99 cherokee speakers - JeepForum.com
post #1 of 16 Old 01-30-2016, 12:10 AM Thread Starter
SurferJ
So crutchfield lists 2 speaker sizes as fitting both the door and rear speaker locations. Which is it? 6 1/2" or 5 1/4"???
SurferJ is offline
post #2 of 16 Old 01-30-2016, 12:19 AM
nolanbalzarini
nolanbalzarini's Avatar
I know 5 1/4 does fit. I did rockford fosgate 5 1/4 all the way around when i replaced mine.
I heard reports of 6 1/2 fitting but I didnt do it because it wasn't a guarantee and they tend to be deeper and may cause interference with the window.
good luck.
Cherokee Of The Month. September 2015
nolanbalzarini is offline
post #3 of 16 Old 01-30-2016, 02:07 AM Thread Starter
SurferJ
Originally Posted by nolanbalzarini
I know 5 1/4 does fit. I did rockford fosgate 5 1/4 all the way around when i replaced mine. I heard reports of 6 1/2 fitting but I didnt do it because it wasn't a guarantee and they tend to be deeper and may cause interference with the window. good luck.
Thanks. I'm guessing the safe bet for Windows is 5 1/4 for that clearance issue. But if 6 1/2 fit the rear overhead speakers I would definitely prefer that. Anyone know for sure?
SurferJ is offline
post #4 of 16 Old 01-30-2016, 08:45 AM
nolanbalzarini
I don't know.. I didn't look into it very hard.
post #5 of 16 Old 01-30-2016, 09:52 AM
Scottykenneth
Just changed my 96 speakers. 5 1/4 was the size
Scottykenneth is offline
post #6 of 16 Old 01-30-2016, 10:04 AM
S8NNG8
Kustom Phabrication
S8NNG8's Avatar
1995 XJ Cherokee
I think a '99 has different specs than us old models.
D3<!L!>3D
S8NNG8 is online now
post #7 of 16 Old 01-30-2016, 10:08 AM
Scottykenneth
Ohhh. I knew that
post #8 of 16 Old 01-30-2016, 10:12 AM Thread Starter
SurferJ
Anyone else????? Lol
SurferJ is offline
post #9 of 16 Old 01-30-2016, 10:15 AM
S8NNG8
Kustom Phabrication
S8NNG8's Avatar
1995 XJ Cherokee
I am curious to know if a late model roof bar accepts 6.5" speakers though. As far as the doors, I put 6.5" s in my front and rear doors of my '87 by building spacer plates out of 3/4" MDF. Then screwed the upholstered board to the door.
D3<!L!>3D
post #10 of 16 Old 01-30-2016, 04:20 PM
MossGreen97
1997 XJ Cherokee
On my '97 the factory speaker size is 5 1/4". doors and 6 1/2 ". rear sound bar. I put 6 1/2" Sony Xplode speakers all around. They were a bolt in for the doors, but to make them mount better I moved the mounting points up about 1/2" to center the speaker in the grill area.No interference with the window and no metal cutting. All the speakers are installed behind the factory grills/ door panels so everything looks stock.
'97 XJ Moss Green Metallic. 2DR. 2WD AW4 tow pkg.,3.73 gears. Firestone Destination A/T 225/75x15.
MossGreen97 is offline
post #11 of 16 Old 02-03-2016, 10:00 AM
bluejunior
Hold my beer
bluejunior's Avatar
late model roof bar will take 6.5's the same as the doors will, you have to drill an extra hole for most speakers.
Source: I used to run 6.5" alpines in my '01's soundbar.
Lifted, Locked, Stiffened
Build
bluejunior is offline
post #12 of 16 Old 02-03-2016, 10:58 AM
S8NNG8
Kustom Phabrication
S8NNG8's Avatar
1995 XJ Cherokee
If I find one, I'll move my 5 1/4" stock one up near the drivers head and put the 6 1/2" in back.
Were the Alpines S's or R's?
D3<!L!>3D
post #13 of 16 Old 02-03-2016, 11:24 AM
bluejunior
Hold my beer
bluejunior's Avatar
R's. They were placeholders until I could get better speakers to match my front components. I use polk MOMO 5.25" components there now. The momo's seem to have a wider mounting hole pattern than most 5.25's and fit the stock holes, which are kind of in between standard 5.25 and 6.5 widths.
Also worth noting here the momo 6.5's I have up front list a mount depth of 2.5", without the covers on the magnets it's more like 2-3/8. my windows just barely rub them when all the way down, so I'd consider 2-3/8 to be the maximum mounting depth for the 97-01 front doors without adding some kind of spacer. Since there's a pretty small amount of space in front between door steel and panel plastic that may mean if you want deeper speakers it would be best to make a thick spacer, cut out the plastic and mount speaker and included grill through the panel to guarantee no interference. The speaker bar has more depth to offer but a lot of speakers are deeper than 2 3-8 so I thought I should mention that since the thread question was for a '99.
Also worth mentioning, even with wadding and sound deading on the roof I can't get much useful below 80hz out of the 97-01 speaker bar without a hell of a lot of EQ, so that's a limiting factor to keep in mind. You want your good speakers in the door or to have an 8 or 10 inch sub that's quick enough to handle up to 100hz cleanly. I know you've got that covered S8, but I thought it might help OP.
Build
post #14 of 16 Old 02-03-2016, 06:45 PM Thread Starter
SurferJ
R's. They were placeholders until I could get better speakers to match my front components. I use polk MOMO 5.25" components there now. The momo's seem to have a wider mounting hole pattern than most 5.25's and fit the stock holes, which are kind of in between standard 5.25 and 6.5 widths. Also worth noting here the momo 6.5's I have up front list a mount depth of 2.5", without the covers on the magnets it's more like 2-3/8. my windows just barely rub them when all the way down, so I'd consider 2-3/8 to be the maximum mounting depth for the 97-01 front doors without adding some kind of spacer. Since there's a pretty small amount of space in front between door steel and panel plastic that may mean if you want deeper speakers it would be best to make a thick spacer, cut out the plastic and mount speaker and included grill through the panel to guarantee no interference. The speaker bar has more depth to offer but a lot of speakers are deeper than 2 3-8 so I thought I should mention that since the thread question was for a '99. Also worth mentioning, even with wadding and sound deading on the roof I can't get much useful below 80hz out of the 97-01 speaker bar without a hell of a lot of EQ, so that's a limiting factor to keep in mind. You want your good speakers in the door or to have an 8 or 10 inch sub that's quick enough to handle up to 100hz cleanly. I know you've got that covered S8, but I thought it might help OP.
Very helpful. Thank you
SurferJ is offline
post #15 of 16 Old 02-04-2016, 02:28 PM
scs2016
I recently acquired a 1999 XJ (sport) and just put Polk DB651's in the rear. They fit in the factory openings, but the mounting holes needed a little finessing. Crutchfield does not spec these as a fitting.
I just ordered a pair of the Poolk DB651S's for the front doors. The "S" is for shallow I think and Crutchfield does list these as compatible for the front doors (with a bottom mount depth of 2-5/16").
04 TJ 4.0L, 5-sp, 2.5" OME lift with 1.25 BL
99 XJ, 2WD, 4L, AW4, 190K
scs2016 is offline
