99 cherokee sport 146k - JeepForum.com
post #1 of 8 Old 09-12-2013, 08:28 PM Thread Starter
troydg
Ok guys so I'm lifting my 99 xj with a 3 in rough country lift, now it comes with an add a leaf, I was told you can insert the add a leaf without taking the whole leaf springs off of my rear end, I just wanted to know if this is true, and if so how would I go about it?
troydg is offline
post #2 of 8 Old 09-12-2013, 08:33 PM
Muddy97Cherokee
1997 XJ Cherokee
Yes. Undo the ubolts and the leaf spring clamps. Then put a clamp by the center pin and undo it. Pull the leafs apart and put the aal in place. It's ideal to get a new center pin and clamps, as well as ubolts.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
post #3 of 8 Old 09-12-2013, 08:40 PM Thread Starter
troydg
So how would I add the aal If it's clamped? Sorry lol I'm a visual learner
troydg is offline
post #4 of 8 Old 09-12-2013, 08:41 PM
Muddy97Cherokee
1997 XJ Cherokee
You put the clamp there so the leafs don't fly all over the place. Once the pin is out then undo the clamp.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
post #5 of 8 Old 09-12-2013, 08:46 PM Thread Starter
troydg
Then just slide the aal in and put it all back together?
troydg is offline
post #6 of 8 Old 09-12-2013, 08:50 PM
Muddy97Cherokee
1997 XJ Cherokee
Yup. Be sure to put the aal the right way. One side will be longer than the other. You will see once you get it.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
post #7 of 8 Old 09-12-2013, 08:51 PM
Muddy97Cherokee
1997 XJ Cherokee
And also put it in the right order. The aal should go under the leaf longer than it and above the leaf shorter than it. Typically the long aal's go under the main leaf.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
post #8 of 8 Old 09-12-2013, 08:52 PM Thread Starter
troydg
Ok man, I'm not doin it until Monday hopefully but ill let you know how it goes, I appreciate the help!
troydg is offline
