old 02-14-2012, 07:50 PM
GregB_00XJ
Deal. Will PM details...
____=__=
l l ,[_____],
()_) ()_)--o-)_)
post #173 of 352 Old 02-14-2012, 08:48 PM
GregB_00XJ
Oh and while disappointed that this will not come refinished and free... kidding.
I have a hitch installed and will be able to mount it under that using the nut strips I am already using.
Now, just need to get there?
____=__=
l l ,[_____],
()_) ()_)--o-)_)
post #174 of 352 Old 02-14-2012, 09:34 PM
doogie
doogie's Avatar
Lookin good man, continues to be a great build.
How long time wise did just the cut-n-fold take?
Nationalmssociety.org
Current = 1996 XJ, 2.5, 2-Door, 5-Speed, 4.88's, 3.5" Mix-N-Match, Black 15" KMC XD122's, 31" BFG AT's, RE QD's
Previous builds 99-XJ, 98-XJ, 89-XJ, 05-TJ, 95-ZJ, 79-J10
doogie is offline
post #175 of 352 Old 02-14-2012, 10:03 PM Thread Starter
PhilipJ
PhilipJ's Avatar
Well I could try, but I'd probably pass out mid-way though in the basement from lack of ventilation.
Thanks! Having that stock bumper back there forever really made it feel unfinished since I had every other side covered but the rear was just...nothing.
The cut-n-fold itself didn't take very long; maybe a half hour per side. There's a bunch of write-ups I found that went into a lot of technical detail with precise measurements and such, but really all you have to do is cut the material out between the inner and outer fender at the front and back in a triangle shape (leaving enough left for overlap) and then sandwich it together with seam sealer and your choice of self-tapping screws or pop rivets, then painting over. I used pop rivets and had some factory-matched paint that I ordered for my header (still need to paint that thing ugh) but really you can't see anything anyway unless you're underneath it. An angle grinder with a 4" cutting wheel and a Sawzall make a great combo for getting those tricky angles.
I might try to go over them with some sort of bed liner and/or some other protective material (maybe some aluminum sheeting or semi-pliable synthetic) to virtually eliminate any possibility of rust and keep the vibration/road noise down a little. It was kind of funny cutting the flares apart and pulling out stuffed bread loaf-sized black plastic bags...for sound dampening, not drug-running leftovers from the PO. Gonna check out the hardware store tomorrow for ideas.
PhilipJ is offline
post #176 of 352 Old 02-15-2012, 09:10 AM
BAR01XJ
Can you show a picture or give a description of how you addressed your flares when doing the cun and fold?
BAR01XJ is offline
post #177 of 352 Old 02-15-2012, 09:13 AM
GtiKyle
That rear bumper looks really nice! Keep up the good work.
Build thread :
GtiKyle is offline
post #178 of 352 Old 02-15-2012, 03:21 PM Thread Starter
PhilipJ
PhilipJ's Avatar
I just unmounted them during the cut-n-fold, but originally I was going to try to cut off the excess that hung below the fender and then try to reuse the tip by epoxying it back on to the cut. After looking at it though, because of that crease in the fender and the shape of the flare, it's really not possible. So I'm just going to cut it flat straight across (tomorrow, when I go back to my buddy's where my power tools are). I'll get some pics of it then.
PhilipJ is offline
post #179 of 352 Old 02-15-2012, 03:42 PM
NW99XJ
Frickin LOVE that bumper!!!
5+" of lift, 33's, OTK, Armored, Lighted, Chipped, Winched & Locked up Front.
NW99XJ is offline
post #180 of 352 Old 02-22-2012, 09:02 AM
XabuJr
XabuJr's Avatar
1992 XJ Cherokee
So it's been like 10 days, where are the pics? Or did you forget the angle grinder?
XabuJr is offline
My 98 Sport Build Thread broncofire75 XJ Cherokee Technical Forum 263 11-30-2012 09:44 PM
Jeep450r's 1996 Sport Build Thread Jeep450r XJ Cherokee Technical Forum 20 02-14-2012 03:16 PM
1993 Cherokee Sport Build Thread...kinda Jcool XJ Cherokee Technical Forum 0 03-06-2011 11:09 PM
XJ HAULIN' Pictures !! ATS XJ Cherokee Technical Forum 8 10-10-2004 08:11 PM
