98 XJ Roof rack build. - Page 2 - JeepForum.com
post #16 of 31 Old 08-17-2012, 11:44 PM Thread Starter
deitzberg
Heres some updated pictures from tonight.
http://i1259.photobucket.com/albums/...i/DSCN0774.jpg
I decided to have the back side hinge open and keep the front locked in place.
deitzberg is offline
post #17 of 31 Old 08-18-2012, 02:26 AM
QXj97
1997 XJ Cherokee
looking nice when will it be ready to mount.
QXj97 is offline
post #18 of 31 Old 08-18-2012, 02:27 AM
jeepster383
I also made little supports to help spread the weight out. Made out of angle iron and flat bar.
jeepster383 is offline
post #19 of 31 Old 08-18-2012, 11:03 AM Thread Starter
deitzberg
I have to run to the store to get some bolts. But I am hoping to be done except for paint today.
Those little brackets are a good idea.
post #20 of 31 Old 08-18-2012, 10:31 PM Thread Starter
deitzberg
Here are some more pictures. The rack itself is done. I decided to keep the front portion stationary and have the back portion hinge open.
I am up in the air about painting it back or leaving it the sliver color.
Here is the bracket that I am using to secure the rack to the jeep. There are 4 spots for a bracket.
post #21 of 31 Old 08-19-2012, 04:06 PM
QXj97
1997 XJ Cherokee
looks good i m going to try and make a homemade roof rack.
QXj97 is offline
post #22 of 31 Old 08-19-2012, 05:04 PM
jjshbetz11
Where did you find those brackets at? They look like they were almost made for this application
sent from a flat black thingie
R.I.P 96 xj aka. War Queen
Hello 2000xj
jjshbetz11 is offline
post #23 of 31 Old 08-19-2012, 08:21 PM Thread Starter
deitzberg
I was in lowes and in th asile with the unistrut they are directly below the strut. They are called "top beam clamp 1/4". They fit very nicely and have a pre tapped hole on the back side and top in addition to the front screw that it comes with. I am going with a total of 4 crossbars so between clamps and 2 10' sticks of strut its about $45.
post #24 of 31 Old 08-19-2012, 10:08 PM
jjshbetz11
Thanks for that info. Have a rack in my mind but the only thing that was stalling me was a way to mount it to the rails. Your way looks really good!!!
Hello 2000xj
post #25 of 31 Old 08-19-2012, 10:15 PM Thread Starter
deitzberg
No problem and thanks. Using those mounts and the uni-strut keeps the rack nice and tight to the roof. I was a little worried about putting the rack up on the factory cross bars. Post some pictures once you get going.
post #26 of 31 Old 08-20-2012, 10:12 AM
TimHaw
1992 XJ Cherokee
looks pretty slick. How can I get ahold of one of those crates? Pretty solid recycling right there
TimHaw is offline
post #27 of 31 Old 08-20-2012, 10:52 AM
josh94xj
1994 XJ Cherokee
A little big for my taste but nice work it looks pretty good looks pretty sturdy to!
"Jeep. Go prepared."
Originally Posted by Teal2doorXJ View Post
i say screw it and just rawdog it!
Originally Posted by cherokeekid58 View Post
Selling your jeep is like selling your soul....
NEW JEEP PROJECT COMEING SOON!
josh94xj is offline
post #28 of 31 Old 08-20-2012, 12:34 PM Thread Starter
deitzberg
They are called IBC short for "Intermediate bulk container". I actually picked mine up from a plant in new jersey that cleans them out and recycles them. I would check with a junk yard they may have some there or any big factory in your area. Even check with the city water department they should have some. I cant quote a price since I got mine for free but when I googled it they were around $100 for just the cage.
As far as the height I kept it a little on the large size for fitting suitcases in and locking it up. But you could easily cut it down and add a top rail. There would be enough left over to possibly make another rack if you make it with out the top portion. I am still kicking around the idea of chopping it down and losing the top cage. I am waiting to test it out before I make that final decision though. I have a long trip coming up so it should be a good test.
Through out the build I was standing on the cross bars in between the supports and it didnt give at all. I am no small guy so it should be able to take a pretty decent load strapped down. I even bounced up and down a few times with no worries.
post #29 of 31 Old 08-20-2012, 05:05 PM
jjshbetz11
Paint it black and call it a day
Hello 2000xj
post #30 of 31 Old 10-03-2013, 07:42 PM Thread Starter
deitzberg
After all said and done.
I ended up hacking it in half and leaving the back open for oversize items. Its held up pretty good. The unistrut brackets have not moved a bit from the day I installed them.
98 xj , cherokee , roof rack , xj
Build your own Roof Rack for $70 Buckets XJ Cherokee Technical Forum 18 06-12-2015 05:29 PM
2001 XJ Roof Rack/Light help: Build own or buy one. AustinTexasXJ XJ/MJ Cherokee Non-Technical Forum 9 10-02-2011 10:31 PM
my $20 roof rack build kirbWJ XJ/MJ Cherokee Non-Technical Forum 21 05-06-2010 12:26 AM
Home Brew roof rack build Big4banger XJ/MJ Cherokee Non-Technical Forum 26 03-23-2010 11:17 PM
Looking to Build a Light Bar or Use the Roof Rack..Which One? ChaoticBastard XJ Cherokee Technical Forum 5 06-08-2005 08:09 PM
