'97 Front and Rear Window Washer Pumps - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > '97 Front and Rear Window Washer Pumps
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 03-30-2015, 07:49 AM   #1
shooptube
1997 XJ Cherokee
(I posted this in technical but no one over there seems to have an answer so I thought I would post over here.) Hey guys just decided to fix my window washer pumps because neither one seems to work any more. I changed the pumps with brand new ones. Also I checked on the battery that both work. When I tried to test the new pumps neither work when plugged into the harness. Is there a separate fuse for just the pumps? I have only heard of one master fuse that does the wipers and the pumps and my wipers work fine. Any help would be appreciated. Thanks guys.
A ton of metal on your Jeep, different from, a ton of well-engineered metal on your Jeep.
shooptube is offline   Reply With Quote Quick reply to this message
Unread 04-03-2015, 08:39 PM   #2
shooptube
1997 XJ Cherokee
Bump. I really need to get these done. Please help
Unread 04-04-2015, 06:18 AM   #3
FairlanePhil
I have no idea but try looking at the diagrams in this thread for clues or diagnostic tips
http://www.jeepforum.com/forum/f11/g...-inop-3115977/
You may have to play with a long jumper wire and look for breaks in the harness or connections
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline   Reply With Quote Quick reply to this message
Unread 04-05-2015, 10:08 AM   #4
shooptube
1997 XJ Cherokee
Thnaks for responding Phil. If I cant find the break, I may just send two fresh wires all the way down to the pumps.
