'99 Sport Build Thread: Grocery Haulin' With Panache - Page 11 - JeepForum.com
post #151 of 352 Old 01-11-2012, 09:25 PM
Brookhart63
Huskies make great friends. Very smart and very independent.
Bought not Built
Jeep Outdoor Club of Cental Iowa
Square Headlight Jeep Club
Brookhart63 is offline
post #152 of 352 Old 01-11-2012, 09:37 PM Thread Starter
PhilipJ
PhilipJ's Avatar
Mine's actually an Alaskan Malamute, although the breeds do look very similar. They're the larger, less crazy sled dogs.
PhilipJ is offline
post #153 of 352 Old 01-12-2012, 01:49 AM
XJ_Renegade
I'm liking the build a lot. You also inadvertently solved one of my driveline woes.
Looking forward to the 'battery tray' install.
1999 XJ - Finally on respectable tires.
1998 ZJ - I'll show you my Niner if you show me yours.
XJ_Renegade is offline
post #154 of 352 Old 01-12-2012, 12:27 PM
MB_01XJ
Good looking Jeep and dog. My wife had an Alaskan Malamute she was a great dog...
01 XJ / daily driver
71 Maverick
72 Gran Torino Sport
85 F150 4WD / Weld Racing wheels, 32 x 11.5 Tires, Leveling springs
MB_01XJ is offline
post #155 of 352 Old 01-12-2012, 12:28 PM Thread Starter
PhilipJ
PhilipJ's Avatar
Thanks. How did I help with that?
Since I don't have a garage I'll be doing the prep, paint, fender cutting and install at a buddy's house over the course of a few visits (plus he has all of my power tools). Hoping to have it done by Super Bowl weekend.
Thanks! They really are great dogs...very independent, so it's nice to not have them running around at your heels begging for attention all of the time.
PhilipJ is offline
post #156 of 352 Old 01-12-2012, 12:59 PM
Spokes
he looks like a raccoon or he has glasses on
nice looking dog though.
Red 00 XJ lifted
Build -->
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline
post #157 of 352 Old 01-13-2012, 10:15 AM Thread Starter
PhilipJ
PhilipJ's Avatar
Got the Dirtbound e-fans installed yesterday. All in all, a very easy project despite the issue with the radiator. It looks like a lot of people hacked their header panel to make the shroud fit over the top of it, but I put it between the radiator and the header. It made for a snug fit when tightening the header back down, but I didn't feel like cutting anything up. Apparently Dirtbound makes a better fitting shroud now that also has vanes to separate the fans, giving them a lower pressure and making them slightly more efficient. Not that they are inefficient at all...the first two come on right at 185 and the third kicks on at 210, dropping the temp to right around 200. Very pleased with these.
The nice German-quality temp sensor plumbed into the heater line. Two lines go to a relay for the 185 fans, the other goes right to the battery. I just wanted to get it all done as it was getting dark, so I'll go back and rewire it to an ACC. Kind of weird hearing all of that fan noise after you shut the engine off.
Plenty of room now with the heavy clutch fan and bulky electric fan gone.
And some other things to do...
PhilipJ is offline
post #158 of 352 Old 01-13-2012, 03:24 PM
XJ_Renegade
My used TW rear driveshaft has a flange-style centering ball and I noticed yours has a yoke-style. It made me realize that I could swap in a yoke-type, so I can buy a pair of those and use a standard SYE instead of the RE hack & tap. More detail on the last page of my build.
Looks like you've got some fun plans for the near future, too.
post #159 of 352 Old 01-16-2012, 05:18 PM
mikeredjeep
[/QUOTE]
Can't wait to see how this is going to look on your Jeep! How long after you ordered the tanker bumper did it arrive? I've heard that its a pretty long wait.
mikeredjeep is offline
post #160 of 352 Old 01-16-2012, 06:30 PM Thread Starter
PhilipJ
PhilipJ's Avatar
I can't wait, either. I think it's really going to tie everything together aesthetically. Hoping to have my tax return back soon so that I can throw on a spare and hi-lift, too.
It was a bit of a wait, but AJ was redesigning the entire carrier plus the hinge/bearing assembly and then he had to wait a little bit for some of the parts to come in (inventory/supply). Took a little over 3 months from his jig to my doorstep I guess, but I told him I wasn't in any hurry for it.
Weighs around 120-130 lbs...
PhilipJ is offline
post #161 of 352 Old 01-17-2012, 07:55 AM
doogie
doogie's Avatar
Love following this build. I'm sure you've said it and I've missed it, approx how much lift are you running with your current set up?
Nationalmssociety.org
Current = 1996 XJ, 2.5, 2-Door, 5-Speed, 4.88's, 3.5" Mix-N-Match, Black 15" KMC XD122's, 31" BFG AT's, RE QD's
Previous builds 99-XJ, 98-XJ, 89-XJ, 05-TJ, 95-ZJ, 79-J10
doogie is offline
post #162 of 352 Old 01-17-2012, 11:44 AM Thread Starter
PhilipJ
PhilipJ's Avatar
It's a little tough to get an exact measurement now that I no longer have the original flare line to measure to from the hubs (unless someone can give me a different reference point) but I estimate right around 3.75" - 4" currently. I'm aiming for 5" with the add-a-leafs and ACOS adjustment so that my 33's can clear the new flares under full flex. Right now they rub just enough to be annoying.
PhilipJ is offline
post #163 of 352 Old 02-02-2012, 06:21 PM Thread Starter
PhilipJ
PhilipJ's Avatar
Since it was nice out today, I decided to hurry and throw in my OME D22XL add-a-leafs. Got a bit of a late start though, so I wasn't able to adjust the front before it started to get dark. Even with the ACOS, there's too many other things to adjust...will tackle that tomorrow. Hoping to get the bumper and tire carrier done this weekend.
Pretty easy to drop these in. Just remove the shock at the axle mount, take off the u-bolts and spring clamps, remove the centering pin and slide in the leaf. Sandwich back together with the jack and tighten everything back up. Took about 90 minutes total and I was taking my time. Gained about 1" exactly, but I didn't drive around afterward to let everything settle in.
Just enough clearance at the clamps to fit an extra leaf in.
PhilipJ is offline
post #164 of 352 Old 02-02-2012, 06:38 PM
GregB_00XJ
Looking good Phillip.
I will be in T Town again soon for a visit with Mom. Would be great to meet up this time! Will give you a heads up and maybe we can make it work?
LOVE the fans.
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #165 of 352 Old 02-02-2012, 06:59 PM
alexrule123
alexrule123's Avatar
I used the OME AAL in my OME pack and it netted 1" and it has stayed that way for over 6 months.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
My 98 Sport Build Thread broncofire75 XJ Cherokee Technical Forum 263 11-30-2012 09:44 PM
Jeep450r's 1996 Sport Build Thread Jeep450r XJ Cherokee Technical Forum 20 02-14-2012 03:16 PM
1993 Cherokee Sport Build Thread...kinda Jcool XJ Cherokee Technical Forum 0 03-06-2011 11:09 PM
XJ HAULIN' Pictures !! ATS XJ Cherokee Technical Forum 8 10-10-2004 08:11 PM
