98 XJ Roof rack build. - JeepForum.com
post #1 of 31 Old 08-12-2012, 03:15 AM Thread Starter
deitzberg
I was working at a facility that reclaimed hazardous waste containers and after seeing one of the 300 gallon I.B.C. I had an idea for a roof rack. If you are not sure what they are Google it and I posted a pic below of what I started with.
I started off by chopping it in half and than again. I did this because the rails on the one side were not spaced the same as the other. So I placed the two identical halves together.
Now this is where I have paused to get some input from some other people on how to proceed.
Option #1 Fix mount the other end caps or maybe make it so I could pull them off if necessary for hauling something long.
Option #2 Make it so that the front and back fold out. This would give me a kind of cage so that I wouldn't worry when on a long road trip. I could lock up the cage and people could just cut a ratchet strap and walk off with my luggage. Also I would allow to open up to carry bigger items that may not fit in when closed up.
Any suggestions or comments would be appreciated. It is aluminum so I cant weld on it. I just dont have the skill or proper equipment.
Deminsions:
Middle rack: 48.5" wide
Long:
Option #1 69"
Option #2 Folded up ~48"
Option #2 Folded out ~90"
It started out:
47" wide side with 6 cross bars
39.25" wide side with 4 cross bars
49" Tall.
deitzberg is offline
post #2 of 31 Old 08-12-2012, 03:25 AM Thread Starter
deitzberg
additional photos
Here is a link to photo bucket where I have some additional photos of what I am working with.
http://s1259.photobucket.com/albums/ii542/Deitzbergiii/
post #3 of 31 Old 08-12-2012, 09:36 AM
Camfam07
I like the option 2 to be able to close and lock it up or open it and have a huge carrier on top, pretty sweet idea, but I say option 2, I have no input on how to put it all togethter though, as I have no idea how to work with alum either.. looks good though
Camfam07 is offline
post #4 of 31 Old 08-12-2012, 10:46 AM Thread Starter
deitzberg
thanks. i am in the garage playing around with it so i will post some more pics as i progress. One nice aspect so far i can lift it up by myself, so the extra cage weight wont make me too top heavy.
post #5 of 31 Old 08-12-2012, 10:21 PM Thread Starter
deitzberg
I fitted the middle portion on the jeep just to get a preview. The part above the second rail will be cut off but I needed an idea.
I got the middle together so now I have to make the final decision on folding or not.
post #6 of 31 Old 08-14-2012, 09:26 PM Thread Starter
deitzberg
Can anyone give me some advice on how to secure the rack to the jeep?
I am considering using the existing rack rails with a set of brackets that can fit over the rail and secure in the holes that are drilled on the outside of the rail. I think they are for tie downs but not sure.
post #7 of 31 Old 08-15-2012, 06:20 AM
CRider74
If it were me...I'd get rid of the factory rack altogether, seal the holes, and use rain-gutter mounts for the basket you're building. At least, that's what I'm hoping to do on mine
Smokin' & Jeepin' (Finally!!!)
CRider74 is offline
post #8 of 31 Old 08-15-2012, 07:32 AM Thread Starter
deitzberg
Will they support the weight with no issues? Mine seem to be in good structural condition but I just don't completely trust it.
post #9 of 31 Old 08-15-2012, 07:51 AM
CRider74
From everything I've read, they'll support more weight than the factory roof rack. I'm planning on using 6 (3 spaced out on each side) to distribute the weight.
Edited to add - my comments & opinions are based solely on research at this point, as I'm hoping to build my roof basket this fall/winter.
CRider74 is offline
post #10 of 31 Old 08-15-2012, 12:24 PM
CharlieCherokee
1992 XJ Cherokee
yes absolutely go with the rain gutters but your factory rails should last you a while.
in regards to your design, i like a low profile roof rack so i would rather have it be real low versus tall and cagey like, just my opinion.
In regards to mounting it to your roof rails, id just get some u-bolts and plates and fasten 'er up
1992 Jeep XJ Sport
http://www.jeepforum.com/forum/f22/1992-cherokee-sport-1394133/
CharlieCherokee is offline
post #11 of 31 Old 08-15-2012, 05:11 PM
jeepster383
Here's how mines mounted
jeepster383 is offline
post #12 of 31 Old 08-17-2012, 03:58 PM Thread Starter
deitzberg
I am actually looking at securing it to the rails that those cross bars ride on. I would run a piece of channel across the roof to the other side so that the weight would be spread out.
post #13 of 31 Old 08-17-2012, 06:00 PM
cherokee_94
I fastened mine the same way. Just take some eye bolts an cut them to be a hook and fit them in the holes in the inside of the rails. Works great!
cherokee_94 is offline
post #14 of 31 Old 08-17-2012, 06:32 PM
QXj97
1997 XJ Cherokee
nice that gives me a couple ideas.
QXj97 is offline
post #15 of 31 Old 08-17-2012, 10:18 PM Thread Starter
deitzberg
What did the rack rest on? Was it the roof or did you keep the factory cross bars on?
98 xj , cherokee , roof rack , xj
Build your own Roof Rack for $70 Buckets XJ Cherokee Technical Forum 19 07-26-2017 10:44 AM
2001 XJ Roof Rack/Light help: Build own or buy one. AustinTexasXJ XJ/MJ Cherokee Non-Technical Forum 9 10-02-2011 09:31 PM
my $20 roof rack build kirbWJ XJ/MJ Cherokee Non-Technical Forum 21 05-05-2010 11:26 PM
Home Brew roof rack build Big4banger XJ/MJ Cherokee Non-Technical Forum 26 03-23-2010 10:17 PM
Looking to Build a Light Bar or Use the Roof Rack..Which One? ChaoticBastard XJ Cherokee Technical Forum 5 06-08-2005 07:09 PM
