96 XJ Sport 4.0L 4wd Auto with code 35 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > 96 XJ Sport 4.0L 4wd Auto with code 35
Engo winches available at www.rockridge4wd.com! Free shippJeep speedometer gears at rockridge4wdDana 30 Truss for your TJ, LJ, ZJ, and XJ
Unread 06-21-2014, 12:35 PM   #1
Doostica
I've got a code 35 which is: Cooling fan relay circuit open or shorted
35 idle switch motor fault - check connections
Which of these 3 do I need to replace? My thermostat, and water pump are new.
#1 http://goo.gl/kF0i79 (according to my vin using the mopar search) ....
this option #2 http://goo.gl/Jr39CM (the relay to radiator fan) or is it option #3 http://goo.gl/NMlOVp
I ask because all 3 are considered fan relays.
***and just to clarify, the second option "idle switch motor fault" would be the Air Idle Control Valve/Motor next to the tps on the throttle body, correct?
Doostica is offline   Reply With Quote
